rpeteru
Everything posted by rpeteru
  1. Recently got back into card modelling. Currently am doing SMS Friederich De Grosse, Have done Motor ship Sibajak Have the two Australian river steamers in my stash. Been awhile since I posted
  2. Have done this model in card by Scaldis to a scale of 1:250 long time ago.
  3. Why not enquire with the manufacturer Artsania Latina They should have it on file.
  4. There are youtube videos on this particular vessel.
  5. This vessel is powered by Two MAN K9Z 78/140D. The 9 refers to the cylinder count and the 78/140 refer to Bore and stroke respectively,780 mm bore and 140 =1400mm stroke. In my earlier days I spent a lot of time with this engines smaller brethren. Mainly K8Z 57/80C.
  6. Forgot to mention also many an hour on the throttles of the starboard Quadripple expansion engine as fitted in HMAS Diamantina. All manually operated in the days before Dynamic positioning systems. The term we used was manu-matic.
  7. Came across the SD14 Kit when I was an Instructor at the Australian maritime college in the 90.s. Was trying to angle to get in on the build, alas one of the Naval architects had beat me too it. When built was use as an instructional tool for all Marine classes.
  8. Actually in this country wine is sold in carboard boxes hence the expression of "Chateau cardbord" when dealing with your favourite tipple.
  9. Funnel walk ways would have been used by stokers to put the funnel covers on when the boilers that the particular funnel serviced were shut down. The reason for the covers was to prevent outside moisture from dripping down inside the funnel and mixing with the remaining residual soot. The boilers burnt FFO or furnace fuel oil which has a heavy Sulphur content. This Sulphur content in the soot when mixed with any water would produce a mild sulphuric acid which would attack the exposed external boiler piping. The removal of soot build up would normally be carried out with a soot blow, but only with permission depending on direction of travel and prevalling wind conditions. That crowd on the bridge did not like to be covered in soot, especially during daylight hours, so we would blow soot just after dark and before dawn. It was also very nice to sometimes see this crowd annoyed especially if they were wearing tropical whites. Pay back can be a b**ch. Some times it just happens only following the Engineer's orders. Daily soot blows would not remove all the accumulated soot, this would be done during the self maintenance period and be termed a boiler wash down. External panels removed and hidden and ingrained soot externally washed out using a high pressure wash. Once this has been completed tubing where it enters or leaves a steam/water drum could be inspected, for erosion, corrosion, caustic embritlement, necking or deformation of the piping.
  10. Gents I think the expression is "Chateau Carboard"
  11. Querry where did you get the mug? I want one. Being an ex Marine Engineer.
  12. Depending on where you are there is also the chance some individual has use the tree for target practice. Have seen many clips of people milling local timber only to find lead pellets or shot in the felled trunk.
  13. Simply stunning mate gives me thought to finish my Grosser Kurfurst. Picked upa PE set including nets from one of the US Pe manufacturers about 3 years ago. Could not figure out how to do the blocks on the boom ends. Your build log has given me ideas,
  14. A similar parallel can be used for the term that of sacking a city. It does not convey an impressing image. But when you actually see the aftermath it does become sobering. In my case viewing the destruction that the Burmese inflicted on the ancient Thai capital of Ayuthia, 60 miles north of Bangkok
  15. Did many an hour or watch on Admiralty 3 drum boilers. Circa 1967-1974.
  16. Er vossiewulf I do not think the Japanese attacked Darwin in 1904 maybe 1942. The port you should refer to is Port Arthur, i think that was the name of the Russian base on the peninsula.
  17. This sort of artistry is really take your breath away stuff. Can only say Awesome
  18. Love what your doing so far. By the way the way what are those stands you use. Are they Home made or a commercial product? It looks like you can place your hull in any position to be able to work on it.
  19. I concur even though my service was with a different navy, I thank all servicemen who served because they believed in their country's cause. Thank you for your service.
  20. Are any of you aware that you can get Card models of two Australian Paddle steamers, The "Pevensey" and the "Alexander Arbuthnot" Both are in 1"100 scale and available from WORLD OF PAPERSHIPS Tm which is a Dutch publisher. No affiliation just a satisfied customer. The Pevensey will build into a model measuring some 335 mm or about 14 inches long. The other slightly smaller 230 mm. The "Adelaide" is also available. Both my copies were picked up from a Melbourne based Hobby shop. Just hope this post is legal?
  21. A lot of this stuff mentioned also applies to both Copper and Aluminium (Australian Spelling) Both will work harden with repeated bending. Copper does require annealing for it to be made soft, I suppose Al does as well. personally I have not done this.
  22. From the last painting it seems to be very similar to the card model that was used as a demonstration by CC Coyle in his V108 build.
  23. Many people might dismiss Manfred Zu Mondfeld in Historic Ship Models but on Page 278/279 he does show how tackle was used to load/unload various items, the one illustrated being casks.
  24. In my case my old ship HMAS Diamantina is now preserved as a maritime museum vessel in Brisbane Australia. Her greatest claim to fame, was to accept the Japanese surrender on Nauru Island. She was also at the time of her decommissioning the last Australian built ship during WW II. She no longer has the shape as I remember her. Having been retrofitted to be depicted as she was during her war time service. I do not know if HMAS Castlemaine also a museum ship is older. moot point. Tina was longer in commission. Correction to this post as I have not mentioned class or designation. Were as follows Class = River class. designation = Frigate. Sometimes the record just has to be set straight.
