I have the same chopper, works like a charm. Charlene and Jerry, nice job on the Bounty.
Respectfully
Hi Per..
The chopper has been a must.  I never even knew what it was before.  I have seen it in Jerry's office and for some reson I thought it was a paper cutter.  I never thought about it again until I planked the deck and used it for the first time to cut the deck planks to length.  I have also found out that the chopper must be treated with much respect as I badly cut a finger a few months ago and I was very scared of it after that.  But I used it again upon Jerry's insistance when building the rudder cabin.  Jerry has since used it to make the grating coamings, etc.  I hope all is well with you..
Regards,
Charlene
Hi again,  Everyone..
I just came back from school and opened the log today but asked Jerry to make the report as he did most of the work you'll see in the pictures to follow....So here's Jerry..
Hello..
Charlene has had some beginner's problems with this kit but it's perfectly understandable.  The Amati Bounty is no beginner's kit and in addition much bashing had to be done due to what i call manufacturer's ignorance.  For example the directions (in Italian) call for the belaying pin racks to be fabricated from 1 x 4 mm. wood strips.  If one has ever tried to drill 15-   0.5 mm. holes in a 4mm, wide strip 3mm, apart from each other then you must surely know that after the third or fourth hole the strip will split lengthwise.  So we used some 1.5mm scrap plywood and our scroll saw, sander and drill press to make the pin racks.  We'll of course make all the other racks the same way.  The cannon ball holders were also made as above as the directions called for the stupid method as earlier with the pin racks.  And of course, Amati forgot to supply the shot for the cannon balls..I had a few left over from my Victory kit  which we used.  That's why the cannon ball racks alongside the grating looks so sparse. .Or maybe, Bounty just returned from target practise...When building the gratings no instructions were given as to how to hold the grating strips together.  Of course past experience stepped in and I showed Charlene how to coat the gratings with a thinned out solution of white glue and water  with a paint brush.  These are the things that Charlene hopefully will remember as she continues to enjoy this wonderful hobby.  I did some work this morning which will reflect in the photos.  Have a great evening everyone and
Best,
Jerry
Edited by Jerry's Admiral
Hi Lawrence, Grant and Brian...
This is Jerry writing for Charlene and me.  Much obliged for your visit and comments which I truly believe are encouraging and most helpful.
Brian, You are absolutely right with respect to finishing the grating with whitewood edges.  And I totally agree that it would have looked much better to do it the way you have suggested.  The problem in this case was the dimensions.  I was concerned that if I made the measurements shorter some of the deck opening would have been exposed.  The grates just do cover the openings.  Truthfully I'm not satisfied the way the gratings look and I may decide to redo them before starting the rigging.  It's Charlene's boat and after an explanaion to her, it'll be her choice as to what to do.  Many thanks for taking the time to express your thoughts and please let us know at any time you have some constructive criticism.
Best,
Jerry
This tool is made by nwsl.com
Buy from them and make them happy, read what they have to say on their website.
I have bought two of their items and am extremely happy with them.
Respectfully
you two have come a long way since I last looked in.     the Bounty looks great!  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi crackers.
Nice to hear from you.  Yes, I intend to saty on MSW and to put a few hours when I can into the construction of the Bounty.  I was able to add a little bit during the Thanksgiving break and of course spent some time observing jerry doing some of the work also.  I learned to make coamings and found the mini size very difficult to handle.  But i finally put it togethher and glued it to the deck.  Jerry showed me a trick using a square corner on a piece of very thin plywood to square the corners of the anchor rope hatch.  I am enjoying the progress and wish i had more time to contribute more to the build of this model.
Hi Popeye.
Good to hear from you again.  Thank you for your visit and encouragement.  I have attached some pictures of what we have accomplished during the past several days.  Things are coming along well andJerry tells me that I had better start reading some of his books on rigging as we are getting close to that part of the build.  I'm not sure i'm ready forr that but I'll do my best.  I'm also planning to learn how to make the masts and yards using our drill press.
Charlene
Hello Greg..
This is Jerry this time.
Many thanks for your kind remarks and of course your visit..So here's a few more photos of work I finished on Bounty today.
Have a great evening..
Best,
Jerry
Edited by Jerry
Hello everyone..
Charlene is away at school earning money so she can support me in the way that i'm acustomed.  So, being home alone I decided to a little more work on the Bounty whose progress is pictured here with a few more photos.  We made the midship and bow bits and belaying pin racks and also finished installing the bowsprit bits.  Charlene gets the next crack at the model over the weekend and hopefully will get a little more completed.  So there are pics showing where we are at.present.
Jerry
Edited by Jerry
Hello Dimitris...
Nice to hear f rom you.  Thanks for the visit and nice words. Hope you are well and things are going OK for you.
Best,
Jerry
Hi Everyone..
Well I had a few hours today and managed to get some work done. Jerry did a lot before me the past several days and so all i could manage was beginning the bow railings and knees.  I'm not happy with the blue stripe paint job and will attempt to make it much better a litle later on.  Jerry asked me to mention that there was a lit kit bashing done when it came to some of the metal parts sincce the originals didn;t fit well.  He made some wooden substitutes using the scroll saw and all came out pretty well.  Here are some pictures that will bring our mutual project up to date.
Charlene
Edited by Jerry
Jerry,
The deck planking is superb. What did you do to get the crisp black "caulking" lines?
Good morning Jparsley, Lawrence and Michael,
I have a few minutes of break time here at school and found this time to answer you all.  I appreciate your kind comments and i'm positive that Jerry will feel the same way. The model is beginning to take shape and I'm excited about it since I'm aware that we are getting close to the rigging phase.  Jerry has been emphatic that the rigging is a must on my part or I 'll never learn anything about the true aspect of building a ship model.  I know that when I started this project I bit off a lot more than I could chew and hence the reliance on my hubby.   I'm looking forward to our Holiday break next week as I hope to find some decent time to get some work on the Bounty done.
Lawwrence, you have been so kind with your periodic visits to my log and I want to thank you for your encouragement.  I'm happy that you are nearing the finish of your household chores and will soon be back in your shipyard thinking about the "African Queen."
Jparsley, thanks for looking in and,
(Michael) ca.shipwright,  I really am proud as to how the deck came out.  It was actually the first time I ever attempted anything like that.  At Jerry's advice, I use a black marking pen to coat one edge and one end of each strip to get the caulking effect.  Jerry used the same method on his HMS Victory and was pleased with the results so he recommended it to me.  And thank you all for coming to see us.
Charlene
Charlene,
I do believe that your Bounty resided in my shipyard before I sold it to Jerry several years ago.
Enjoy!
He Michael..
Thank you for reminding me where the Bounty kit came from.  Jerry was picking his brain trying to remember.  He said that he promised to keep the prevous owner of the kit informed as to the building progress and so now we know.  And now you know how the build is coming along.  Please keep tuned for more progress.
Have great day.
Charlene
Charlene,
I always thought that the Amati Bounty is one of the most beautiful model ship kits ever offered. You are doing a ban-up job of building this kit. It is coming out beautifully.
I regretted selling the kit as soon as I gave it to the FedEx guy. Oh well.
Regards to Jerry G.
Good morning, Brian..
I'm under strict orders to do the majority of the rigging.  But, I may have to wait until summer to do that so who knows?  Good to hear from you; hope all is well...
Hi Everyone,
So, it looks like I'll be able to spend some time working on the Bounty during the next couple of weeks as I'm now on Christmas break from school.  Jerry did  some work on the kit and his progress will follow with some pictures.  He asked me to mention that the Amati kit has been far from complete in both instructions and in parts.  There have been shortages, especially with the metal pieces and the instructions are far from good.  Since the kit is Italian, the plans and directions are also in Italian.  We asked the supplier for some type of itranslation and what we received is minimal at best and without previous experience I don't believe anyone could handle this model.  Forget me , as I'm a rank beginner, but even Jerry is having a tough time understanding the "manual."
Before we started building this kit we knew, from reading other posts, that the gun ports were too close to the deck and that the cannons would not stand with their barrels horizontal to the water line.  Jerry racked his brain for a solution  and finally i agreed with him that we'll place the cannons into the gunports even though a couple of them will be pointed below horizontal. We even thought about grinding the metal carriages down to lower them to the deck but decided that doing that would look real bad.  When the cannons and their tackle are complete I'll be getting my lesson on the drill press as I learn to make the masts and yards.  We are getting very close to that aspect of the build.
Jery and I wiould like to wish all of our friends a very happy holiday season and a very prosperous and healthy new year.
Nice work, I'm taking a lot of hints from your work on my copy of this ship.
Right now, I'm looking at "Bits with puleys and blocks ready to install.jpg", and wondering what kind of knots you used to tie the blocks onto the 'dowel'?
It looks like the thread goes around the sides of the blocks, but then that would mean it couldn't easily go around the dowel?  somewhere there is a 90 degree twist, or am I looking at it wrong?
Hello Regan..
Thanks for checking in on our log.  This is Jerry writing as Charlene asked me to answer your post and to add some more photos to her  (our) log.  In answer to your question, I don't know what you mean about a 90 degree twist.  Yes, I used a thread to tie the block to the dowel but the block sits at 180 degrees to the dowel or straight up. What I do is tie the thread around the block using a true square knot and then I tie the loose ends around the dowel. also with a square  knot.   I hope the attached picture will bo of some help for you.
Jerry
Hello Everybody...
A little more progress on Charlene's Bounty.  For the past couple of days we have been preparing 2mm blocks and eye-rings in order to mount the cannons and to rig them to the deck of the ship.  Charlene is learning how to handle blocks of this size and seems to grasp the way to thread them in order to attach them to various parts of the rigging.  In this case, as mentioned above, the rigging of the cannons.  I believe this will be the hardest part of the building of this model since everything is extra tiny and the areas to work in is very congested.  The results of our first three or four days follows in pictures.  The deck has become quite messy as you can see but we will clean this up in the future.  We hope everyone has had a wonderful holiday and will enjoy a healthy and prosperous New year.
Jerry and (charlene)
Edited by Jerry
Hello Regan..
Jerry
Thanks Jerry, I've moved on.  I fastened the block to the dowel using this technique shown here:
I used some of the very abundant black line that is in the kit, along with some black thread that came with the kit when I acquired it.
My language here is horrendous, because I do not know the proper technical terms, but the hole in the block needs to be perpendicular to the direction of the dowel.
The line going 'around' the block needs to be 'parallel' to the dowel.  When you tie a reef knot (is that different than a true square knot?), the lines move away from the block in the same direction as it did going 'around' the block.  In order to tie a knot around the dowel, you have to spin the block. That was a horrendous description.  It confused me, and I wrote it!  Never mind, the blocks are now fastened to the dowel just fine.
Good morning, Neptune..
Thanks for the further explanation.  I get it now.  I'm much obliged that you took the time to open my eyes.  In a situation like this, in the past, I simply twisted the block 90 degrees and put a drop of CA on the thread which held the block in its new direction.
Many thanks
Jerry (for Charlene)
Regan..
I appreciate the video.  It is very enlightening.
As  for the thread, I use  black Coats & Clark Dual Duty Button and Craft thread.  It can be found in most fabric stores or in a Hobby Lobby store if you have one nearby.  It's quite inexpensive and goes along way.  It's perfect for tying blocks and for all aspects of rigging.  And yes, a square knot and reef knot are the same.  Here is a sequence that I learned from Jerry to tie a 2mm. block using the thread mentioned above.
And a drop of CA on the knot will do it...
 I hope you have a nice day.
Charlene
awesome progress Charlene.....the deck layout looks super with the cannons rigged.   hope you had a good Christmas.........and wish you and Jerry the best for the new year!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
