Great stuff, Piet - she's really coming together.
Brian,  if you think you'd like to build a submarine, why not think about AE1 or AE2 - seems an appropriate time for a model of one of them.
John
Hello John and thanks for your compliments.  It would indeed be a great tribute to the crew of the AE1 to build a model of her.  When it turns out to be a good model, as I'm sure Brian can accomplish, the model could be placed on permanent "loan" to the Australian Royal Navy museum.
Thank you Mark for dropping by and your like, it's much appreciated.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Piet,
That is an incredible mine.  But then, so are the pulleys.  Engraving Remco's name on both of them is a wonderful tribute.
Ahhhhhh Piet I thought you were pulling my leg mentioning to engrave the pulley's, but you're actually pulling it off.
I am honored to be actually named on you model and also that you let me help you a tiny bit to accomplish your wish to build your fathers sub.
A BIG thank you.
Remco
Treat each part as if it is a model on its own, you will finish more models in a day than others do in a lifetime.
Current build HMS Kingfisher
MSW 1.0 log click here
Looks good Piet
Best Regards,
Pete
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Herreshoff Buzzards Bay 14
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
looking good Piet!  the mine and the pulleys are really cool!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank all of you for visiting and clicking the like button, I am honored.
@ Mark, thank you but what do you mean "Engraving Remco's name on both of them"?  There are six of them 6 mm buggers and it wouldn't be right to not do all of them   :D  :D  :D   But - - - I refuse to do the 3 mm pulleys  ;)  ;)  :rolleyes:  :rolleyes:
@ Remco, yeah, actually it started out that way, pulling your leg that is.  But after I tried it on my wooden prototype I figured why not give it it a try.  I have ordered a small electric hand tool like EdT is using.  That should give me some good control, perhaps better then a snake attachment.  I hope that my hands are steady enough.  Well, it's I who is grateful for all your help and this is the least I can do to show my gratitude.
@ Pete48, thank you as well and what a fine looking model you are crafting, just lovely.
@ Popeye, thank you !!!!
Did I mention to all yuns that I'm having fun????
Cheers,
                       VOC Ship Surabaya
The fun definitely show, Piet.  And as for the pulleys.. I only saw the picture of two with his name on them...  :blush:
Hello Mark, ahhhh - - - poor you, don't take it so hard my friend  :D  :D  :D  :D   Yep, there are three for each gantry and a few of the 3 mm ones.
And yes, I am having a ball, will mis the build when we go up to PA to visit our daughter and grandson but perhaps I can finally do some artwork.
Cheers,
                       VOC Ship Surabaya
Hello again every one and thanks for visiting and your like votes.
The mine saga is close to coming to an end, hurray  :dancetl6:  I cemented most all of the hardware on with two part epoxy and started cleaning it up.
I also cemented the tracks in the mine tube on the sub.  There is still adjustments to be made to make them slide down into the bin but that'll have to wait till the weekend.
I also made 10 of the 3 mm pulleys, another hurray!   :dancetl6:   I managed to snap one drill bit though, a # 68.  No matter how slow I fed the drill this brass is tough and the drill snagged enough to make it fgo beyond it's design limits ;)  :rolleyes: .  I'll just blame it on junky Chinese drills  ;)   I got the broken part out after I made two pulleys.  :D
Sooooh I sharpened the broken drill bit by hand and eye with a diamond file and it worked okay for the rest of the pulleys - - - being extra careful.
I tried fitting one of the mines in the bin and it would only go half way in so I need to file the fake "roller guides" some more.  Once I get them to slide in nice and easy they'll be painted a dark grey to offset them with the rest of the boat.
Well, this is it for today.  A few pics below for my archive and your viewing pleasure.
I cut a strip of plastic that fits snug between the two U channel tracks inside the mine bin.  I think they are close to 180 degrees to each other.  I'll have to adjust the mine sliders to make them fit.  I used two part epoxy cement.
This shows two mines - now with all the hardware on them except for the arming switch which will be done after the mines fit.
This shows all ten of the 3 mm pulleys.  As yuns can see I made the pulley pin holes rather small and had the reduce the diameter of the brass nails I am using for them.  I believe this is closer to scale then using those 1 mm nails.  These are 0.4 mm in diameter.
Cheers,
                       VOC Ship Surabaya
Wow those are some nice looking pulley's, Great job Piet
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Nice work, Piet.  It's probably a good idea not to add the arming switch yet.  You wouldn't want one of them blowing up prematurely.  :D
nice bit of progress.......the mines will look great when painted :)     looking forward in seeing all this come together.   are you going to try fitting them before you go off on your trip?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hello Pete and thanks for your kudos.  Yep, they came out okay, it's rather easy when you have a lathe  ;)
Hi Mark and also a thank you to you.  Yeah, I guess you are right but this afternoon I did manage adding the arming switches  :o   I'll be careful though handling the mines  ;)
Hi Popeye, thank you as well for your kind words.  Patience my friend, they are coming together but slowly.  Yep, They'll be old history by the time we drive up north.
Cheers,
                       VOC Ship Surabaya
First of all my thanks to all who visited and your likes, much appreciated.
Continued today with dressing the mines and fitting them in the bin.  It's a tight fit but I can move them in and out okay.  After I was happy with that task working out okay I added the arming switches to the sinkers.  The trigger cords still need to be finished but that'll be done Sunday and then I can paint them and call it done :dancetl6:
It was a short day for me because I first had to go to the DIY store and buy a new lawn sprinkler head and after lunch I decided to make dinner.  Ran down to the local green grocer and bought nice root veggies and organically grown tomatoes.   Then off to the butcher and got me a nice chunk of beef.  I planned making a Belgian style beef stew with a good dark Belgian beer - yummo!!!
Gwen was happy she didn't have to cook ad it came out just great.
Okay, I did make a few pics of one mine inside its bin but they are still not painted.
This shows one of the mines fitted inside its bin.
Another angle of the mine inside its bin, you can also see part of the arming cable.  The other end is hooked to the side of the bin and as the mine is dropped down it pulls the switch lever that arms the system.  Rather ingenious.
Cheers,
                       VOC Ship Surabaya
To bad most of the mine details are hidden by the bin. Still looking great Piet.
Will you be having one being lowered into place? Piet
Michael
Great work Piet, The detail work is amazing
Best Regards,
Pete
Edited by pete48
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
great details Piet  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hello everyone and thanks for visiting and your likes.
@ John (Lad), thank you John, Yes, she's going to be something alright, much more then I originally intended.
@ Remco, never fear buddy, that's why I made two. Besides, the one that's inside the bin can be pulled out for demo purposes.  I should have made the mine bin closer to the torpedo loading gantry so I can actually hang one on the tackle, but then again they were not used for loading mines.  The second mine will be placed on the final display board with a torpedo or two.
@ Michael, as a followup to Remco's question, no, I am not able to actually demo the loading of a mine - - - except if I make a dock-side crane for that purpose  ;)  :rolleyes:  :rolleyes:   No, really, I'm already adding much more in details then originally planned.  Actually, they did have a torpedo loading dolly with a lifting boom that ran on the rails I put on the deck - - - no, I'm not going to make that dolly  :unsure:
@ Wacko Joe, good hearing from you and thanks for your compliments.  Well, you know me, I take pictures whenever I have done something, they are for my own archive as well.
@ Pete, thank you too for your compliments, always nice to have all yuns in my dockyard.
@ Pat, good having you here and thanks for your compliments as well.  Yeah, She'll be a conversation piece alright.
Cheers,
                       VOC Ship Surabaya
Thanks everyone for dropping by and your likes, it's really much appreciated.
Well, the mines are finally finished and painted.  Yuns are probably sick and tired of hearing about and seeing these buggers, well, so am I  ;)   On to other things now such as completing the torpedo loading gantries and dingy boom.
I managed to engrave remco's name in the 6 mm pulleys and his initials on a few of the 3 mm pulleys, really!  Some of them were not as good as most but it's the idea that counts.
I blackened the pulleys and some other hardware and painted all the pulley brackets licht grey and started to assemble the pulleys into them.
I also cemented both the forward and aft gantries to the deck.  Now it's just a matter of mating all the parts and pieces to where they are suppose to go.
This has been a very successful day and expect to have the gantries up and running in the next few days.
Here are a few pics to show today's progress on the mines and the pulley engravings.  No sense showing all the hardware because they haven't changed a bit from previous pics, only now they are painted.  I'll show it when the gantries are fully operational.
Here are the 6 mm pulleys with Remco's name engraved on them and only 2 of the 3 mm pulleys with his initials, which are hard to see under the glare but they are there.  Unfortunately they are all very hard to see after I blackened them, but rest assured that they are engraved.
I have loaded one mine in the bin and placed the other on the deck for show.  You can now also see the arming cable.  I thought to paint the fuse tips red for "danger."   :o
Here is another view of the mines.
Cheers,
                       VOC Ship Surabaya
Piet,
I'm always amazed and inspired when I visit your log.  My jaw dropped when I saw the finished mines.
if they are activated by floating out and the cable activates the arming device -how are the mines kept safe when removing ones not used -
I presume there is a device that can enable them to be retrieved from the bins
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
The mines look great Piet. The engravings too, one engraved pulley wasn't enough uh? ;)  Thanks again buddy, although I do hope they don't stand out to much after they are inserted in the brackets. Imagine 200 hundred yeas from now, historians digging up the Dutch National Archives for the original drawings as to explain these strange markings on a contemporary model. That would be hilarious...
Remco
The mines look Fantastic , Great work Piet
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
