Thank you Steven! Yes the 30 ton cutter was only 48.6! That's smaller than even the Sultana and was effectively a pilot boat. I do plan on adding some swivels on the aft portion but yeah one gun pretty much. While I can't say for sure what the real Active actually looked like she did have one gun and was 38 tons. It seems that most of the other cutters were built on the 50 and 70 ton lines very few were this small (if any). The reports from Irving King Coast guard cutters book states that at the time Captain of the Active was in desperate need of additional ships to help combat piracy and a one gun pilot boat was hardly up to the task. By 1824 many more of the larger ships were added to the squadron and shortly after the Morris class took over and the issue was largely delt with.
Build on hold: HM Sultana 1/64th scale
Current Build: 31 ton Doughty revenue cutter as USRC Active 1/64th scale (in progress)
Future Interests: Ballahoo, Diligence, Halifax and beyond...
Hi everyone. A quick update. Decided to make a bilge pump since the ones available to buy are either too big or cast metal. I enjoy making tiny things that work. :) It's about 3/4" and all made from scratch. I glued wood strips to make the octogon shape and the nozzle at the bottom is a 1mm crimp bead. The black strips are electrical tape. The hinges are wire and can move the handle up and down. :)
Edited by CharlieZardoz
Here is the pump on deck. I am wondering of the handle is correct I wanted a bit of contrast but perhaps the top should be flush?
Also you can see the brass axle for the carronade carriage and the cleats added to the deckhouse.
Good looking pump and it works which is a bonus.  As for handle length...  it might look too long to the eye but how does it measure up to full size?
Eh I popped it off and shrunk it down a bit about 1/8" an inch. Now it looks right to my eye. :) I love this hobby in that you don't like how something looks you can just fix it. For me it was a practical space issue this is a very small ship so now it's 12 mm or 2.5 feet. (see correction it's actually 18mm/3.75')
That's good to know. I've studied the cheerful pump plan and basically made a variation from a few that I've seen (hms Badger, AL's Dallas and the pump provided for Sultana).  Also I re-measured and realized made a mistake the pump handle is 18mm not 12 which is about 3.75' (was late must've been high off tung oil fumes :D ), since Cheerful is a larger ship than this cutter I think the size is fair to avoid crowding on the tiny 16' wide deck. :)
Oh also planning on smoothing out that pump at the handle... just a bit ;)
Using a 3D printed program I made little teeny windows for the deckhouse. The left upper image you can see the inner frame is beveled/rounded. The upper right image you can see a ledge where I can place a small glass or plastic pane inside. I also finished planking the front of the house.
I think dimensioning parts is often a compromise between historic accuracy and what pleases the eye...with emphasis on the latter.  No one is going to measure the handle length with a ruler. So the “eyeball” test maybe more important.  Nice work overall, Charlie.  Looks great!
I’ve been troubled by the looks of pump handles on my models, as well, trying to reconcile a stubby handle with the need for leverage.
Ive often wondered if longer handles might not be removable, like capstan bars. Though, I’ve never seen that detailed.
Steve
"If they suspect me of intelligence, I am sure it will soon blow over, ha, ha, ha!"
-- Jack Aubrey
Builds:
Yankee Hero, Fannie Gorham, We’re Here, Dapper Tom (x3), New Bedford Whaler, US Brig Lawrence (Niagara), Wyoming (half hull), Fra Berlanga (half hull), Gokstad Viking Ship, Kate Cory, Charles Morgan, Gjoa
Believe it or not I've actually recarved the handle piece to something more curved as so. I didn't care for the thin handle this looks more like the diecast handle does and probably more accurate (length still the same though). Haven't attached it yet so didn't post a picture here it is overlayed on top of the old one. ;)
Good morning all. So thought I should give an update for the week. I finally attached the wale and true keel. This was quite a challenge as the wale was a 1/16" by 5/32" strip of boxwood so learning how to curve the wood on this very sleek hull shape was a challenge. I opted not to spile since I wanted to maintain the sharp shape of the strip and also its such a small model (the front half of the wale is 3"). Anyways it worked with a bit of assistance as you can see in the pics. :)
So what you see below at the bow is the keel minus the beak. That piece will be added later. The keel and wale will be painted black so thought it neat to leave the beak tip unpainted to add contrast. The reason why I chose boxwood for the wale over cherry is so it doesn't splinter but also thought that even if painted there may be a slightly different grain texture to make the wale stand out. The back of the wale curves slightly upward and gets thinner at the stern. Also the wale is in 4 parts. Front and back halves which join at the middle but also an upper strip which is 3/64 by 3/64" boxwood. This made a little ledge at the top of the wale where I can place the deadeye channels and also a holly strip to add a white molding. The above railings and bulwarks I will add after finishing the planking to avoid banging them around and getting damaged.
The bow image where the two wales meet shows a bit of spacing where the wale meets the keel. Did the best I could but will use some wood putty to fix that since it will be painted anyway.
Looks nice. One question: it appears that there are two joints amidships at the same location; curious why those aren't staggered?  Or is it an optical illusion from the photo?
Edited by Cathead
Hi. In this instance I am treating the wale as one piece. In reality it probably would have been more though in my mind I was picturing a ledge and once the holly strip is laid over it, any indication will be covered up. I will stagger the holly piece and the decking but good observation! :)
Hi all. So here you see the next plank below the wale is done and the wood strip was cut into 3 pieces each about 3 and 1/16" or about 17' real life. The front piece was spiled from a wider plank to get some shape to the hard curve the back was tapered slightly to make room for the transom. From this point itll just be a matter of the planks meeting in the middle. The stern definitely needs steelers/drop planks. The front will need more tapered spiled planks. I may modify the shape of the existing planks a bit depending on how the next strips naturally bend.
The wale ledge to the planking material might be ever so slightly steep but I wanted it very pronounced since many issues I've seen with this model is that the wale is not raised enough and blends in. Since this whole area will be painted black that contrast should be nice and pronounced.
Here you can see the rough estimates of where I will have the planks end. I am using the rule of every 4th repeating via the diagram below. This makes an interval between planks of about 3/4" an inch or 4' maybe a bit small but thought doing every 3rd plank would not look as neat. The planks themselves as stated before are around 17' the lower planks are not cut since they will be covered in cooper however I did use pencil lines to get the overall planking pattern down so things look as they should. This is all very new for me so having the lower planks detailed like this means I can practice then potentially cover up my learning curve with copper plates ;)
Nice progress, Charlie and also what sounds like a good plan.
Thanks Mark. I am really liking the way its looking so far. Here you can see the curve up to where the transom pieces will be. Also using walnut shade wood filler I've been filling in any tiny spaces left between the planking. Thin it out with some water and you it does the trick. Next up is to finish the planks in the front. To make the spiled pieces I will use cardstock forst to make the shapes then transfer over on a veneer sheet.
Hi Charlie -
The planking is coming along nicely.  Your technique with the thinned putty is a good one and should work well for you.
Something that works for me when spiling is to first lay on a piece of frosted tape over the curved area to be planked, then draw the plank shape on it.  Take it off and lay it flat onto cardstock.  Cut it out to make your pattern.  When you are confident, you can lay the tape directly onto your planks and skip the cardstock step entirely.
Dan
Ha! That's a nice one! Well here it is now with two new spilled planks and while I think I did a fairly decent job with the cardstock to wood I am noticing the planks look slightly thicker when curved toward the bow before tapering inward. I don't recall cutting them thicker so I think it may be the natural effect of wood curving and wanting to straighen out. That said I realize that drop planks will be necessary to avoid crowding. Likewise the inclination of planks at the back means a few Steelers as well. But overall it looks decent er I think :)
Hi Charlie -
The shipbuilders' rule is that no plank should ever taper to less than half its original width.  When you find your spiled planks getting that narrow, it's time for a drop plank.  Now that you have some planks laid, you can pencil in the rest of the strakes to see where stealers will be needed.
Looking good.
Dan
Looks great, Charlie.   What Dan said...   She'll be looking perfect in no time.
Ok so here is how I placed a steeler. The main planks are 7/64" thick so I used slightly thicker 1/8" inch and shaped the edges to meet. So basically the steeler and two surrounding planks were made together then assembled on the hull. Will do the same with the drop plank which is next.
OHey msw folks! Thought it was time for a new update. Every day I add a few more planks you can see where I am now. The drop plank is in place at the bow and looking like I will need at least one more. I feel like there may be some minor crowding at the bow which I think is the result of such an extreme form bending the planks a certain way and assuming it looks as it should. Pretty much all of the bow are spiled planks so getting them just right is a learning curve as well. I initially layered the planks in a step fashion like you would a deck but looks like it was more random so going to mix it up for the last bit. ;)
Yeah in some ways you are right. However I think its relative to the subject matter. The larger 80 ton hull I have is pob and I simply do not have to worry about hull shape. However adding some balsa wood between the frames can be a nice way of adding structure after the shape is ready to go. But I do think solid hull helps the novice understand things about woodworking they may not if their only experience begins with plank on bulkhead. And especially for small hulls and simple hulls like this one it taught me alot.
