This model is getting better and better every update. I like the evolution of the model and your buildingskills. They both amaze me. Cheers
Thanks greatly Kees.  I do the best I can with whatever I find.
Rob
Current build:
Finished build:
Current build(On hold):
Rob,
Great work on the winches and thinking outside the box.
Thanks Mark. I appreciate that.
I tend to work outside the box.  My default descriptor is; I will use anything or any material to achieve my goals.  I build scale ship models and in doing so, there is no prerequisite demanding one only use a particular material...ie(wood). That further delineation would be a purist....and I ain't no purist.  I fully appreciate purists and those who are building to demonstrate actual building practices or historical construction techniques, however, even they have to compromise based on wood selection and metal choice(No one is using white oak, black iron or hemp).
I use the phrase, *Paint covers a multitude of sins*.  And it does... on  real ships it protects against the elements and seals the wood and its seams...that is why you never see(or rarely) unpainted full scale ships. Some Smaller vessels are varnished but that is another subject.
Rob
Current build:
Finished build:
Worked on the masts today..
After turning them I tried several media for the bands with no good results.  here are the banded(pencil thus far) mast resting in place.
Current build:
Finished build:
I further reduced the masts in length bringing them into scale.  I then cut and applied nuclear grade cloth tape(extremely sticky duct tape not available to the public) to simulate the banding and then applied the chafing band.
Current build:
Finished build:
I sealed the tape and wood with a coat of epoxy paint.....let dry.
Current build:
Finished build:
Then finished up with white paint.  I have to finish the (McKay mast...as it was dubbed at the time) next...it will be varnished not painted..
I still have to fashion the mast boots to finish off the deck and then add the fife rails.  this all has to happen before I afix the tops to the masts.
Rob
Current build:
Finished build:
masts look really good.......the tape banding works very well.   I believe they call them woolings.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Yeah..this tape is so sticky and I put the roll on the lathe and cut a nice even strip...so all the bands would be exactly alike.
It paints well too...no one would know unless I told you.  Which I did.
Rob(thanks)
Current build:
Finished build:
I just thought they were iron hoops, .....Interesting.
Rob
Current build:
Finished build:
Very clever use of a device designed for a completely different purpose, it takes a particularly observant person to be able to see these sorts of opportunities.
The winches look really good.
Michael
No Roger...the smaller diameter is the portion of the mainmast that is within the doubling.  These masts were of the Forbes design topsail..so the extra long doubling was hooped as was the lower mast portion.  I have not added the cheeks or any parts of the trestle tree yet.
Not sure if I am going to first mount the mast then add the tops or build the mast entire then secure it to the deck.  I have to go through the fife rail and if the mast is not completed I can fix it to the deck and make sure the rake is correct...then I can slip the foot.boot over the mast and then slip the fife rail down and secure it in place.  This cannot be done if the top is installed first.
I'm planning out my next move.
Thanks for posting.
Rob
Current build:
Finished build:
Michael
Thanks Michael....
It is my nature to adapt or otherwise redesign another's engineering to suite my needs.  This habit saves me time and energy...mostly saves me effort to have to fabricate items totally from scratch.  I employ this habit in all my builds.
Thanks again for noticing.
Rob
Current build:
Finished build:
After lengthy searching I found the appropriate version that nearly represents the Great Republic as she sailed down from Boston to NY.
One item that will be altered is the lower spanker mast which was not painted white, but was varnished to permit free movement of the spanker sail mast hoops.
As depicted in lithographs of the period and described by eye witnesses(Such as Duncan McLean) she had no sail higher then Royals forward and aft.
This a good representation of how I will depict the beautiful Great Republic.
It is prudent to mention that most images and paintings of her show her with 6 sails per mast...this was her final representation after she was rebuilt...this was because her overall sail plan was reduced(doesn't look like it when you go from 5 sails per mast to 6)...but the size of each sail/yard was reduced significantly...so in reality she actually lost several hundred yards of canvas.
No wonder she was originally called the *Behemoth*.  She was HUGE with the largest main yards (120ft) ever placed on a sailing vessel.
Rob
Current build:
Finished build:
Tinkered on the GR for a bit and added the cheeks to the foremast.
Current build:
Finished build:
Another
Current build:
Finished build:
Thanks Patrick.....The masts are temporarily stepped...so I can remove them to finish the tops and add all the hardware and eyebolts
I hope to finish up all the tops this weekend.
Rob.
Current build:
Finished build:
Thanks Russ and everyone for all the likes.....
I worked  about 40 minutes on the GR and finished the first top...2 others will proceed in similar fashion.
Rob
Current build:
Finished build:
Thanks Russ.  Before the top gets mounted on the mast head...I still have to mount all the eyebolts for the bunt/leach line blocks.
Rob
Current build:
Finished build:
Just so no one is confused(especially myself).....  the Fore/main/mizzen lower masts doublings will be painted black as will the top mast doublings.  I left them white and was waiting till the mast is fully assembled before painting them.
The top masts and topgallant masts will be Varnished...only the doublings will be painted black.
More later....as later gets closer.
Rob
Current build:
Finished build:
Finished the foremast top.  I had to make 3 sizes of eyebolts for this build and set the medium bolts for the clew/leach line blocks.  They were probably painted....because black iron rust horribly in salt air.
After I finish all three masts..I will add the deadeyes and futtock shrouds.
Rob
Current build:
Finished build:
Well..I'm almost there.  Here are a few images to bring ya'll up to speed.
I finished the tops and rigged them with their eyebolts...now I'm focusing on the spanker mast.
Rob
Current build:
Finished build:
Well after lots of quality time working on the build...I finished up the spanker mast....oiled it and the jimboom..tinkered on a few other minor details..I think I'm done for the day.
What's next.....
Well I still need to rig the top deadeyes and futtock shrouds on each mast and then rig the topmasts and so forth till I'm done with the masting.
Here's a couple more pics.
Rob
Current build:
Finished build:
Sorry about all the clutter behind the model...it's just too big to move around all the time for images.
I have to make sure I pay close attention to getting all the mast hoops for the spanker sail in place before I mount/step the spanker mast.  So too for all the other masts that will be having pin posts added to their bases.  I probably won't secure the masts till they are totally complete.
Clear skies and smooth sailing .......
Rob
Current build:
Finished build:
