Old Collingwood
  1. Evening all, I did abit more today concentrating on the U/C units these are built up in stages with painting and weathering in layers, I have been able to glue them in place letting them set before I work on the outrigger units - then it can be sat on its wheels. The main u/c doors were changed onboard Hermes as they had an issue with original ones (hence the colour shade difference)😉 # just noticed the front u/c small door has moved and will need re gluing.🤨 OC.
  2. I think there are always some minor injuries - but dont think anything major, I always wanted to be an ECW reinactor but travel and things stopped it. OC.
  3. I was at that actual event with my late farther - he took me when I was about 7 or 8 - I was blown away by all the colour / smell and noise. OC.
  4. I was tempted to do a diorama on the English Cival War from the 1600's (May still one day) Centered around this - OC. Warwick castle-2.mp4
  5. Thank you kindly Ken, it took me nearly all day to do. OC.
  6. Evening all, Sidewinder Time - these come in seperate sections - body / Two piece tail fins and seperate front fins, then several layers of paint and a couple armd marks, then it was attached to the rail - it still needs the pre-rail painting. OC.
  7. Evening all, more progress with SHAR - I decided to wortk on the Pitot Tube and nose cone, firstly the kit one is able to be improved with the addition of a brass Masters tube, but first I had to cut off the plastic one where it is joined to the fuselage frame, then it was a case of sanding the front part flat - and with a very very very fine drill I made a small hole in the end (not very easy) I managed to do this (just) then the brass tube's end (protrution) was glued into the hole with ca, this was left on one side while I worked on the nose cone. The nose cone needed some shaping as the fuselage at the very end is not a purfect circle, so I sanded the edges where it needed flating slightly, then I maked with a pencil inside for the T.D.C alignment, then I applied a few coats of Black/Grey and after a few coats of top coat, then when dry it was lined up and glued in place, still needs some work to tidy up and a bit of paint on the tube. OC.
  8. Looking excellent also looks strong (you would have thought delicate at this stage) with the Three stringers I would have said they were there also to show the the line of planks like what we do with string or paper strips to show how the flow of the planks. OC.
  9. Excellent work - especially considering the scale. OC.
  10. Count me in, I have seen the RN one at Yeovilton Museum, looking forward to this one. OC.
  11. Im back again - next up was the rear jet pipe exhausts - these get very hot so they soon show a burned metal finish, I mixed up a mixuture off Brass and flat Black and gave then a couple of coats, next came the fuselage heat shields - thease again tended to get very hot and show a burned metal look. After these had dried I applied a few coats of top coat then they were glued in place - next was the placing of the 190gal drop tanks on thier inner pylons. Its getting there. OC.
  12. My procedure for my decals was to apply micro set to surface first, then position the decal and using a cotton bud smooth out the decal, then when set I applied a good few coats over the top with micro sol, with the tail decal it settled down even let the panel lines show through - but the silvering between the decals on the decal is showing the decal not pulling it down (its all down to me not applying a gloss coat before the decals) OC.
  13. Thank you kindly Mike, Yep thats what I have been doing but will continue , the tail has had about Ten coats of Matt Acrylic Callejo top coat so far, but I can keep adding more. OC.
  14. Good day all, I have been pushing on with the varnishing with my brush - its not going too bad, the main culprit being the Royal Navy decals on the tail, its not fully blendid into the paint surface but it will do, I have also been concentrating on creating the SHARS tell tail rear dirty shiny rear lower from the heat from the rear jet pipes. So without delay here are some pics - OC.
  15. Evening all, more progress this evening - after applying the serial codes to the bottom of the tail, I then settled it down with micro sol, and when I was sure it was set I then rubbed some pancil into the rear lower part of the frame to represent staining from the Hot rear jet pipes, after I started work brushing on my Vallejo Acrylic Varnish, my method for doing this was to work in controled areas and dry between coats. Working over the decals was/is taking its time as its needing several coats to hide/blend the silvering on the decals - it is working just slowly and some are more stubborn than the rest. I will put some pics up when I am happy with the result. OC.
  16. That is looking so nice - this is not an exaggeration, you have improved even over what the company themselves could do. OC.
  17. Thanks Kevin, yep I have always loved Harrier displays and thier low level speed - very underated, was watching some vids last night of them 700mph at almost ground level - loverly jubbly. OC.
  18. Evening all, decals are on, just need to wait a few days for them to fully settle down - then I will dirty the back end abit with pencil gently rubbed over, then I will brush paint my Vallejo Matt Acrylic Varnish, it shouldn't look bad as the lighter paint finish was applied by brush out in the Atlantic on HMS Hermes by the crew. This will (hopefully) seal in the decals and blend them in so I can handle it for the other bits and pieces. OC,
