Posts posted by kpnuts
Hi all Airfix missed a gun port on this so I've been racking my brains trying to think of a way of making one and I think I've got it.first I covered on of them with bathroom sealant to make a mould then I tried to make a resin casting but it was so thin they kept breaking when I tried to get them out, so I thought I need something more flexible so being as how it was so thin I thought just acrylic paint, but that was too flexible and wouldnt come out of the mould so then I thought How can I stiffen it up a bit so I put a thin smear of superglue over it, hey presto it came out, here is the result, I may make another mould and try again as this is a bit chunky probably because of the number of times ive tried using it but at least I know it works.
Hi all well shes back to her former self Jan he bought it so yep its going back(lets see if he breaks it again, I may have to charge next time)
Hi all well got the leds working again (the stern mast PE arial has been snapped off the trouble is I've binned the instructions so don't know which way round it goes, any help out there?)
- cog, Captain Poison, GrandpaPhil and 2 others
- 5
Hi all well I got this back from the library and thought I would take it to the Norex Hobby Show Exhibition on the 25th
needs a bit of work though, one of the Ju's is off its plinth the sea looks very dusty the explosions from her guns seem to have drooped a bit and several of the led explosions no longer work.
- mtaylor, cog, popeye the sailor and 1 other
- 4
Hi all a little update, well after exhaustive research(20 mins on google pooped for the rest of the day now) the Airfix kit is a little wrong the little sticky up thing on the top of the rails do not exist(thats great as I thought I would have to make some of those as I broke some whists struggling to get the warped hull together, also there should be another gun port on the second tier down sternwards of the last on on the model, roughly where the little slot is on the kit, I may add it when I find out what purpose the slot is for also the ornamentation above the top rail dose not exist neither does the ornamentation between the rails. not tremendous problems so should be able to sort them.These are the little sticky up things which I've now removed.
Ok so I've reguilded the damaged guilding and the actual damage is not as bad as I feared the worst bit being he broke one of the side arms off and I cant find it anywhere os will have to try and scratch one(those canons are tiny, maybe a stretched sprue or a matchstick in the lathe, it's also now missing one of the flags (which I also cant find) nothing I can do about that so will just touch up the paint where it was snapped off .here is the damage.
Hi all well getting this one back in a sorry state, went down to feed the birds and empty the bins this morning. Rolf tried to take it to his house in frinton yesterday, didn't even get it out of the hall broke lots of oars off the anchor post lots of railings, a lot of the rigging is slack so he's busted something there as well, he thinks I will just go down with a tube of superglue and stick it all back on, not that simple a lot of the guilding was pulled off when the oars and railings came off so that will have to be redone(a real pain as lots of bits were stuck on after the guilding ) I will take some pics when I get it home.
Hi all well the transom will have to be done in small pieces, the ornamentation is making me crosseyed
- popeye the sailor, Papa, GuntherMT and 3 others
- 6
It's going to take me ages to paint this, the only reference I have is of a 1/100 scale ship and this being 44 times smaller its difficult to get the same look.
Hi all well this is going to be a challenge to paint, to say the least, but I've made a start.
- dgbot, tasmanian, Old Collingwood and 4 others
- 7
Hi all I've decided to display it on the turn with the gun ports open and water just starting to enter, I think that's a fitting setting.
My new one commissioned by my boss, the Airfix Wasa, I bought it off ebay and I've no idea how it was stored but its warped to hell, its been a real pig to get it together, didn't do it as per instructions as i could not get the deck atattched and level so glued the hull front together then when the glue set glued the rear the glued the deck a bit at a time using loads of masking tape to hold it till dry.Broke lots of these bits on the top rails (whatever they are) so will have to make some new ones.
- dafi, Old Collingwood, hexnut and 1 other
- 4
Hi all well its done (just hope Rolf likes it)after all he's paid for it.
- GrandpaPhil and GuntherMT
- 2
Hi all here is an update on this one
Hi all as a note People keep asking me how I do these sails, well here is a short guide, they are so easy.
First you need the white spirit you clean your brushes in ( you know the jar or bottle or whatever that all the sludge builds up in( I keep mine topped up in a little bottle as I use it for other things too)
you get your vac formed sails , your brush and your white spirit.
then you get a good brushfull of the sludge in the bottom of the bottle and scrub it all over the sail(both sides)
allow it to dry and give a second coat if required
then with a downwards motion wipe the muck off till you're happy with the effect
and there you are, see how easy it is.
Hi all just a quick update,my bosses husband said he would buy the Royal Sovereign but that this was too big was talking to him the other day and mentioned the Greenwich maritime museum said they wanted it but did not have the room, but would I resubmit it next year as they are constantly changing their displays. He told me today he will buy it (no mention of price), what would I ask for I can't keep it for a year, don't have the room (incidentally i told my boss I had got the Airfix Wasa off ebay and she wants me to build that for her. Actually as I was typing this he came up they've both gone for £400.00 I am well chuffed, I'm sure I could have got more but hey, two models out of the way and money for more, still have to finish the Sovriegn, and of course, start a finish the Wasa, I love modeling
Hi all another update.
Well I know it's not finished but it's sold, my boss's husband came round to show me his car (some little horrors standing on a bridge lobbed a rock as he drove under and stoved in his drivers pillar and windscreen (the cars only a fortnight old £90,000 worth) he spied it and the Reale and said the Reale was too big for his new seaside house but he would buy the sovriegn.
Hi all well I've decided to plug away at the rigging and here's where I am now, I've discovered I can do more than one set at a time with this thingy, thus saving loads of thread.
Hi all well the amati Loom A Line is total rubbish, the airfix doodah is brill though, so that is 10 quid down the drain, the airfix whatsit was free with the Wasa.
Rigging is deffinitely not my thing, I am thinking maybe take the top mast off just leave the lower masts and have it as its having a refit, don't know -
Thermopylae by kpnuts - Revell - PLASTIC
in - Kit build logs for subjects built from 1851 - 1900
