Looking Absolutley Stunning - like a Museum model. OC.
- 355 replies
- vanguard models
- Sphinx
We should all do Hood kits - make it a megga group build - might have to wait a while for mine though, OC.
- 225 replies
- I Love Kit
- Hood
I love this image of her - many years later I have stood in the exact same position, watching the warships. OC.
I hear you Craig - although she looks unique in the water with her very low (and wet) rear deck, I think sometimes they can look kind of cut at the waist and missing something if they are not a full hull. Dont foreget her lower hull was dark Grey not Red. OC.
- 225 replies
- I Love Kit
- Hood
I am here as well watching with most interest mate - you doing a full hull or sea scape? OC.
- 225 replies
- I Love Kit
- Hood
I think its more enjoyable aslo to tackle a project like this is small slow stages, as its something to look forward to doing with each stage - guess it helps taking a small break to go off and do something else in between. OC.
Evening all, a little more work this evening - I added another aerial ontop of the bridge and a few other bits and pieces, then I dry fitted everything back in place to see how its looking - OC.
Thanks Scott - very true over the time frame, with the metal barrels I understand they are included in the kit as its the Delux edition. OC.
I chased this up today the seller (from china) told me there is a delay as they have not actually been made ready for distribution yet from Flyhawk, and there will be a wait (of unkown time frame) before it will be firstly sent to me then for it to arrive here, OC.
The little dance we all do on the floor "looking - looking again then re looking" I thought of the idea of using a magnet but wouldn't work with me - would stick to my leg due to the metalwork in it. You are doing a lovely job she is really standing out - lets all remember these are 1/700 kits very very small that makes a 6ft tall sailor just 2.5mm tall. OC.
Evening all, more progress on the Fortress - first I decided to see if I could build up the break waters, I had some PE frets left over and I discovered that some of the edging was roughly the right size - so I cut a length using my sharp blade this was then shaped against the plastic break waters then with tiny amount of CA applied with a fine bit of wire, I then pushed it in place, I then found some slightly narrower edging and the same idea then glued in place. After they had set I shaped them using my edge cutters, after I added a small amount of detailing behind the rear most break water. I then worked on the main mast with the PE I added a small platform and created a small aerial, then I had a go at the Two round radar domes very very luckily I found Two perfect round bits of left over something or other - perfect they were the right size and were duly glued in place. Starting to look a wee bit busier now. OC.
Thank you for explaining about those Ammo products - love the ones you use, they look so handy. OC.
- 127 replies
- Akitsushima
- Pit Road
- 127 replies
- Akitsushima
- Pit Road
Wonder if mine was different that I got to use on my challenger tank as soon as I opened the jar the smell was very obvious even the admiral could smell it from Twenty feet away - brushing it over the tanks surface was very smelly I almost had to stop due to the odour, the only thing I could do was to try to de gas it really quickly using the hairdryer. Certainly a shock compared to zero odour acrylics. OC.
- 127 replies
- Akitsushima
- Pit Road
I love that stuff but its too smelly to use in a lounge. OC.
- 127 replies
- Akitsushima
- Pit Road
Just found our a few things about the boat - she was the only one of her class to have the extended bow bulwarks, the reason for this was she was going to be trialed for the Phalanx system and it was going to be placed on her forecastle between her sea dart and 4.5in Kryton turret, but to make it less affected by the sea spray they built up the bulwarks and enlarged her break waters. So thats another job for me to do - extend her breakwaters. When we saw her it turned out we were very lucky to catch her as only a few months later she was sent off to be scrapped. OC.
Thank you Alan, she will never be perfect as there are too many issues with it - some of the PE aerials leave a lot to be desired, I had to imitate one with the thinnest plastic stock I could find and sand a bit, to get it level I drilled a small hole right through the base of the main mast, then pushed it through and glued it in place, then the secondary radar globes were missing so I had to scratch build something similar (will need shaping as long as they do not come un glued) There will be no PE handrails as I do not have any and when finished she will most likely be without many decals including her pennant number and name plaque on her hull. But I think she will be an improvement over how I built her - it was my first plastic ship kit since a teenager and first one I ever built in 1/700 scale and under not the best circumstances - light and lack of viewing aids apart from my glasses. OC.
