Hello david...
I'm so happy to see that you're back in business.  I do have one worry though, are we going to be able to put up with your wit.  Just kidding, because I'm sure we all missed you very much.  The Diana deck is fabulous; it looks so good.  Having now built kits from various manufacturers I have definitely decided that from a a material and plans viewpoint nobody can beat Caldercraft. One gets what one pays for. So I'll be staying in touch and hope you do the same.  Regards from the admiral.  She said to tell you that we still are planing a trip one of these days to northwestern England.  Take care,
Best,
Jerry
Hello David, Diana is coming along well, I have the kit waiting in the wings. It appears Caldercraft weren't too fussy with the supplied wood in this kit, I have already replaced most of the Boomerang dowel and will check the planking timber when construction time comes.
I have sent you a PM re the Top & Butt planking jig.
Regards
Gary
This is looking very nice david,   lots of clean detail especially the deck joints.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Greetings all
Well I am enjoying this build now, after my long layoff, and things are going pretty well. I have completed all the work necessary on the gun deck for now, apart from fitting one broken off upright which needs sanding to the correct shape to follow the curve of the planking. And now I need to temporarily fit the top deck before starting the first planking. The bearding line will firstly need to be sorted, so to taper the rudder or not is the question. I am still not sure what to do. Could anybody tell me how many plan sheets I should have, as I have six, and thought there was one showing all framework assembly ( the bulkheads and stern fitting etc) which may of gone missing, so I do not have any picture of the complete assembly framework shown in the first photo. Anyway thanks a lot for viewing and all your comments, and here are a few photos of my progress. DAVID
6 sheets my friend. 6 sheets
Current Build - Caldercraft Diana
Completed - Artesiana Latina Swift, Harvey, MGS Prince de Neufchatel, Imai USS Susquehanna, Mamoli Constitution, Rattlesnake per Hunt Practium, Caldercraft Snake, Diana, Caldercraft Victory, Kammerlander Duke William
Waiting to be Launched -  Bluejacket Constitution
Proud member of The New Jersey Ship Model Society, Model Shipwrights of Niagara, Model Shipwrights of Western New York and Offshore member of the Society of Model Shipwrights
6 sheets. keep up the great work
Absolutly loving the deck planking - Super Work  clean neat and tidy :)
OC.
Current builds
Completed works.
Greetings all
Thanks for your comments and likes. Well I have got a bit more work done on the Diana, as it has not been worth venturing out at times with the bad weather we have had. The top deck is pinned in position and the rudder wil be tapered. As you can see I have already tapered the sternpost area, which we all know should have been sorted before any assembly work. The taper is slightly over 2mm at the base, and needs reducing at the top slightly, but I can easily sort that when I need to, at the planking stage, when I can tidy it up. I am about ready to start the first planking, but as you can see some of the bulkhead runs need be sorted which I will do as I go, just checking with strip which I find works for me. Well wish me luck, and I shall be back in a week or two or three. I have taken a few photos to give you an idea what the stern post taper is like, but it is very awkward to achieve a decent view, which could be with the lamination of the ply. Thanks a lot . Regards Davidpost-96-0-57672100-1479846090_thumb.jpg
Greeting all
And here we go with the first planking. As you can see I have planked down four strips and now started letting the strips run in a natural curve, with the strip running easily and flat on the bulkheads with no pressure. You can see what happens at the bow when you add the third and fourth strip, the strip is being twisted into place leaving gaps between the strips, and the strip is also not landed flat on the bulkhead leaving gaps between the bulkhead and the strip. So we now need to add stealers later. I bet none of you chaps have ever twisted any planks into position. Anyway, it's going good, with the first plank pretty level with the top deck, although it isn't on the photos as the deck has been loosened off a few times. So this is were I am at the moment. Jason I don't know what I am going to do at the keel yet. Any way thanks for all your likes and comments, here are a few photos Regards DAVID
  • 3 months later...
Hi David,
I'm no ICT expert but ......
I'm sure it's possible - try moving the 'flashing' cursor to the bottom right hand corner of a picture and then tap the 'return' key a couple of times to add a few line spaces. You should then be able to type in your comments there.
Hope I'm not guilty of teaching you to 'suck eggs' (!) but I tend to write my text first as a word document leaving gaps for the pictures , cut and paste this into the 'reply' box and then upload the pictures into these spaces.
I still struggle with the frustrations these clever tech tools throw up at me at times - and I take my hat off to those clever devils who manage to annotate their pictures with arrows, coloured text etc.
Hope this helps.
Cheers,
Graham
Greeting all
                   I am about to cut out the 28  16mm x 14mm gun ports, after finishing the first planking. I have this  fluted burr which isn't to bad, but would welcome advice on a decent product you may have used and would  recommend. I am cutting through a double wall which will be  7mm, so the longer the cutting edge the better. Regards .DAVID
hi david,
i used a 1mm drill bit. made lots of holes and then used mini files to finish the job.  took time but in the end i felt it was worth it. your deck is great. thank you for sharing the deck jigs.
all the best
mort
I do like your planking very much. Your hull planking is coming along great.  Good work
Regards, Scott
Completed builds:
Awaiting construction:
hi david
forgot to mention i put painters tape around the gun ports before filing
mort
  • 7 months later...
  • 9 months later...
Greetings  All
                        I have taken my Diana out of storage, and decided to continue my build after approx three years.  I tell a lie !!!!!.   All I hear from friends is. “ Where’s that Diana ?”   “ That Ship should have been finished by now” or “It’s about time you started building that ship again” or words to that effect. So I have given in to all the earache I get. As I said I have today got my self ready to continue. I had reached the stage of cutting out the gunports after finishing the first  planking. The ports are roughly cut out on the starboard side, and I intend to line them next, and then start on the Port side.  Unfortunately I cannot locate the two instruction books which I know are in the house somewher,  but I do have  all the plans to hand. What I need to know is the gunport sizes which I think are 14mm x17mm  and if the four gunports with lids ( three at the stern, and one at the bow) are the same size.  I also need to know the strip size I should be using for the linings.  Thanks to you all in advance for your help. DAVID.
Hi David,
Picks up instruction manual blowing an inch of dust off the top 🙂  I seem to recall that I ordered some wider strip because 1x6mm did not seem large enough....I also seem to recall this was probably the last time I looked at the instructions because they are really not that helpful.  For what its worth, the instructions say the following...
"Gun port dimensions should be 16mm long, 14mm wide and 30mm apart (note:  although I disagreed with the latter dimension as per my log...)
Gunport without lids can be framed using 1x6mm walnut strip.  Cut to length and glue the vertical sides first, followed by the top and bottom frames.  When complete, sand the outer edges flush with sides of hull.
The gunports with lids are framed after the application of the second planking."
Cheers,
Jason
In the shipyard:
Hi David,   so good to see you back on the build.
OC.
Current builds
Completed works.
welcome home you were missed.
mort
Edited by mort stoll
On ‎8‎/‎23‎/‎2018 at 12:56 PM, Shipyard sid said:
Greetings  All
Welcome back Sid. Its a coincidence that after stopping a couple of years ago I have just restarted with a new build.
Glenn (UK)
Sid good afternoon, the Dianna will be my next build, after The Vic is completed, LOL i will still be a long way behind you, but will learn from your progress
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Greetings all
                    Well I will be more than glad when I have all these gunports cut out and lined. I have only lined 12 of the starboard side. The strip is very brittle and the edges break away at times, and some of my work is more than poor, so it shall not be seen !!!.  So I now need to know the size of the second planking strip which will hide the edges of to aforesaid gun ports. Looking at the plans it could be  277 but as I have not located my manuals I do not know what 277 is.  BTW Jason is absolutely correct, the 6mm wide walnut strip is not wide enough to line the gunports. Regards . DAVID
Hello Kevin
              I was just preparing my script when I heard your mail ping in. It will be your own fault if you follow me when you start building your Diana , so don’t blame me !!
Sometimes I wish I had never clapped my eyes on it, and took up Stamp collecting.
But don’t let me put you off .     Best regards DAVID
9 minutes ago, Shipyard sid said:
“ Find it Collingwood !!  And no you can’t email Cornwall model boats for one, we are two hundred and and thirteen years to early !!! And don’t even think about joining model ship world with this lump of junk “ !!
"Hey"!   that could have been me in my early days......
OC.
Current builds
Completed works.
Greetings all
                 Well the starboard side gunport ports have all been lined in some sort of fashion as you can see, which I find a very disappointing standard, when I compare my work from a few years back. I think thing should be ok when I fit the second planking, so I shall now ignore the instructions and plank down to the wale as I cannot see any reason why not, and try to make the ports and run of the planking look some thing like decent. It is obvious this  visible area of the hull is the most important. So here we go with a bit of planking, wish me luck. Thanks a lot for all your likes .
regards . DAVID
Coming along very nicely david.
OC.
Current builds
Completed works.
Hi David
Looks good to me :)You may want to consider getting a coat of paint on the gunpoint linings before you put the second planking round them... they're tricky enough to paint without having to avoid the final outer hull finish at the same time. My boat ended up looking like a toddler who'd got hold of some lipstick around this point... I'm sure you'll do a great job and it will look really smart as you get the next skin on.
All the best
Rob
