Everything posted by Tankerman
	Master Korbel- Brigantine Phoenix (Plus Edition) £180 plus p&p. Master Korbel - Schooner Polotsk (Plus Edition) £160 plus p&p. I do not have the time or display space that these kits deserve and would like them to go to a model maker who can do them full justice. Both kits contain the full sewn sail set, are new and untouched internally. I will post them tracked and insured. PM me if you are interested or want further information.
	This is a Model Trailways kit. After following this build log I was very interested in attempting the model myself: The kit retailed at £450 in the UK which was more than I was prepared to pay but in the New Year Sale at Model Expo earlier this year it was on offer for $200. Even with shipping and import duty it was still a substantial saving so I bought it. I always expect a lot of hard work where white metal is concerned ( unless it is a Model Factory Hiro 1/12th. car kit ) and sure enough I was not disappointed. The moulds were obviously reaching the end of their useful life and I spent many hours grinding and filing away excess metal, not just flash but huge lumps. In other places areas where the cast was missing I built up with low-melt solder and then filed back to shape. Although I was very pleased with the end result I thought a team of horses would set it off nicely, I could not find any photos to tell me if it was a 2 horse or 4 horse team. I went for the 2 horse team as the overall length would fit in the display case I had.
	Deluxe Materials "Glue 'n' Glaze" is the product I have found that is better than PVA glue for glazing windows and portlights. It is similar in consistency but seems to give a better appearance.
				48th Scale imperial rulers. Where?
Tankerman replied to John Murray's topic in Modeling tools and Workshop Equipment
This may be of help: https://www.blundellharling.com/product/imperial-academy-architects-triangular-scale-rule-12-300mm/ Good luck -
				Air Compresser
Tankerman replied to Guyuti's topic in Painting, finishing and weathering products and techniques
I can thoroughly recommend this compressor from a totally reliable specialist supplier. It is very well constructed, quiet and very reliable. I have had a Sparmax compressor for many years and would not consider anything else. https://www.everythingairbrush.com/product/sparmax-professional-mini-piston-airbrush-compressor-2-5-litre-air-tank/ Chris -
				Waterslide Decal Paper
Tankerman replied to hof00's topic in Painting, finishing and weathering products and techniques
Very much by trial and error wefalck, I was lucky that the red on the truck was a good match. Chris -
I have used this method on several of my models and show two examples below: The T2 tanker is the very old Revell kit at around 1/450th. scale and I wanted to show it as one of the many T2s owned by the company I sailed with. The company logo was downloaded form the web. The "Caltex Glasgow" and port of registry in the correct font and size ( less than 2mm in this case } were added to the file over a black background. The file was then printed on to a white decal waterslide transfer paper by 'Experts Choice' using a domestic inkjet printer. Once the ink was dry the sheet was sprayed with a clear acrylic varnish to seal it, after which the images were carefully cut from the sheet and applied to the model. The tractor unit is a conversion of the standard AMT 1/25th. kit of the White Freightliner to represent the ones operated by Carolina Freight. The logo on the door is a commercially available decal but the fleet name on the roof deflector and front bumper, the fleet number and legal lettering are generated in a 'pages' file on a Mac to the correct size and font, given a red background and printed off on white decal paper. The red print colour matched the red paint I used on the cab. I hope this helps you HOF. -
	Having bought a jar of this to try I wouldn't be without it now, such a versatile glue. Not only the windows but all the PE and resin decoration on the stern of my Sphinx are securely attached with it.
- 505 replies
- vanguard models
 - Sphinx
	Here you are: https://www.abebooks.co.uk/servlet/BookDetailsPL?bi=30549031522&searchurl=an%3Dwilliam%2Bmowll%26fe%3Don%26sortby%3D17%26tn%3Dss%2Bgreat%2Bbritain%2Bthe%2Bmodel%2Bship&cm_sp=snippet-_-srp1-_-title1
	Just before I read your post I had been fitting my interpretation of the frieze decoration to my model of H.M.S Sphinx. Reading from various sources about ship decoration during the Georgian period I was not convinced that a small 20 gun frigate would have had that much gold gilt work and the frieze was more likely to have been painted in yellow or ochre paint if indeed it was decorated at all. As I wanted to include all the exquisite etched brass pattern that Chris W. has provided I decided to use a white primer followed by a coat of light yellow acrylic colour by Vallejo. When dry this was then coated in Humbrol Clear gloss varnish. The detail on the etch is then highlighted with a wash of Seraphim Sepia from the Citadel range of washes called "Shades". The photo shows the fitting of the first row of decoration on my model and I am very happy with the result. Over the next couple of days I will apply the the rest of the decoration. I hope this gives you some idea of the possible alternatives. Chris
				kit review 1/72 Brockley Combe, 1938 Cargo Ship - Navarino Models
Tankerman replied to James H's topic in REVIEWS: Model kits
The hull bulkheads of the kit would require a lot of modification in order to fit a motor and stern shaft, as well as space for batteries and associated radio gear, keeping in mind that some access is required for maintenance. The photos show my scratch built hull frame for the motor collier, the M.V. Ballyloran. This is a 1/48th. scale model but the principles are the same and you will see that the motor bedplate and stern tube are fitted at this early stage to ensure an accurate alignment. Should you decide to build the M.V. Brockley Coombe I would recommend a book "British Motor Coasters" by Charles V. Waine which is a very complete history of this type of vessel and where you will find a General Arrangement drawing of M.V. Brockley Coombe and photographs.- 6 replies
- brockley combe
 - navarino models
	I agree, my reading and research on the subject means I have reached the same conclusion as you. Chris
- 857 replies
- Sphinx
 - Vanguard Models
	B.E. this book would add more interest in your search for the colour "blue": http://modellbau-muellerschoen.de/Shop-en.htm?fbclid=IwAR1Z1MSLyl5JG6KSoLfZbK_vKumG63wh8itcYxOTGQZ_YBbbTgHVB6Z6zyw but at a price! Chris
- 857 replies
- Sphinx
 - Vanguard Models
	I second that Malcolm, it is a great testament to the hard work that Chris and James have put in to the development of this kit and I'm looking forward to the arrival on my doorstep of a big box from The Forest of Dean in the next week or so. Long live Vanguard Models. Chris
- 355 replies
- vanguard models
 - Sphinx
	This is my most recent plastic kit, the Revell 1/400 "Queen Mary 2" with a Gold Medal Models photo-etch upgrade set and a KA wooden deck set.
	There is a short section on the Enterprize Class Frigates in Conway's "The First Frigates" by Robert Gardiner containing a list of the vessels in the Enterprize Class and three profile draughts. Chris
- 312 replies
- enterprise
 - caf
				ancre Coureur by cafmodel - 1/48
Tankerman replied to cafmodel's topic in - Build logs for subjects built 1751 - 1800
I am nowhere near ready to start construction of this kit yet but have been studying the instructions, plans and components from the two boxes. The photo shows one of the many frame component sheets and you can see engraved lines on the frame components that require fairing. My assumption is that each clinker step will need to be filed to the line to achieve fairing - a lengthy but necessary process. Hoping this answers your question ASAT. Chris -
	Parts E1 and E2 were missing from Box 1 but also sheet 2E from Box 2 when I received my kit. I informed Tom last week and received the replacement parts yesterday. No complaints from me about CAF Model's after sales service. Chris
