Old Collingwood
  1. Oh! I foregot to mention - the bowsprit is the kit plastic one, but I strengthened it by fitting some dowel inside - this made quite a difference. OC.
  2. I think I sorted it - I re did it with thicker thread a kind of waxed one that came with the kit (I did not think about using it as it is a buff color) anyway I managed to get each winding to sit next to each, then just did a simple knot and glued under the grating (out of sight) the ends, then I gave it a coat of black/grey type thingyy. OC.
  3. Good Evening all, can I get a bit of advice from folks please - I am struggling with the gammoning rope trying to get a neat inline pattern, I have to run the rope (thread) up from the cutout in the beakhead then up through a slot in the grating and over the bowsprit, I have fitted a block on the top of the bowsprit but I can stop the thread from getting all bunched up and not in a nice clean line. Are there any cheats to make this (stressful job) easier? OC.
  4. Its a fictious ship but im building it just as the wife wants it - as it is in the films, (makes it a lot easier for me that way)😉 OC.
  5. Its just the way the film designers built the ship probably desined around the May Pole dance. OC.
  6. Really impressive work on the masts - how do you hide the ends of your mast rope wrap arounds? OC.
  7. I know - strange arrangement no mainmast bits either. OC.
  8. Evening all, I continued with the forecastle bits - they were painted then weathered, I then got my instructions off the admiral that she wanted the capstan to have its spindles - so hey presto I made it so - painted and weathered. After letting the capstan dry I turned my attention back to the forecastle - it ocured to me that the inner railing was missing some belaying pins, I have some metal ones so I had to drill out the rail between posts then glue in the pins with some gaitor glue. Just a couple of pics -
  9. Evening all, only a lttle bit of work today on the pearl - firstly I built/painted and weathered the capstan then glued it down, then I started work on the kit forecastle bits, the kit part is a complete piece - all it needed was a bit of cleaning up then a piece of decking was placed underneath to help its attachment to the deck. Just the two pics - OC.
  10. Late nights mate as I watch over the wife (just our way). OC.
  11. Hiya mate, yep slightly darker but deffo showing some weathering, its a very enjoyable build and the scale 1/72 really helps - I used to make 1/72 scale Airfix toy soldiers - you know the ones that were that horrible slimmy plastic (real hard to paint) I at one stage had hundreads of then including the Battle of Waterloo battle set - had then all over the room floor ( mum was not impresed) OC.
  12. Oh - I foregot to mention - the upper sides are not glued on yet, just dry fitted to test weathering and fit. OC.
  13. Really cant go wrong with a build, be it either wood or plastic - or even a combination of both, its only limited by our imagination, the skill part comes along with practice (I think). OC.
  14. Looking good with the extra details - no problem with the name of the wriggles. OC.
  15. Yep there called wriggles, they were in two shapes - one more pointed in the center and the other more flat on the top with rounded corners. OC.
  16. Evening all so today was "weathering/shading day" - I gave the hull and upper hull parts a series of dry brush white passes, basically just white acrylic with a large brush with almost all of tha paint taken off the brush with a rag, than brushed all over raising the highlights and creating some age. Here's the pics - OC.
  17. Evening all, today I fitted the two forecastle ladders then gave them a coat of paint, I then decided to close in the lower/main gun deck hull sides, this was a fiddly operation requiring some moving around of the side sectons to get them to sit properly, this caused a bit of poly cement mess around the join. After the first side was glued and supported with elastc bands - I was able to attach the other side, I set the hull aside to set while I cooked dinner - then I touched up hull join line, but also decided to give all hull parts a second coat - that to be honest is a more brown/grey/black color, but it will be weathered again with dry brushing (can use talk as the wife has allergies to stuff like that) Just the one pic - OC.
