9 hours ago, Dr PR said:
vossiewulf,
The "jib inhaul/outhaul/halliard ring thingy" is called a "traveller." There are some other things called travellers, most (all?) involving metal rings that slide along some kind of boom or rod and provide a place for tackle and rigging to attach to - like the ring that the boom sheet block will attach to on the "horse" (horizontal metal bar) at the stern of your model.
You must have great patience to be manually serving ropes with that very tiny thread!
Your bock holder is a nifty idea. I'll have to make one for myself when I get back into rigging.
Have a happy holidays!
Thanks for the explanation, Phil, I'm trying to absorb the topic of rigging now and every bit helps :)
Yes, it takes patience to serve line with fly tying thread, but I'm hoping it will get better with Chuck's serving machine, that is making its way through the mail to me.
As for the block holder, make one carbon fiber rod about 1/8" longer than the other, this makes getting them both into the blocks much easier as you're only doing one at a time.
26 minutes ago, vossiewulf said:
No Gregory, those are standard Syren wood blocks.
OK that brings up my next observation.
I never cared for the bright look of Syrens boxwood blocks, but there was not any alternative that came close to the shape/quality.
Myself and others found that the boxwood did not take traditional wood stains very well.
I experimented with Fiebing Leather Dye  ..  Just another option you might consider.
The difference in color here is the lighting.  With hindsight I would have polished them a bit more.  I would like to get more of the look I see on contemporary models.
― Jimmy Buffett
Slow crawl:    Rattlesnake
I am using ethanol-based dye stains like they use for musical instruments because they don't penetrate much, and if they don't penetrate it's hard for the result to be splotchy. But it was anyway, I'm not happy with the results I've gotten so far. So I'll take a look at the leather dye, thanks.
While I'm here, I finished the blocks on the jib boom eyes.
And then I took a hand at trying to create thimbles 75% of the size that Chuck creates in his Cheerful instructions, and I can report that making thimbles out of 1.2mm OD brass tube is not easy. The cuts in the tube have to be square and parallel to each other, and no matter what you cut the tube with it leaves a tang of uncut metal that needs to be removed with a small full-flush side cutter. I made a blunt-curved end brass rod per Chuck's suggestion and used that with a little chasing hammer to tap each side of the pieces of tube to form the curve of the thimble edge. Not easy to get consistent results and you really need a reasonably thick piece of brass to go under the tube sections when you're tapping.
I ended up cutting the tube sections on my Byrnes saw while holding my hand right over the blade to catch the tube section as the blade hurled it in some random direction, and then clipping off the tang under magnification.
As noted I wish there was more consistency in the results, I'm trying to be as consistent as possible with the number of taps and how hard they are, but I've still got some variation. I'm going to stare at these for a day or so and decide if I want to try again for improved results.
The Fiebing's is alcohol(ethanol?) based but I seemed to have gotten pretty good penetration.  I would suspect the formulation might be different across intended applications.
One caveat to keep in mind is that DrPR talked about using shellac on some of his block rigging and the dye was bleeding into the rope.
Not a problem if you don't use shellac.
― Jimmy Buffett
I was trying to use the shellac to shape the rope. Shellac is an alcohol solution. Fiebing leather dye is alcohol based. If the alcohol in the shellac wicked down the ropes to the blocks the dye bled into the ropes, discoloring them.
I also had problems with the light brown stain on the wooden blocks. The end grain is more porous that the side grain, so the ends of the blocks soaked up the stain and are almost black. The sides stained OK on the smaller blocks, but the sides of the larger blocks were splotchy. I think this was caused by glue on the wood from the sheeve pins in the multi-part Syren blocks.
All in all, I think I would have gotten MUCH better results with just painting the blocks.
Phil
Current build: USS Cape MSI-2
Noted :)
Been making the driver boom, I think that's what it is called, the main fore and aft boom, not sure why other than it's one of the things that needs to get done. I also received my Servomatic machine from Chuck, so I will be putting that together tomorrow, I need it to serve the stays as the intent is to have them fully served.
Not sure how many people remember at this point but one of my crazy ideas that worked really well was the doing the black of the hull not via brush or spray, but via pen. I got Faber Castell india ink archival waterproof ink pens and colored in the hull like a 3D coloring book. It was very easy and low stress and I like the result better than paint- a single layer of paint at 1:64 scale is like 20 scale coats and detail is lost. The film thickness of ink is negligible.
Anyway those original pens are long since gone and while I wait for Faber Castells from Amazon (Jan. 11?! bah) I tried some pens I found locally that also claimed to be india ink archival black pens.
We can see at least one of them is lying, it's not black it's dark purple. That's like the "black" of Sharpie pens, it's actually dark purple. The other one is desaturated but it looks more dark gray than black. Guess I will have to wait for the Fabers.
Like I said working on driver boom. For those interested in the process, I started with square Castello boxwood stock and made it octagonal using my model maker's palm plane. I then took it to the lathe, and rounded it and tapered it down at both ends, the thickest section is about 1/3 of the way along the boom. I then took it off the lathe, and used the same small palm-plane to create the two angled flats to accept the cheek piece thingies.
I then ripped a piece of boxwood to about 2.5mm and drew out the side pieces, then cut them out with a fretsaw and touched them up with the Nakanishi micromotor.
I used black gaffer's tape for the iron reinforcing bands, the white edges of the tape will go away when the whole boom is blackened.
And then I made and glued on the small wooden cleat.
Received the Faber pens and blackened the driver boom, then put a clear coat on it with Minwax Polycrylic. That turned out to be a mistake; although it had performed ok on a test piece, it didn't level on my driver boom at all and its sheen which was supposed to be matte is greater than I consider good for a satin finish. Now I'm waiting for lacquers from Mohawk, they mostly supply luthiers but I've found they're really good, level well and are very clear. We spray so little in a ship model that there really isn't much reason to avoid VOCs, while we do need finishes which smooth out well, are clear, and have a predictable sheen.
I also made the gaffe boom from more square castello boxwood stock...
...and finally got the right size nails for my chainplate ends.
Another quick update, I worked on the yards today. I had never had to turn small scale square stock into small scale octagonal stock (no Lennarth Petersson, I am not doing hexagonal) so I had to make a little v-groove jig. I made it about 50% longer than it needed to be for these yards so it will be useful in the future on larger 1:64ish models.
The plane is a Lie Nielsen model maker's palm plane. It's pricey like everything else Lie Nielsen but it's also very well made and is about the perfect size for ship modelers. One thing I really like is that the iron is 1/8" thick, very thick for this size, so you will get zero chatter with it. If you were going to buy a single plane for ship modeling, I'd recommend this one.
Anyway, the v-groove jig worked fine and I was able to put a good octagonal shape on stock down to 3mm.
I normally prefer dye stains to pigment stains, because dye stains are molecular, there is no pigment grit to be seen at small scales. But I'm going to try a gel stain from Woodcraft on my blocks. I've used General Finishes gel stain once before on a chest of drawers and it came out nice, so I'm hoping it might work better than the results I've gotten so far with the dye stains, which is very blotchy.
You know I'm glad I am doing the yards and masts in castello boxwood, not only can it be scale smooth, but it's strong and you can make tiny parts with it. Like these sling cleats... I think they're called that.
Otherwise, I received my Syren Servomatic from @Chuck. Chuck, it went together reasonably well and it turns easily and almost fully smoothly. And it's working with the fly-tying thread I wanted to use. The only downside is with your dark brown thread I need magnification just to see my serving :) I may need to use the tan rope just so I can accurately serve the ropes.
And I intentionally did not sand the char. I like cherry with black trim, going back to a customer furniture shop that I worked at 35 years ago that frequently used that look.
 Nice looking mast work, Vossie.
You are proceeding at marching pace with your Lady and the details you are implementing one after the other are amazing to me. Instead, I am stuck with my models.
Cheers, Dan.
One thing I also found with the fly tying thread is you have to give it some extra twist as you serve it on otherwise it lies too flat. Yes magnification is the way to go when doing the smaller threads.
The yard looks very nice
Cheers, Dan.
Your Lady Nelson is a very nice model, you just built yours more out of the box than me :)  Keep at it!
Thanks! As for putting some twist on the line, I'll try that, thanks :)
Some progress using the Servomatic. I can't say it's quick but that's because I am using very fine serving thread. After spending a few hours with it, I think the Servomatic is well worth the $60 or so that it costs.
But first, my tool addiction demanded I buy these cool baby Japanese saws from Lee Valley. They're made just like the full sized versions so they should last quite a while.
Now back to the thimbles that I made out of 1.2mm OD brass tube a couple weeks ago, I blackened them so they're ready to go.
And two fully served jib guys, or at least that's what they're going to be.
And we bring them together and we have thimbles at 1/64. I'm sure I couldn't do them at any smaller scale.
Yards and booms all done ready for rigging.
And the topmast done except for paint. The little knob thing on top of the mast was made separately and attached to the mast via a reinforcing carbon fiber rod.
Just need to make the main mast and we're fully go on rigging Lady Nelson. Actually I will probably follow Chuck's instructions and rig the bowsprit before making the main mast.
 Very nice, Vossie.
That is some excellent work mate.  Those thimble are just the right size, look good and the served line looks very realistic for a newly served line/rope.
cheers
Pat
On 1/11/2025 at 5:39 PM, Keith Black said:
 Very nice, Vossie.
cheers
Pat
Thanks guys, I appreciate it :)
Intead of more masting and rigging, I remembered I hadn't dealt with the swivel guns so I stopped to do that. First was mounting the pedestals (?) they mount on. This was somewhat fiddly work because of the changing sheer line curve and the tilt of the rails resulted in each one having to be fit individually to ensure they're perpendicular to the waterline. Which was a slight problem too, as the plans show the knightheads should also be perpendicular to the waterline whereas I unfortunately made them perpendicular to the rail. Now I have the pedestals and the knightheads pointing in two different directions which is annoying but nothing I can do about it now, getting the knightheads out at this point would be hard.
The pedestals were reinforced with carbon fiber rod dowels.
Here you can see the discrepancy between the knightheads and the pedestals. Also, I once again used the Faber Castell markers instead of black paint, which was very convenient.
I also couldn't stand the swivel guns that came with the Lady Nelson kit, they're really not very good. I did a lot of searching for alternatives but eventually bit the bullet and just ordered a VM Sherbourne kit as that has accurate guns and PE gun mounts. So now I have a Sherbourne kit sans swivel guns for cheap if anyone wants it ;)
Oddly, the plasticine clay seems to have removed the blackening from the PE swivel gun handles that were attached to each gun. I'll have to touch them up once they're mounted.
I painted the 3D printed guns themselves with Tamiya flat black. Tamiya flat paints have an interesting quality where if you rub them down post application, they get more satin and almost glossy. So if you take something like one of these guys and rub it down the high points of the reinforcing rings will become glossy while the paint in the recesses stays relatively flat. This accomplishes more accurately what folks are trying to do when they dry brush items to bring out details.
And all done, now to store these for mounting after the rigging is done. And I'll turn back to masting and rigging now.
Just FYI for anyone following, I managed to injure my back early last week and have been mostly bedridden since. It is getting better, slowly. Also I am kind of stuck on the Lady Nelson, because of the tight fit of the jibboom I will need to rig the forestay before mounting the jibboom, which means I need to make the mainmast first. I decided to replace my 7x10 lathe with a 20 year newer 7x14 lathe so I could turn the mainmast for Lady Nelson between centers, as well as accommodating the need to also turn much longer yards and masts in the future.
But of course there have been delays. Specifically the lathe arrived with the electronics box having been ripped off in transit, nice. So I am waiting for a wholly new electronics box from Little Machine Shop to repair the lathe so I can turn the mast and get back to making progress.
Hopefully between back and lathe I will be on the positive side of things by late next week.
Get better soon. Curious to see your new lathe. Good luck with it!
Dan
Sorry to hear about your back problems Vossie, best wishes for a full and speedy recovery.
Makes you wonder why some of these companies do not pack their items better.  I understanding making savings where possible, but packaging is one area that proper packing would negate the costs of replacements etc. Hope it all is still in alignment?
cheers
Pat
cheers
Pat
Thanks Pat!
The lathe was packed pretty well. I'm guessing it took a pretty significant drop onto concrete to rip the electronics box off like that. But thankfully looking at it it otherwise seems well, although obviously I can't run it to do thorough tests. But I am less than happy that I have to repair something that happened before I took possession of it, and I'm going to mention that to Little Machine Shop. I still have to replace my mill that died and I was assuming I'd buy the Hi-Torque LMS mill, but this hasn't encouraged me.
Dan
Thanks Dan! It's the C3 SIEG 7x14 lathe. It's basically the same as the lathe I have except it's newer, has a somewhat more powerful motor, and has a bed that's 4" longer. Long enough to turn a decent mainmast between centers, I'm really not confident I could do a good job with the top turning free.
Vossie, I pray your back heals and returns to normal quickly.
