Hi all well since I've nearly finished the Spits and the Lanc I thought it was time to start back on the Corvette and this little beauty that I've just taken delivery of, I must say I thought the 1/6 bikes box were huge but even they pale into insignificance when compared to this beast.
That said the box could be half this size
The moulding detail is beautiful
The instructions however could do with some work, one written page in english everything else is in French.
and why put these on the top where they could get creased like this, if theyed been on the bottom this would not have happened
Hopefully I can iron them out.
I have taken a very stupid chance and bought a very (well I think its very expensive) guilding kit just for this. I gulp, am going to try useing real gold leaf wherever the ship has gold. I have never guilded anything in my life so we will see, have I wasted my money, am I going to ruin this kit, stay tunefor the next exciting episode.
This turns out to be a nice ship when complete. I built it a long time ago. Have no idea where it ended up. It comes in different colors too. You got the white hull and cream colored "gold" parts. My hull was a blue and gold parts were actually metallic gold plastic.
I would really like to build the Corel version!
Have fun building!
Kp,
She is looking good so far. I know how tough it is to paint the tiny details on the Reale or any plastic ship. Have you tried Tamiya's tape? It lays down really nice and when burnished keeps paint from creeping under it. Just lay your first coat lightly along the edge to seal it. I also lay it over what I am going to paint and then use a sharp hobby knife to cut along the edge so as to get a clean edge. I used Tamiya tape to get the painted line on the U-Boat I did a couple of years ago.
Steve
I also have the Aurora/Heller English instructions in .pdf form if you need them. It makes building the Reale a whole lot easier.
Edited by docidle
Current Build: Merit 1/48 Early Eco 80' PT Boat and Imai 1/50 Catalan Ship
Revell 1/196 USS Constitution (My oldest son's school project)
Revell 1/72 Hanse Kogge
Revell 1/50 Viking Ship
Revell 1/72 U-Boat
Zvezda 1/72 English Medieval Ship Thomas
Revell 1/90 The Nina
thats a good idea vsjerome, the masking tape idea won't work with gold leaf. The trouble I am having is getting rid of the loose bits that have not stuck to the size, I tried a stiff brush but the gold is so soft (its 9 carats I don't know if that's the softest or hardest grade, maybe if it's the softest I should get a harder grade) it takes all the gold off not just the whispy bits at the edges.
Can somebody help me on this I've tried searching here and on Google for a build log on this and all I can find is someone on finescale modeler asking if anyone's built it or my build log (which is obviously rubbish) I know this kit has been built by other people where are the build logs.
KP,
There's no builds of the Heller kit.  Several of the Corel which might give you ideas, etc., but the Corel kit is wood.
Edit:  Thought I'd add this.. I used Reale France as search terms here on MSW.  Gave me the kits and the scratch project.
Edited by mtaylor
KP,
There is a great build log on this German forum of the Reale by Schmidt. It goes through pretty much the whole build and he is a really fine modeler. If you use Google translate it makes a bit of sense, although the translator has difficulties with some words. I hope it helps.
http://www.wettringer-modellbauforum.de/forum/index.php?page=Thread&threadID=34914
Steve
Edited by docidle
Revell 1/72 U-Boat
Hy Steve, that would have been my hint too. For better understanding, he is working on two hulls there: one fresh one that he basically pimps up and one already build oob from E-Bay as reference - so do not get confused, he is comparing them quite often :-)
XXXDAn
Edited by dafi
Hi all here is a bit of an update. I have a big problem with this kit and dont know how much further I can go with it. there is supposed to be 2 sprues number 17 and 2 number 18 but there is only 1 of each, I have emailed Heller and asked for the missing sprues to be sent but have no idea what their customer service is like I'm hopeing they will send them as the kit is useless without them and I will have to bin it otherwise. so will do what I can and hope they will send the parts sooner rather than later.
XXXDAn
Dan,
Thanks for clearing that up, I have wondered at times why it seemed he was working on two models at once. The OOB was very nice but the pimped out one was REALLY nice. I know at the time, he was using an oil wash on his models but now has come around to the way I use oils, straight out of the tube and wipe after a time. Although I do tend to use a number of oil colors for my aging process instead of one. I really like his, Chris (Drake), and your modeling.
Thanks again,
Steve
Edited by docidle
Revell 1/72 U-Boat
KP,
Your Reale is really coming along nicely. About the missing sprues, I have never had to deal with Heller's Customer Service, but I have heard that they are helping customers out with these issues fairly well, although there might be a lag time.
I will need to pull my Reale out now and check if it is missing any sprues. Thanks for the heads up.
Steve
Edited by docidle
Revell 1/72 U-Boat
Hi thanks for the replys I am going to continue to build what I can on it in the hopes the parts will come I know it could be wasted work but if the parts dont come, maybe I could put it in some sort of dio in dry dock for a refit or something
I am having all sorts of problems getting rid of the loose flakey bits that you just cant seem to brush off, so I've decided to try guilding the whole part then painting over the guilding.
I've started by sizing all the parts for guilding
then guilding the whole lot
Now painting it
also I decide to put a wash over some of the solid gold parts to highlight some of the detail
Impressive, very.  I built this many years ago and it never occurred to gild all the gold areas.  Looks great and look forward to more.
Rick
Wherever I am at...........there I am
KARTONIST in the making.......... B)
Hi all well I'm afraid this is as far as I can go till the parts come so hopefully they will be here soon.
I cant glue the two boxes on yet as I would not be able to get the other cannons in so this is it for now.
S9Fx4j7.jpg?1
Emailed Heller and have been told the parts were shipped on the 23rd so hopefully not long to wait.  Still won't get much done as off on hols in a fortnight.
