Posts posted by Maury S
Danny,
I started the cutter, and get back to it when ever I come to a stopping point on the Echo Section. It's small, so when I'm in the mountains I can take it with me. Not power tools necessary. I'm sure you'll have yours completed by the time I turn around. That will help me a great deal when it comes time to get the frames in.
Maury
So sorry about Sadie.
Maury
- Ol' Pine Tar, GuntherMT, Rustyj and 8 others
- 11
Laying out the planks below the wales. I used tick strips every other bulkhead starting from deadflat and ran a batten at the mid points (10 planks down) from stem to where the square tuck joins the stern. That seems the most critical alignment of the planks. Since it was fair, I marked all the bulkheads with a dark line. Same exercise on the other side.
Maury
- mtaylor, Stuntflyer, Chuck and 9 others
- 12
The wales have been installed on the starboard side. The pieces were cut to size, tapered at the bow and cut to fit the shape of the fashion piece at the stern. These went on much easier than the original planks. A little sanding, then I'll put a coat of sanding sealer and start painting them.
Maury
- GuntherMT, Ol' Pine Tar, Chuck and 9 others
- 12
Using Chuck's bulkhead kit keeps everything lined up nicely. I had quite a few adjustments to make by cutting them myself...particularly at the stern. Looking good.
Maury
- Canute, Stuntflyer and Chuck
- 3
In real life, the spaces between the frames would have been filled-in. Those pieces are not included in the plans provided.
Maury
The counter took some edge bending as well as the gentle bend of the stern and came out well. Edge bending is still something I'm getting comfortable with...the inside of a bend seems to bend a bit sharply in the center rather than a gentle sweeping curve. I even place two clamps in the middle of the plank to widen the curve. Trial and error. The transom edge bending is less severe and went on well. I did the lower strake pieces first, then moved to the solid plank above the gun ports and then filled-in the rest. Next up are the fashion pieces covering the edges of the counter and transom. Question for Chuck...The planking over the square tuck is vertical on the plans and in your build log, but seems horizontal in the pictures with the instructions. I seem to recall more discussion about the vertical planking and the surround on the build log at the time, but that does not appear now.
Maury
- Dubz, Jack12477, Ryland Craze and 11 others
- 14
More planking. I started using CA on the planking and things went much faster. The next step is to make sure the tops of the frames are fair and match from side to side. Tops of gun port verticals need to be sanded off. Square tops of the frames get faired. This will give me a place to measure the width of the next two planks up to the shear.
Maury
- Mirabell61, Jack12477, mtaylor and 10 others
- 13
- lb0190, Ol' Pine Tar, qwerty2008 and 1 other
- 4
I bent the stbd side piece and over did it a bit. Easy to correct. Just learning to make those little adjustments that only come with experience. Chuck, the strake above the molding is broken up by the gun ports. Do you bend a full-length piece to a fair run before you cut it in small segments or bend the pieces separately? I'm not there yet, just asking.
Maury
Thanks Chuck. First attempt at edge bending. Learning curve!
Maury
Completion of the first strake above the wale on the port side. This involved edge-bending the long center plank so I tried Chuck's clamping and heating method. It did not hold much of the bend after 5 minutes with the blow dryer on high. I repeated and let it set for an hour...not much difference, but enough that I did not have to force it too much. I clamped it both against each bulkhead, and also against the wale. The aft-end part of the strake is too short to do much bending so I mark the width and used a ships curve to to get a mild curve to match the run of the wale. It fit perfectly. By the way, after marking the width at each bulkhead and drawing a fair line, I clamp it in the vise and use a very sharp 1" chisel to cut close to the line and finish it off with 100 grit and 150 grit sanding sticks.
Maury
- IgorSky, UpstateNY, Mirabell61 and 4 others
- 7
Cutter for HMS Vulture by Dan Vadas - FINISHED
Here is the link to my cutter. Clinker planking was new for me. David's suggestion was to plank without frames on the plug and add them later.
Maury
http://modelshipworld.com/index.php/topic/7678-18-cutter-by-maurys-scale-148-small/?hl=%2Bcutter+%2Bmaury
