mtaylor
Moderators
Everything posted by mtaylor
  1. Eric, Every builder sees the smallest of "problems"... the rest of us usually never do. Looks great.
  2. You got me checking and reading, Richard. Those aren't hammock cranes. as the French of the period didn't use hammocks (at least in frigates). On the replica it's a walkway. On many frigates of the time, these rails were removable so to lessened the height the boats had to be raised (and for easier handling) over the side. I'm still checking my sources on this. Ah... here's one of the videos... at the 0.29 mark you can see them. BTW, here's all the videos (including construction): https://www.youtube.com/user/HERMIONE17300/videos And here's the video I referenced:
  3. Welcome to MSW, Tobias. Once you have your kit, feel free to start a build log in the kit area. It's the best way to get help.
  4. Do give some thought to starting a build log. It's a great way to get help and someone looking over your shoulder.
  5. Welcome to retirement, Gary. Mark is correct, there aren't enough hours in the day.
  6. If they're square openings I make note of size and location, then cut to "close" by drilling out the center first. After that, I sand using sanding sticks. As a check piece, I make a block of wood the size for the ports that's again tapered such that one end is full size and rest isn't. This tells me when I'm getting close. I also put reference lines on the hull and the check piece to keep everything square. Beware though.... on some ships (seems common on French frigates) the first port isn't a gun port but used for handling of the anchor. It is often a different size then the gun ports. On some ships, they aren't as the sides are vertical but the top and bottom match the run of the deck. Same method would work, just a different "insert". I'm sure others have their own way of doing this but this is what works for me. As always, your mileage may vary.
  7. Hi Tony, Welcome to MSW. I moved your topic to the "New Member" area. So far, you've got some great answers to your questions. I'd suggest picking one of the kits from your stash that interests you the most. Then start a build log in the kit area. It'll be the best way to get help. Also, pick one that has one mast for starters. I had no ship building skills to speak of and my first kit was the Scottish Maid. My biggest issue was the rigging so I should have went with one mast.
  8. Welcome to MSW, Bick. Start a build log as it's the best way to get help. You can go to the Kit area where you'll find an index to all the kit builds. Looking at others build is very helpful.
  9. Breaks are needed, Yves, unless we want to get burned out. I look forward to seeing your other projects and then this one when you return to it.
  10. Are you using a solder designed for aluminum? Also, you'll need a low power soldering tool. If no one gives you and answer, do some Googling for aluminum solder and soldering tools. I did solder aluminum some decades using a small torch and aluminum solder to make spoiler for a car. If I recall correctly, you're actually welding the aluminum.
  11. Looks great, Chris. You got the hang of running the laser quickly. Can I ask which brand and the laser power? As for the etching... low, low, low power and speed will need to pretty fast.
  12. Yves, super well done. The figures really give a sense of size of those engines. I didn't realize the cylinders were that large.
  13. Welcome to MSW, Tom and good on you for coming out the lurker section. Looking forward to your build log.
  14. Stunning work, Doris. Just leaves me speechless. I hope you and your family have wonderful holidays.
  15. Chris, I think we all have gone through what you're feeling about "is this right?". Every scratch builder had to start someplace.
  16. Use pushsticks. I use some old chopsticks that are notched on the end and once the end of the plank is close to the blade ( maybe 3-4 inches) I use the push stick. It doesn't matter the length of the plank but I always use pushsticks. I also have "finger boards" to help guide the wood. When I don't use the finger boards, I use 2 push sticks one to push it and the other off to the side near the blade to help guide it and keep it from moving away from the fence. Oh.. no long sleeves and stand off the side. Kick back can do a lot of damage to the body and sleeves can get grabbed by the blade. Be safe!
  17. With regard to the wood stacking... the Engineer is the boss, right?
  18. Chris, Off to a great start. If you haven't done so, use the search feature for Bonhomme Richard. There's been at least one other build of her by Jeronimo. Plus discussions on the wreck being found, My bad... there's another one by Jerry Greening. These might help you. I do have the monograph also and it's on my bucket list.
