Everything posted by archjofo
Hello, many thanks für the nice comments. In between, I will still show you how the portholes of the ventilation hatches are constructed. The glass body with a diameter of 1.3 mm were punched out with a specially prepared punch pliers from an acrylic glass plate. Then they were glued with Micro Kristal Klear in a brass tube piece. The brass tube piece has an outside diameter of 2.5 mm. See you soon ..
Hi Mark, thanks for your kind words. Here is a little update, with other metal fittings for the outboard walls of the French corvette. I hope you enjoy the pictures. This can happen sometimes. Here's a look into my sorting box with various fittings. In this case also the support for the anchor and the boat davits are seen. Here you can see a scupper valves. The eye bolts to mount outboard. Drilling the bolt holes with a diameter of 0.3 mm drill is a very delicate affair. For one of these fittings 8 holes are to be performed. Finally, an overview.
ROYAL CAROLINE 1749 by Doris - 1:40 - CARD
archjofo replied to DORIS's topic in - Build logs for subjects built 1501 - 1750
Hello Doris, the standing rigging looks very realistic. You build amazingly exact. Simply fantastic! I admire your work.- 883 replies
- royal caroline
- ship of the line
Hi Karl, I can not repeat often enough myself, but your section model of the BRH is just fantastic. This precision and attention to detail is extraordinary. Here I can learn a lot about professional modeling.
- 662 replies
- bonhomme richard
- frigate
Hi Grant, I appreciate your kind words. ... and so it goes on: The reinforcement (flat iron) for the supporting knee I made out of brass sheet 0.2 mm. The support of the channel (round iron bars) was made of brass wire with a diameter of 0.9 mm. The second attempt for a support for the channel can be seen in the picture. This is made of a round brass bar having a diameter of 1.5 mm. This is too massive, unrealistic. In the next step, these pieces are browned and then mounted.
Hello Doris, it is a pleasure to see your new build log images. Is it possible that you show us your ropewalk?- 883 replies
- royal caroline
- ship of the line
