Everything posted by mtaylor
Yes. hardwood is an excellent choice for them.
If carving is an issue... have look here https://modelshipworld.com/forum/84-build-logs-for-the-carving-group-project/. Basically, it's nice learning how to carve using simple tools. I think that with the tools and plans you have, the Rhino won't add much as the parts can be cut from the plans using the tools you own.
Fokker Dr1 by Javlin - FINISHED - Revell - 1/28 - PLASTIC
mtaylor replied to Javlin's topic in Non-ship/categorised builds
Nice work on the DR1. -
Are those measurements you gave "actual" or "scale"? Seems a 9 foot long keel will be huge if that is actual size. As for large quantities it depends on where you are and what local species are available and also a local mill or wood shop to do the cutting. You might also inquire our sponsors that do custom woods and see if they take special orders.
Occre Diana (Spanish frigate 1792), low quarter gallery windows?
mtaylor replied to Esap's topic in Wood ship model kits
When I built my Constellation (see link in my signature) I scratched my own galleries. Different era and probably different design. The kit had some crappy casting and wasn't accurate nor fitting properly. It really wasn't all that hard to do. You could probably do the same thing on your model but you may need to rework the stern like the bottom photo shows. The upper photo seems to show the stern framed in as it should be. -
Interesting problem. Have you looked at other builds? It would appear that there are no galleries as such the extend out from hull siding. I might be wrong on that part. And yes, it looks like the bottom of the windows do go lower than the gun deck. If those are galleries extending outside the hull line, it's possible that the gallery deck was lower than the main deck but not being familiar with Spanish vessels I can't say for certain. -
which mini wood lathe is best?
mtaylor replied to Benjamin S's topic in Modeling tools and Workshop Equipment
Ben, is there a Makerspace where you are located? If so, they probably at least have a wood lathe and possibly a metal one also as well as many other power tools... mills, saw, sanders, etc. (the local one near me has seemingly a warehouse full). Pretty reasonable to join them and they do have training on all their tools, both power and hand. If it's like ours, they won't let use and tool unless a) you had their training and/or b) prove that you know how to use it. -
Macro is out enemy especially on such tiny model as that boat. It does look great from here. And Bedford is right about being our own worst enemy. Enjoy (hopefully) you're time off for the holidays.
Can you immerse the glued parts in alcohol? If so, I've used PVA (Elmer's School Glue is my usual first choice) and when time to separate and just dropped them into alcohol. I don't force them apart but let the alcohol soak and dissolve the glue. Sometimes it a matter of maybe an hour and other times it's a lot longer.
I'd start by going to the kit area and searching using "CARD" as the key word. Also set the search for "titles only". Also there is this area for discussion but no build logs: https://modelshipworld.com/forum/28-card-and-paper-models/
There is but I'm not sure what it is currently. I just size all mine a 1500 pixels wide and seems to give a good image.
Welcome aboard.
Yes. But do try to use a large an image as possible. Some phones are limited to size and we end up tiny photos.
Thanks Frolick. I saw that site but I'm building at 1:64. He is doing nice work. I ended up buying some guns from Chuck and since they'll all basically be hidden, I think they'll be ok. I may have to tweek the muzzle. though. Currently, she's on the back bench waiting for me to get my Sphinx kit finished. High School French????? Sadly I didn't take French. But Google Translate is my friend.
I'm surprised that the helmsman would be in that position. Seems very cramped and not very ergo friendly as far as being able to change sides while steering. But he does look the part there.
- 106 replies
- Admirals Barge
- Vanguard Models
This has been a mind boggling yet wonderful log to follow. By all means, stay warm. I'm looking forward to seeing the grand finale.
Wow... that is an impressive model and display. Looks perfect. And yes... a toast or several is in order.!!!!
- 134 replies
- Captain Kidd
- bottle
(and 3 more)
