bear
Posts posted by bear
Ahoy Mates
Pickels is high on Cat Nip plus he was going around in circles trying to catch the damn red laser light that I tease him with. And mostly because he hates the damn Santa Hat!!!!!!!. But other than that he's a very happy cat and ruler of the house here in Troutdale.
Merry Christmas and Happy New Year to ALL!!!!!
And use CA only when you have to. PVA is better on your model and health than CA. My sisters horse Wyatt says to stay away from the hide glue also for reasons I do not have to explain here,and in memory of his parents.
Ho Ho HO LOL
Keith
- mtaylor, Canute and thibaultron
- 3
Ahoy Mates
Since I am now sensitive to CA-it causes me to have symtoms like I have hay fever,I also just use CA to stiffen the ends of thread and with material that PVA can not hold. It was a great change in my building quality of the rigging and how the thread looks after it has been glued. I also use flat varnish to hold knots.
I use transparent Titebond and Titebond II. The transparent Titebond has a more flexible when it hardens,and is almost clear.
Then only problem I have is with black thread and how the silvering shows if you do not water it down enough. It causes holding problems since there is not the same thick glue to start with. Sometimes I just use the regular thick glue and then touch up the silvered area with flat black ink or paint,and then cover with flat varnish.
But it always beats the problems with brittle,stiff and glass like surfaces that CA can create on the thread and where you use it. With the PVA,it still shrinks down into the thread when it dries,which CA doesn't.
It doesn't harden as fast as CA,so you do not build as fast,but that's a great thing since you end up looking and thinking about what you are doing and have done. Remeber you are doing this for enjoyment not a speed building race.
Just try doing the same knots and rigging with CA and then PVA and really look at the end results. You decide- it's your build and you are the one who knows which one you like best. And PVA is easier to debond with just rubbing alcohol .
Merry Christmas and Happy New Year form Pickels and Keith
- BobG, aviaamator, Canute and 6 others
- 9
Ahoy Jerry
They can change the scale easy to 1/36,so what would you want?
Keith
- donfarr, mtaylor and thibaultron
- 3
Ahoy Mates
I have been getting some 3D printed parts for my builds and have been asked by the designer as to what modelers would want made in 1/48 scale.
What would you want printed that you would buy?
Thanks
Keith
Ahoy Chuck
It's like a lifetime ago-40 some years ago when I started out learning how to file and polish form die's at work. It just takes lots of just doing. You will get a feel for it just like in your planking skills.And develope your own ways and steps and final finishing mediums.
It's easier with steel because you have material that has no grain to deal with. You might try scraping with very small knife blades. Just like you make your moldings ,but in shaped areas and corners. I use small dental scrapers for my plastic models and they work great on wood.
It just is that the photos show up everything your eyes do not see.
Keith
Ahoy Mates
Just received some 3D printed parts for a scratch build I will be making of my Dads ship he served on in 1942-43 in Greenland. The Albatross Class Minesweeper AM72 USS Bluebird in 1/96 scale.
I purchased USN navy figures,Lewis air cooled macine guns and a 3"50cal Dual Purpose single Gun mounT. I have read some ways of cleaning and painting 3D printed parts but want to know if any body here has experience with these type of parts. And whats the best way to paint them,and which paint to use.
Here's what they look like. It's hard to see the fine details of the figures since they are in frosted white color.
Keith
- Canute and thibaultron
- 2
Ahoy Steven
Well,Pickels and I were unable to comp-lete the ship for the show. Just too much work to be done and little time,so I just said forget it for this year. Right now I am remaking some of the last couple weeks rigging work that I had hurried thru. Now I can take my time and not build for a show,but for me.
There's nothing worse than building for a show deadline,and I will never do it again. My last builds that ended up in a show and entered had been finished long before the show,and during the build I did not have a contest in mind.
It's better to take the time it takes to do your best work.
Keith
- mtaylor and Louie da fly
- 2
Ahoy Duff and Brian
Thanks for your replies. I have to finish the rigging by Friday because the Mary Rose is being entered in our Annual Contest. Now I can finish up this part of the ship. If there is contrasting information please post it.
Thanks
Keith
- mtaylor and skipper1947
- 2
Ahoy Mates
Setting my lateen yards for my Mary Rose for the Mizzen and Bonadventure mast's.Being that I have never rigged a lateen yard I want to know if they are set inside of the shrouds,which limits the angle to which they can be set from just fore and aft, or should they be set at an angle outside of the shrouds?
Have looked thru my reference books ,and they do not show exactly where they should be.
Here's photos of how I have just set them on the masts now on the Mary Rose. The Jotika kit finished model photos show them inside the shrouds like I have set them now.
They are just set there,nothing is lashed down,I want to find out before I start to set the lines on the cleats and pin rails. I have not routed the lines to the correct belaying points either.
Thanks ahead of time for your help. And is there a reference book or site that shows clearly how they shoud be set-the lateen yards .
Thanks Keith
- skipper1947, BIGMAC, Tadeusz43 and 4 others
- 7
Ahoy Mates
A lot of my toolmaker tools are now being used in my shipyard.Diamond files,radius gauges,scribers,height gauges,dial calipers,angle protractors,dept gauges,toolmakers square,squares,pin vises,toolmakers vices,Bridgeport Milling machine,12" lathe,surface grinder,unimat lathe,transfer punches,shim punches and die.
People asked me when I retired if I was going to sell off my tools. Hell no I said,I still have models to build. I am lucky that they were purchased over the last 48 years now,and I would hate to have to start over and buy some of them now. Just my Starrett Toolmakers Square cost's over $350.00 now! And I use it all the time on my ships.
I also have all of my Fathers Toolmaker tools to use. He taught me the trade and we worked together for 18 years before he retired. He then did wood carving making figures and then chip carving before he passed 6 years ago. I use quite a few of his tools in my model building.
Plus his wood carving tools. I just wish he was still around to do his excellent sharpening of them.
Using all these tools in model making gives me the feeling that I am still working on die's,except they are 99% wood now. I use all the skills that I learned in toolmaking in my model making now. And have always loved doing both since I grew up with my dad teaching me how to build models and later how to build and design die's.
Keith
Ahoy Mate
I have their 1/72 German Torpedo Boat resin kit,they are expensive by they are very detailed and the only ones being made. I like the half hull type for space requirements. I remember that one member of our modeling club made up a submarine diorama that had the ocean surface with what he stated as a 1/35 scale Typhoon Class Russian at periscope depth.
He had a base that was only 4" X 8" with the ocean surface made out of resin with the periscope sticking up 3" ! The rest was underwater! Or under the base he would say with a smile.
I just wish they had other types of submarines. I do have a 1/72 resin kit first type Holland submarine kit that was made a decade or more ago by Bluewater Navy.
Keith
Ahoy Mates
Here's whatbasswood for the deck planks,boxwood for the hull planks and swiss pear for the gun port line planking and the lap planking on the upper hull looks like on a Mary Rose build in 1/80 looks like. I have done it in admiralty style to show down thru the decks to the main gun deck. I have the main deck cross beams in boxwood and the smaller beams in swiss pear. The finishes are a Minwax oak for stain and Testors Dulcote to seal all the surfaces.
Keith
- Canute, mtaylor and Landlubber Mike
- 3
Ahoy Mates
I have been working on my Mary Rose now for about 3 years now,and will complete it in the next 3 weeks. I have a show to enter it in as a deadline. But there have been times when I was fed up with the build.
That's when I would find a small sub build for the Mary Rose that was different from what I had been working on to break the negative feelings that had built up from the stress of building.
You do two things,work on something different and make up and complete a new addition to the big build. And just look at it as a new small kit.
I often use rigging and yards as subjects for these little "kits" > There's lots of yards to make and plenty of blocks to seize .
Keith
Ahoy
NO ON THE BABY WIPES!!!!! They contain oils that would only damage your model. Try to find a museum with a qualified conservator and get second opinions before doing ANYTHING to your model. Take your time in finding out what to do. And first do an area that's not clearly visable,so that you can try out the cleaning process on a very small area,and then let it age for a while to see if there are any adverse aftereffects to what you have done in cleaning.
Take your time in researching out the information and those who can help you. Make sure they are documented people in cleaning artifacts.
Just remember that you want to do it the correct way the first time,and not to end up with something that's worse than what the condition is now.
I just wish I had this task to do now that I am retired.
Keith
- thibaultron, druxey, Canute and 1 other
- 4
Ahoy Newbie
Boy ,now you want to start out on two of the biggest models that there are? WRONG,do not go there. For your first build these are not even in the same universe that you are in now.
I would recomend the Model Shipways Gunboat Philadelphia 1/24 kit to start out with,and here's why:
First,the odds of you completing it are better than even,while the Surprise and Constitution completion odds are NONE!
Second_ It's a simple flat bottomed shaped hull with a bow and stern shape that you will be able to make and learn from.
Third- It's a large scale that will allow you plenty of room to work on the rigging but still have lots of things to learn and be succesfull at. That is VERY IMPORTANT for your first build. Learning and success without being so simple as to be boring,which this kit is not.
Fourth -Great kit and instructions and plans and not too expensive.
And most important-You will have fun building it because it will challenge you without defeating you!
Look up our building groups blog at www.woodenshipclass.blogspot.com and see back in time how our group built our Gunboats.
You have to crawl before you walk,and this kit will take you along in a very rewarding journey in starting out in ship model building. Do not by the first ship kit you like before you have the learned skills to finish it. I would say that maybe 99-95 % of all first wooden ship kits purchased NEVER GET FINISHED,and end up in disapontment and the fate of the closet top self until they are either sold at a garage sail or thrown out years later.
Keith
Ahoy Mates
Regarding wooden ship model contest's,who holds them and what are their rules?
As far as IPMS shows they used to be limited to only plastic models or some high percentage of plastic used in the model. The latest rules are stated as "material that is appropriate " which does not exempt wooden ship models.
Our local IPMS club changed their name from Oregon Historical Modelers Society to Oregon Modelers Society since their are now more car builders and other types of modelers in the club.
And I know that there are standards established for museums models.
Keith
Ahoy
Use whatever works best for you. Most of the time whatever you use other than wood to start out with gets painted 99% of the time anyway,and who cares what's under the paint.
And I have used wood, brass plastic and steel for wooden parts that I ended up painting to look like wood in the end. And the result was that if I did not tell what it was made of,all thought it was WOOD!
In our building group our founder and owner of the hobby shop could not stand that I was using evergreen plastic for parts on my wooden ships instead of brass. We argued about it,I said that since it was painted black ,that if I had not told him otherwise,he would have assumed that it was made out of brass and either painted or blackened.
After about 3 years and beating him in contest's for those years,he finally is quite about the subject.
It's your shipyard.
Keith
- CaptainSteve, Rick01, Canute and 3 others
- 6
Ahoy Mates
Just wanted to know what types of glues you use when rigging in black rope other than CA that will not "silver" when dried?
I have tried diluted PVA glues with a range of results. From being unseen when dry to being white-"silvered" air under the glue when it's dry.
I use Titebond for my Tan Syren rope with no problems,but the black is different for some reason unknown to me. Where the tan will take to the Titebond with little effort,the black doesn't want to hold onto the glue and dry the same as the tan.
What do you use,and how do you use it? And what should I be doing different for the black rope that is not the same as for the tan and light rope?
Thanks
Keith
- thibaultron and Canute
- 2
Ahoy Mates
When knotting ratlines,at what small scale do you just use an overhand knot in place of a clove hitch? This question just came up in our group meeting yesterday.
Would it be like smaller scales than 1/72? That's getting so small that it would be hard to see the difference.
If you have elves doing your building with tiny hands this question doesn't have to be asked. We are asking for the normal builder,not an OCD one who would do it down to 1/200 scale or smaller.
Thanks
Keith
Ahoy Mates
To start with I am a now retired tool and diemaker who has been using mills of all types for the last 50+ years. What advice I would give all about milling is that,since you are not having to do it for a job with time being a large factor- Take your time milling. Small cuts do two things: 1- it saves wear on your cutters which are costly to replace and 2 nd it reduces any deflection of either the cutting tool and reduces the over cutting of the mill cutter in your work piece.
The small milling machines are not built to handle deep cuts by the milling cutters. In size a standard Bridgeport milling machine handles cutters up to 1" dia. but even then they have a hard time with full cutter depth cutting.
If you kept the same size and capibility ratio of milling machine to cutter,the small mills would have only a cutter of 1/4" dia. with a cutting flute depth of only 1/8".
So take it easy.
And if you are burning wood,either your speed is too high,feed too fast clogging up the flutes of the cutters,or you have a cutter that doesn't have enough room for the chips created by you cutting speed and feed.
Mini mills EQUAL MINI CHIPS!!!
Keith
- hornet, WackoWolf, aviaamator and 9 others
- 12
God Bless you Chuck!
You know how to make my day. I am looking forward to building this kit after I finish up my Mary Rose. It will be great to be able to purchase the resin castings and then be able to carve and learn also.
This barge will fit in nice next to my Gunboat Philadelphia that's also in 1/24th scale. And my first build to use all of your rope and blocks in it's building.
Keith
Chuck
As for the laser cut parts for the carvings,will there be extra's included for those who have mistakes when shaping them? Or will you offer to sell set's of the laser cut parts that need to be carved?
I know that I would want at least an extra set so that I can use one to learn how to work the shapes out,and another for the finished model.
Please put me on a list for this kit.
Happy Customer from Troutdale,Oregon
Keith
Wood Ship Model Kit for Beginner
in Wood ship model kits
Ahoy Mate
What I would recomend is the Model Shipways kit of the Gunboat Philadelphia or another flat sided boat kit with a flat bottom .
It's a flat bottom hull with simple curved shape on bow and stern. !/24 scale,so it's not small,making it easier to work with. Basic building tasks can be learned on this ship without the problems of lots of hull planking. Covers the simple rigging. It has great instructions that go step by step. The Latina kits do this also,but their planking wood is crap and the hull shapes are not for a beginner.
A beginner needs to have success in building,and a typical shaped hull is not the way to start out. I have seen too many hulls with just a couple planks on them where the beginner stopped out of frustration . most of the planking on this kit is flat,the hull framework is great because of it being a flat bottom.and the wood in the kit is right for the beginner. Basswood.
This kit is a GREAT Starter kit,I would stay away from the other kits listed above,sorry guy's. Look at it from not knowing anything about building,then look at the wood type,hull shape,instructions,skills needed to make it. You need to crawl before you walk,and a flat bottomed kit in 1/24 scale meets this need.
I had not worked on a wooden ship kit since 1974 when I joined this group at our local hobby shop. I joined them when I saw that they were building this kit. I am so happy that I could start again on this kit because it allowed me to get back into wooden ship building.Even with all my skills,I could not see starting on a hull that needs intermediate skills to start out with.
But the kits listed there are more advanced than what a beginner should start with,and be able to complete without having problems. I have been building for 55 years now,a tool and diemaker and have passed on my building ways to our group. This kit was right for all of these guy's.
This kit can be built at the level you want. Our building group had 8 guy's,most had little or no wooden ship model skills and little ship modeling experience and they all got them completed. Check out our group's blog site at www.woodenshipclass.blogspot.com You can go back and see all of our builds in progress over the last 4 plus years.
Sorry if I have been blunt about this,but sometimes we tend to forget how basic a first build should be.
Keith
