Posts posted by Old Collingwood
Is 47 decibels very loud for a sprayers compressor? could you use something of that noise level in a sitting room without it causing disruption to normal tv watching?
OC.
- Canute, popeye the sailor and mtaylor
3
32 minutes ago, Egilman said:
Interesting comparison of size with the previous benchmark destroyers the type 42s with the Fortress of the Seas HMS Edinburgh (my fave modern warship) - the middle of the Two on the left.
OC.
- popeye the sailor, Canute, mtaylor and 1 other
4
Just some bits and pieces from my memory of these family of ships from seeing them come and go where we used to live - they appeared to be a very good ship regarding little role when cornering compared to say the type 42 destroyers, also what I found strange was that the middle anchor always used to partialy lowered when entering harbour (I used to see that with all same fleet) never found out why, also thier tanoy system was very loud often when they were moored in a streatch of water we could hear the tanoys from more than a mile away.
Just a bit of trivia from my own memories.
OC.
- Waitoa, marktiedens, GrandpaPhil and 7 others
10
Superb work on that Mill.
OC.
1 hour ago, Landlubber Mike said:
Coming along nicely OC! Looks like it will be a nice sized model.
Thanks Mike, its paused for a bit ran out of spray paint.
OC.
- Landlubber Mike, Canute, lmagna and 3 others
6
You are doing fine mate "gently gently" is the key.
OC.
- mtaylor, Canute and Edwardkenway
3
Dont know why the kit makers have to split the heli deck like that 2/3rd along the heli pad - they could have made it all one deck (its the same with many modern warship kits like that in different scales).
OC.
- Canute, Egilman, popeye the sailor and 2 others
5
Looking excellent.
OC.
- lmagna, mtaylor, Edwardkenway and 5 others
8
Absolutley amazing considering it 1/350 scale thats the same scale as the moden warship builds in the forum - and we know how fiddly they are.
OC.
- Kevin, Edwardkenway, Canute and 6 others
9
Really nice Job Denis, paints certainly do test us - but you pulled it off nicely.
OC.
- Egilman, Canute, popeye the sailor and 4 others
7
1 hour ago, CW_Tom said:
It looks great. I’d never heard of card models before until I came here.
Not much that doesn't go on here - if they make it - we will build it.
OC.
- CW_Tom, ccoyle, Edwardkenway and 6 others
9
- Edwardkenway, Waitoa, marktiedens and 7 others
10
Very tidy work mate - you got those tree nails perfect not in your face just nice and accurate.
OC.
- marktiedens, mort stoll, md1400cs and 2 others
5
That is looking really nice - I too love the lines of the ship, we all panic over the first hull planking - thinking it looks rubbish - "boy I did with my Greyhound" but sanding is our friend.
OC.
- RdK, J11, Louie da fly and 2 others
5
Bit of progress (sort of) I took the wokka outside got the outdoor bench set up again with a box to put it on, got my rattle can RAF Green then after a warm up and thorough shake, I started spraying.................ups................splirt splirt got half the wokka done then it ran out😬
So as it stands its put away de gasing in the cupboard keeping the smell locked away, will have to wait now till the new year before I can finish it.
Oh well I have my Waterloo figures to keep me out of trouble.
OC.
1 hour ago, popeye the sailor said:
looking really good OC..........you've made quite a bit of progress
Thanks mate, they say the primer is the "Tell tail" as it shows up everything.
OC.
- mtaylor, Edwardkenway, lmagna and 3 others
6
Evening all, right Primer day - it was a bit fiddly as it had be done outside, the idea was to sit it on a box ontop of our covered deck bench, then spray what I could while walking around the wokka, then left it a few minutes to dry till I could pick it up and place it down so I could spray the underside, only issue I had was a bit of a run near the winch - I left it to dry for a few moments then rushed it inside still on the box and straight into our cupbaord.
This evening I was able to check it out and give the run a light wet and dry - problem solved.
OC.
Great work Kevin, do the bricks strengthen the assemblies up much - give them some rigidity?
OC.
- EJ_L, popeye the sailor, lmagna and 5 others
8
8 minutes ago, mtaylor said:
I'm not sure that the intake filters were ever powered on choppers. Most of the ones I've seen take the incoming air and 'cyclone' (for lack of a better word). The realitively clean air goes into the engine and the dust and debris goes out he side/top/bottom of the filter. Many different designs depending on the engine.
Thanks Mark.
OC.
- mtaylor, popeye the sailor, Canute and 1 other
4
Fokker Dr.I by popeye the sailor - FINISHED - Revell - 1:28 scale - PLASTIC
in Non-ship/categorised builds
Whats next in your plastic stash mate?
OC.
