KenW
Posts posted by KenW
  1. I’ve added the main topmast and main topsail yard with its sail.  The area of this sail is really large, even larger than the main course on my model.  I’m starting to wonder if I should be making the sails to be full size.  I thought that the sails on my last model, which were half size, were too small; now I’m thinking these may be too big.  No turning back now, however.  My sail plan is a cross between David Anscherl’s and the kit’s plan drawn up by George Campbell based on Harold Hahn’s plans.  My decisions are based on what I feel looks and/or seems right.  Most of the lines are still not tied off.  I’m waiting until the top gallant lines are all in place.  Now I’m off on a 12 day vacation, so the shipyard will be quiet for a while.
  2. The mizzen mast is fully rigged.  It involved adding the topsail yard and sail.  All the lines had to be tied down while not interfering with the lines going to the small pin rail that I added for the spanker brails.  Everything looks good at this point.  There are still a couple of ‘empty’ pins, but they will be used later for various braces. I learned on my last build that braces are best left to last.  So now it is on to the main mast.
    2017_03_17_02.jpg.5da7f780fced7162f3fa07cf84f11b0b.jpg        2017_03_17_03.jpg.3c03daafb833ad163b61c6fd4bbf7a08.jpg
  3. The crowsfeet weren’t as hard as I thought.  The hardest part was making the euphroes.  I don’t have a power drill, other than my Dremel.  I made the euphroes with my hand held drill.  I used a 1/8 x 1/16 strip and used my xacto to make a score down the middle of the 1/8 side.  The score helped keep the holes lined up, and just used my awl to mark where the holes should be.  After the holes were drilled, I used a sanding stick to get the width and thickness down to where it should be.  The crowsfeet line I used was that recommended by Antscherl.  The line was fly fishing line with a weight of 6/0, and it’s very thin.  It was hard to capture on camera.
  4. The mizzen ‘spanker’ has been bent and the gaff crossed after many mistakes.  But with some perseverance the task was completed.  The ‘spanker’ was brailed which required a total of six lines that needed to be tied off.  I previously added a small pin rack holding 4 belaying pins on each side and used three per side for the brails.  The remaining one will be used later. I actually have a rigging plan that will use the MSW kit’s plans, with expansions to account for the ‘extra’ lines I need to show the furled sails.  Anyway, it’s on to the dreaded crowsfeet.
  5. Congratulations!!  Your model looks great.
    Don't worry about how long it takes - this is a hobby right.  As 'russ' states, "Tain't a hobby of you hurry".
    Where did you get the case?  In particular the plexiglass plates.  I can't get 1/8th inch thick; they tell me that it is too thin.
    Anyway, great job and enjoy your effort.
    Cheers.
