In David Antscherl's primer on planking, on page three he states the following: "By now you will realise that virtually all the planking will need to be cut to shape, as you cannot edge set a plank.".
It would seem to me that based on the method he describes it would be beneficial to spile every plank on the hull...is this correct? On the previous page he describes how to create a stealer plank, shouldn't that be unnecessary if you are spiling? Are there instances of planks common to the every model that do not require spiling?
“The World is a book, and those who do not travel read only a page.” - Augustine
Artesania Latina San Francisco II 1:90 Scale
On the Shelf:
Model Shipways Armed Virginia Sloop 1:48 Scale
Ideally one would at least check each plank for width along its edge.  Even those not particularly needing to be cut on a curve still will need a bit of tapering, which is what spiling is, matching the width and shape of each plank to its place on the hull.
You can bend a plank in or out, twist it, or bend it up and down (edge set) but not more than two of those at a time.  Since you have to bend in or out and twist in most places, that leaves cutting on the curve for the up and down.
Stealers and drop planks are used when the difference in width of the hull at that point becomes either impossible or difficult to account for merely by changing the width of the plank, in other words, when spiling will no longer work with the plank stock available, or when the plank would diminish to near nothing.
Remember, the plank should set onto the hull with no stress, totally relaxed, as smoothly as a baby's butt.  Stealers, drop planks and spiling help you achieve that.
Edited by jbshan
Hi Fish
I disagree with David,you can edge bend planking and many builders far more experienced than myself have shown techniques for doing this.I have even successfully edge bent Ebony.
The odd stealer was using in planking of many full size vessels,however,if you want to emulate the planking on contemporary models,then stealers are undesirable as they were very rarely used on these models.
Kind Regards
Nigel.
Currently working on Royal Caroline
With all due respect, Nigel, while one can edge-bend a plank to a degree, the ideal is as Joel states; "The plank should set onto the hull with no stress, totally relaxed". It imparts a good deal of stress to edge set a plank more than a few degrees. Heat and moisture can help, for sure, but I wouldn't want to attempt edge-setting planks around a bluff bow. I tried that on an early model of mine and, after a few days, the result looked like clinker planking, except it was supposed to be carvel!
The idea is to prebend the plank off the model Druxey,I totally agree that bending as you lay the planks is fraught with problems.Chuck uses a hair dryer,Dr Mike uses an iron or a toaster!Prebending the planks removes any inbuilt stresses and prevents problems later on.
Kind Regards
Nigel
I haven't experimented with off-model edge-bending, Nigel. I've seen Chuck's results and they do look very good. I wonder if there will be a tendency for them to 'spring' later on, after a year or two? Similarly, how easy would it be to edge-bend a complex 'S' shaped wale plank accurately, such as shown here?
Druxey,
In my "scrap" and "misc" piles, I have pieces that I soaked and bent with a curling iron set to "MAX".  The pieces are still bent after several years.
I did do some steambending way back on my Constellation but the parts on the ship and I'm not finding any scrap... so that's inconclusive.
I agree Druxey that would be a little challenging.I don't say you can eliminate spiling completely,just reduce the amount required.To date,i haven't had any spring back issues,however all my final planking is glued to a continuous substrate,be it solid wood infill or a first planking layer.I know Chuck single planks over bulkheads or frames albeit closer together than one would find in a standard kit.
Kind Regards
Nigel
Since I just finished planking my Victory I will wade in with my 2 cents on spiling. When I second planked the starboard side I spiled about 6 planks at the bow. The planks were very happy and a perfect fit was obtained (IMHO). The trouble was that to effectively spile I had to start with a wider piece of wood than the kit supplied. In my case I used some wider planks that didn't quite match the rest of the planks. So on the port side I edge bent the supplied planks. More effort, more strain, but with steaming and prefitting it ended up looking just as good (I show some examples on my log). The edge bending was also facilitated by spiling standard planks to the extent the existing width would allow - not insignificant at the bow where you are typically tapering to a narrower width anyway.
Anyway, if I was to do it again I would have ensured I had wider planks of the same stock to begin with. Even though the end result was the same I enjoyed spiling and it is the correct way to do it.
Best,
Ian
Edited by Seventynet
Yes, Ian, you sometimes need wider plank stock than comes with a kit.  Even the old timers didn't have easy access to say, 48 inch wide plank.  This is one reason to use stealers, to get the distance covered with narrow plank stock.  A garboard might have a section at the aft end that notches up wider, to the width of two or more 'normal' planks, to allow you to use regular stock farther up.
Spiling, the process of measuring each plank to the one previous, is the way you find out how wide and what the shape is of that next plank.
So a stealer plank is used when the size of the plank is so small, it's not really possible to taper to such a small size?
On the Shelf:
You can taper to a fine point, but that's just not realistic.  In the real world, you would need at least one nail/trunnel/whatever there to hold the end down.  The usual rule of thumb (rules are made to be broken...) is to not taper more than half the plank width...   but see about rules made to be broken.
At the risk of stating the obvious, a drop plank is used to reduce the number of planks running forward (e.g., at the bow). In other words if the tapering is making the plank too thin (like Mark says, less than 1/2 the plank width), you may need to reduce the number of planks by dropping one out - a drop plank facilitates that. A stealer is used to fill out a space that cannot otherwise be filled by the normal plank width (e.g., typically at the stern).
Timely topic for me, thanks Fish
I have just started 2nd planking my Endeavour and have been pondering the correct way to do it.
What is the proper way? Do I need to make all the planks go forward?
Or do it as the replica has been done.
Another question, What would be the max width plank used for spiling?
The Jarrah I am using will only side bend a tiny bit, but the pine I used for the 1st planking
could nearly be tied in knots after soaking.
Which has me thinking that if a plank will side bend then do it. If not then spile.
Thanks Chris
Hi Chris,
I think the only thing that will tell you how wide the plank needs to be is the curve itself and the length of the plank - revealed through the many techniques used to define the spile. I use transparent tape. Anyway, the wood I used (mansonia aka African walnut) became more conducive to edge bending through two approaches - tapering (and there's where you can do a semi-spile by cutting/sanding part of the curve into the plank you are tapering) - and steaming/soaking the plank, then prebending and clamping it into the actual bend (let it dry, refine the fit and then glue in place). I do not think you risk a plank popping later on if you follow that method. However, there is a limit to how far you can edge bend and the wood will tell you that (it will fold in on itself). Again, IMHO, spiling is the preferred way if you can get the stock.
Best, Ian
Hi Ian Stock is no problem as I am cutting planks myself.
What I want to know is, what is the max width of planks that would have been used
back in the past when these ships were built.
On my Endeavour i would need planks that would have 900mm plus in width
I don't think that would have been done.
Thanks Chris
Sorry Chris, that's way out of my knowledge base. However I wonder if it would be logical to assume that the maximum width of the real stock would be controlled by the length of the plank. IOW if the curve for a 20 foot plank required a plank wider than they possessed, the plank length would be limited to something less than that. Maybe a serious spile would be addressed by a less wide 10 foot plank. Does that make sense?
On spiling.. if you line off the hull per the tutorials at bow, the planks will need a taper.  If it gets too 'thin' on the taper, a drop plank will be needed.  At the stern, if the needed planks get too wide, stealer time.   The tutorials are a big help and about the only difference is the method in laying out the runs of the planks.
On plank width... shoot for a plank length around 28-32 feet or so...  It's going to vary from place to place depending on what was available at time.  Width could be 6" to 12" wide... again, depending on what was available.
Crackers... microwaving works but you'd best move it to the workshop as the planks cool down fast, in my experience.  I've been using the curling iron method which works for me. I'm trying the Chuck heat gun method but so far, I don't have the hang of it.
It's like" to be or not to be,that is the question" Well I have done all of the methods of plank bending. I prefer to use a combination on mt building. Spliing is an art that you have to practice,and yes it does take wider material than is what is supplied in a kit.
But as one who doesn't use the kit wood for other than first planking if at all,it's not what dictates how I build or plank. 99% of kit supplied planking wood is crap IMHO.
I have spent more time trying to get a great fit by bending in the different ways listed than by spiling a plank. As to wasted wood,a lot of times I make up a pattern out of folder paper to begin with,and that way I reduce my waste by 90%. I can layout and trace the paper plank onto the sheet and then cut it out leaving enough to fit it into place. The next spilied plank is about the same shape, so it nests into place next to where the last one was.
Just how many planks do you break using the heat and bend and other methods? And if it's short,what do you grab onto when bending?
Keith
I think you are on the right track Ian,
Make a plank out of more segments for which you might be able to a wider one for bigger curves.
Still i think that 400mm to 500mm planks would be near the max width to get any sort of length if that.
so i think that I will work out my planking based on this idea.
Cheers Chris
end of quote---
I always leave a tail or handle that extends past the ultimate end of the plank I'm working on.  I first cut or sand or taper, whatever, the top edge and give it a rough bevel.  I then trim the end going to mate to the previous plank or into the rabbet, going back to the top edge if needed to get the top and end to a snug fit.  I then do the bottom edge to the correct width from previous calculations, at 90 degs. to the outer face.  Lastly, I mark and cut the tail end to fall on the frame I want.  This 'tail' has been my handle for all the previous processes.
I have just been dealing with this issue and the planks that I am using 5/32 thick by 5/8th at the widest cannot be edge bent successfully I have to spile them.
after steaming for 25 minutes they lay on the frames like a cloth....Thanks Chuck and Druxey for the tutorials
Michael
On my next build I'm going to try cutting the planks from sheets to fit the curves as opposed to bending. I've never done it before but the idea of a plank laying on without it be under stress seems like a good idea.
On the Shelf:
I've tried spiling the first time about two weeks ago, using mahogany veneer. Worked like a charm and in my opinion, works better than edge bending.
Samuel Pepys notes in his diary on 19 July 1667: "the Dutch fleets being in so many places, that Sir W. Batten at table cried, By God,says he, I think the Devil shits Dutchmen."
I just finished spiling my current build.  It was a first for me and it does beat edge bending.  I actually did both due to some of the compound curves and tapers involved so spliing got it close then bending, twisting, etc.  Spiling wins hands down, IMO.
It is so good to see these posts from those that have tried spiling and have become converts.  There are a lot of posts on clamps for planking but a properly spiled plank can be soaked and pre-bent and, once dried by whatever means is chosen, it can be held in place with finger pressure for a minute or less using an aliphatic (carpenter's) glue.   Druxey converted me years ago and I have been happy that he did so.  No pin holes and no clamp dings, especially when using softer species of wood.  I do use clamps for many things, but rarely for planking.
Allan
