Posts posted by Old Collingwood
4 hours ago, Edwardkenway said:
I'm still here also!!
Glad your still looking on Edward - more to come on the build yet, since posting the above I have added the yaw vane and started to fit the stores shoulders/pylons.
OC.
- Egilman, popeye the sailor, Canute and 2 others
- 5
Amazing work - eye watering detail - hat off to you sir.
OC.
- Keith Black, Egilman, gjdale and 6 others
- 9
Welcome back to the pack, right straight in with the canopy - the glass unit needed fixing down to the frame after both had thier edges cleaning, then using a tooth pic ultra fine tip - I dipped the end in some revell pro glue and ran it along the frame and pressed the glass down, then I sat it in place just dry fitting - its a start.
OC.
Requires abit of adjusting to get the fit right no doubt - just apply the notion "test fit three times - cut once" just keep checking things before cutting material away - saves many tears latter (We have all been there)
OC.
- mtaylor, Ryland Craze and Canute
- 3
Hi all "Are you stil there", I am getting back on this very soon and giving my Waterloo figs a little break, I have sent off for some more Tamiya Surface Primer - waiting for it to arrive, in the mean time I will prep her ready for the primer, I will have to mask up the main sliding canopy then temp attach it down possilbly with some blue tack inside the glazing onto the top of the Bang Seat, then it will be a case of checking all over her before laying down the primer.
OC.
17 minutes ago, Canute said:
It's a treat, Denis. Pull the trigger, snap goes the hammer(this was a percussion cap style), one sec or so, bang and a cloud of sulfurous smoke envelopes you. We called 'em smoke sticks. And I think the French pronounce your name Denny. Of course, I could be full of soup, but what else is new, eh?
And dont foreget the deafening noise from the "Bang" I understand a famous word between troops was "Pardon" or "Whatttttt"
OC.
- mtaylor, marktiedens, Egilman and 8 others
- 11
Evening all, more work in progress will show after I have finished "Running Man", the admiral came up with a good idea - I should give them names after all my friends on here - wonder who could be who?
OC.
11 minutes ago, Canute said:
Have you started naming your "players"?
Yep, he is "Bluey" dont know why😛 I think next will be "Pinky" - only joking thought it more interesting to give them an identity.
OC.
Welcome back to Plastic Land mate, very interesting subject I used to have the UK eqv called a Raleigh Chopper.
OC.
- CDW, Edwardkenway, Egilman and 3 others
- 6
6 minutes ago, dragzz said:
Thank so much I will look in to that
No problem.
OC.
- mtaylor, Canute and popeye the sailor
- 3
13 hours ago, dragzz said:
oldcollingwood i looked at that site wow what a site iam not to sure where a can get all the pe parts for that the hood 27 sheets of pe parts lol
Yep its brilliant for info, check sites like Ebay or direct for makes like Lion Roar, Pontos, White Ensign, there are quite a few companies who do detail sets.
OC.
- popeye the sailor, mtaylor and Canute
- 3
22 minutes ago, dragzz said:
hello popeye not to sure about pe stuff and the wood deck will cost me 125.oo in canada thats a bit much for me i will try and get as much pe as i can for it
hello thank you for following my build log nirvana
old collingwood welcome to my build log and yes i will look into the link for mods thank vary much
No problem at all.
OC.
- 3
3 minutes ago, VTHokiEE said:
Thanks! I have been looking at pictures of cannons this evening and they did all appear to be pushed right up tight. It’s good to have some confirmation to my research.
This is an interesting idea that I may play around with and see which I prefer. Thanks again!
No problem at all - glad to help if I can.🙂
OC.
- VTHokiEE and Edwardkenway
- 2
Excellent work - really taking shape with all those frames, should be built in no time with that giant building her😉
OC.
- mtaylor, Kevin, Edwardkenway and 1 other
- 4
5 hours ago, VTHokiEE said:
I prepared one cannon and decided that one of my side tackles is a little longer than I want going forward (the visible tackle is the long one). Should the cannon trucks be right up against the bulwa rk? This isn't glued in yet.
Edit: Currently redoing the longer tackle, it bothered me too much already 😂I think they push them right against the bulkhead for maximum recoil so the cannon works at it best, if you wanted to show some life on her, you could also display a few recoiled back with tight ropes.
Spledid work you are doing everything looks the part.
OC.
Thought you might find this useful as it shows different mods to improve the kit - gonna be an epic build.
http://www.hmshood.com/hoodtoday/models/trumpeter/trumpeter200.htm
OC.
- Canute, mtaylor, popeye the sailor and 1 other
- 4
1 hour ago, Kevin said:
I think that is his scribblings about a mass party for us all at his place - the writting is the menu for all the food goodies we will get😜
OC.
- Canute, mtaylor, popeye the sailor and 3 others
- 6
8 hours ago, lmagna said:
I have always been a B-17 guy but the B-24 was considered the faster of the two planes. In most other ways they were similar and the people who used them seemed to prefer them over the B-17 in most ways.
I have the Osprey in my collection as well Denis. I have always liked them in spite of their early reputation and problems. We have a few around here and one thing is certain, you know it when one flies over................. They are LOUD.
Start a build Lou - would love to see it.
OC.
"Wowzer" you have some nice stuff to keep us glued, the B24s always looked to heavy to fly to me, and the B25 - I am sure my dad used to speak about them when they were over this side of the wet stuff, and the Osprey - what an amazing Heliplane/Planecopter - I have seen a few at shows and even the one over the top of us.
Got my camping gear out ready for these.
OC.
Sea Harrier FRS.1 by Old Collingwood - FINISHED - Kinetic - 1/48
in Non-ship/categorised builds
I have been thinking about doing her as ex falkland vet XZ-439/2, the reason behind this particular frame is - in 1982 just after the falklands war my late farther saw an add in the paper talking about an airshow at Farnborough where some ex falklands harriers were due to be there, anyway after soom pleading by me, my farther took me to the show and I got to see the Sea Harriers display there, one of them there was indeed XZ-439/2.
Here are a couple of pics showing her at the show (the lighter grey one)
Pics not mine they are off the net.
OC.
