Bolts added at the tip of the standards, bottom will be put in when fastened to the deck, ironwork added to the companionway, gratings also completed, I have simulated the bolts with pencil, only one though couldn't get two in there, I should be able to start deck planking soon
The clerk of the cheque's yacht of sheerness
Current build HMS Sirius (1797) 1:48 scratch POF from NMM plans
HMS Winchelsea by chuck 1:48
Cutter cheerful by chuck 1:48
Previous builds-
Elidir - Thames steam barge
Cutty Sark-Billings boats
Wasa - billings boats
Among others 😁
All deck furniture completed, now into waterways and then planking, 20180817_170552.thumb.jpg.96f81762aa13725a6aece83591d586f6.jpgI'm going to try and have the skylight windows opening
Previous builds-
Among others 😁
Hi Paul, when you say having the skylight windows opening, Are you thinking of just having them or one permanently opened or do you mean being able to open and close them? The deck furniture looks great.
Michael
Thanks Michael and for all the likes, I did think to have them working, opening and closing but with the frames at 1/32 it might be difficult
I have added some hinges and opened one side, they will go up and down but will be very fragile and probably mot accessible when completed so I'm thinking to fasten one side and leave one open
Previous builds-
Among others 😁
Started work on the waterways, curved scarph joints are a pain
I'm using ottili wood for the waterways, I was given some sheets by friends who own a boat yard in Windsor (they are currently refurbishing the last Dunkirk vessel still afloat and supplied the boats for the recent Dunkirk film)  its quite grainy but is a lovely colour
Previous builds-
Among others 😁
Deck planking all completed, seven coats of sanding sealer sanded with finer paper inbetween each coat finishing with 0000 steel wool
I have added the bolts ln the corners of all the grating coamings and now finishing the rear part of the waterway
I promised the wife when I had finished the deck I will go back to working on the Sirius so this could be the last post about the cheerful for a while
Edited by paulsutcliffe
Previous builds-
Among others 😁
So back to the Sirius as promised, very productive day in the shipyard, forecastle and quarterdeck beams cut, cambered and foremast partner beams started
The red light is a laser level that I'm using to make sure everything is centred properly
Previous builds-
Among others 😁
Thankyou Albert and every one for all the likes, not quite on a par with your naiad but I'm getting there
Regards
Paul
Previous builds-
Among others 😁
First hanging knees attached, an iron curved knee will go around the gunport
Previous builds-
Among others 😁
The forecastle is completed apart from some lodging knees, I have also cut the skid beams ready for cambering, brodie stove finally hidden under the beams after all this time
Foremast partner is in the process of being test fitted, I also added some chocks on either side of the fore bitts as seemed very weak area, the two iron knees can just be seen in the photos
Regards
Paul
Previous builds-
Among others 😁
Skid beams being test fitted20180919_193936.thumb.jpg.8ca39953f14ad2f05ce1d4b125593ce3.jpg
20180919_193952.thumb.jpg.5e6f9bbba6dbde422dc2942773a10f71.jpgand a couple of holly planks being used to check the flatness of the forecastle deck
Previous builds-
Among others 😁
Unfortunately no work in the Sirius this weekend as had orders from above to make handles for the wife's sewing machine screwdriver and her unpicker thingymagig, First try at turning with the screwdriver and then went mad with some glued together strips for the unpicker, the small one in the middle is a piece of naturally two coloured ebony
The machine is a 1932 Jones in beautiful condition so I thought I had better put some effort into the handles to match the workmanship on the machine, she chose three so that means I get to keep the bottom right for one of my xacto saws bargain!!
Previous builds-
Among others 😁
Started working on the waterways for the forecastle another nice curved hook scarph
Previous builds-
Among others 😁
Also started working ln the carronades for the upper decks
Previous builds-
Among others 😁
Hi Paul I like the way the deck planks look on the cheerful they seem to have the right amount of texture. sometimes it seems that very uniform planks could almost have been scribed on a single sheet of very plain wood.
Michael
Thanks Michael, that was the effect I was aiming for after umpteen layers of sanding sealer
Regards
Paul
Previous builds-
Among others 😁
Forecastle planking completed, I had to go a bit further than I wanted and the wife wanted as I want to show the 9lb chase gun
All has had three coats of sanding sealer scraped with a blade between each coat
Previous builds-
Among others 😁
I noticed a little anomaly on the cheerful photo earlier and went to have a look at the Hull sitting in ordinary awaiting further work
There seems to be some sort of reaction going on along the seams, the whole Hull was flattened with five or six coats of sanding sealer, I used dark glue between the planks as I was going to leave natural at the time but then decided to paint using acrylic, the seam lines have risen since then??? Whilst I like the look, I'm not sure how or why its occurred
Regards
Paul
Previous builds-
Among others 😁
Hi
Titebond 2 dark wood glue between the planks etc, sanded smooth, sanding sealer and then Windsor and Newton acrylic paint thinned with water and about six coats if not more
Thanks
Paul
Previous builds-
Among others 😁
The chase port needed cutting out, still needs the sill adding in and filing square, tested with 9lb gun and carriage
At this time I believe the carronades were fitted on the inside principle so I have made the  6"x6" blocks to use as spacers ready for when bulwarks are built up
I have added a piece across the rear beam to infill ready for the balustrade which I'm going to try and do in ebony, hence the clips holding the front finishing piece
Regards
Paul
Previous builds-
Among others 😁
