HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 69 donations so far out of 49,000 members - Can we at least get 100? C'mon guys!) ×
Some light touch ups and then I will put on a protective satin varnish. The surface is sensitive to scratches.
Respectfully
looks super Per  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Dry fitting parts before gluing is a good thing. This way I can see when adjustments are needed or how attaching parts are to be located on deck.
One example is the Samson post together with the bowsprit.
This area is a tricky one, several parts going together in various ways.
Also I find the space under the main rail at the bowsprit very tight for a final assembled unit to be pushed through.
Will look into some other build logs for inspiration of how-to.
Respectfully
I swear our kits are different. My stern is made entirely differently.
Norwegian Sailing Pram 1:12 Scale. 2nd boat in the learning series.
In Dry Dock:
Muscongus Bay Lobster Smack. 1:24 scale. Model Shipways, 3rd in the learning series.
Not sure what'll be next, probably the Santa Maria by Artesania Latina 1:65 scale. Unless someone has a better suggestion for a beginner.
Pride of Baltimore. Model Shipways. Clipper used in the war of 1812.
Black Falcon. Mantua Model. 18 century corsair brig.
CSS. Alabama. E. Manolie? Can't read the font. Build in Liverpool in 1862 for use in the American Civil War by the Confederates. Steam and sail, sloop of war.
Of all the things I've lost, I miss my mind the most.
A baseball cap my Dad wore.
To get some decent curve to the main rail I used regular clear tape and out it on the plans.
Same thing was done transferring markings for eye and bolts going into the rail.
From there I traced the outlines and transferred to the strips.
Doing both port and starboard at the same time I am somewhat certain of getting the same shape to the parts.
P1030884.thumb.JPG.5bb14dd8199ef6c27b29f39b53c62b95.JPGP1030887.thumb.JPG.eb18159cf365c61cda6f93391d85d146.JPGP1030885.thumb.JPG.bbe8a8260289f4a376f872f337d4cac6.JPGP1030886.thumb.JPG.c2b3dd7ba7174e22d3ba855f25538827.JPG
Respectfully
No laser cut rails? :o
No laser cut rails!
Hand made by my delicate hands........:P:rolleyes:
Respectfully
most laser cut rails don't fit right anyway ;)    nicely done!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Using the plans I lifted the layout for the main rail, transferring it to the .5" wide strip and shape them there after.
Here they are in place but not finished nor glued.
This is the first time I am using vimeo, if this works I will continue use the media.
Feedback is welcome in this matter.
Thanks all
Main rail
Edited by Nirvana
Respectfully
Steve, thanks for the feedback.
It was more of a trial using the video.
I am to re-post the maintain construction.
Info regarding Vimeo, if you can stay below 500mb clips per week and 25gb per year it is free.
Yes, there will be ads in the beginning before your video is shown.
Respectfully
Bill, I used both methods.
I was fortunate that there very little differences.
What I don't like is the thickness of the material. It is too much "meat".
It doesn't look  proportional.
Respectfully
Too thick is good. You can always take em down till they look right. Too thin and then you need to start over.
Edited by reklein
Bill, in Idaho
Completed Mamoli Halifax and Billings Viking ship in 2015
Next  Model Shipways Syren
So I am getting to an end of manufacturing the main rail parts.
Using both the plans and yacht I feel I have got a good fit.
After the last part been cut and trimmed, sanding and pre-stain is next before painting.
I worked from Stem and Stern to get my parts correct.
5a6d1013560e9_mainrail1.thumb.JPG.6aba5115a640ad289b652ffddf555640.JPG5a6d1017532b9_mainrail2.thumb.JPG.b11041c1fafbb1eba0b2721efc742385.JPG5a6d102043c88_mainrail3.thumb.JPG.9f71a06703e8e78b2644016c843246b0.JPG5a6d102703720_mainrail4.thumb.JPG.3551a3207502bc4b0460939228142aeb.JPG5a6d102b6d64c_mainrail5.thumb.JPG.9f5203804a58e7c253dcaf25123f3df3.JPG
Respectfully
Hi Per
I find rails quite tricky. Your approach seems to work well so I may give it a go next time.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Keith, I found the approach workable.
Less headache.
Respectfully
I make them similar,  but I don't do the scarf joints.  I should give it  try  ;)    look really good Per!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Dave,
I used the stem and stern piece as a guide creating the other scarf joints.
Respectfully
Getting the hawse pipe opening is a tricky part.
Here the two britttania pieces are mirrored and on top of that, several angles involved.
Attaching blue masking tape to the waist, I measured 30mm on the plans and transferred the measurement to the tape.
This would mark the aft part of the metal part. Next was to measure the top and bottom of the opening for the hawse pipe.
Using the metal piece I traced inside of the part. I did the starboard which is on the plans.
Doing the port side was a little trickier.
But at the end I got the second opening right. Looking at the stem it looks like Bluenose has gotten eyes.:D
Now I have the delicate job of drilling the hole for the "eyes".
Respectfully
It took some effort and meditation before I put the drill into waist for the hawse.
Port side is being worked on, using my home made template (masking tape) I worked slowly.
According to the plans the hole going through should have 2.5mm diameter.
I may open it little more to insert a tube, which is not necessary.
Doing so, I have been able to create an opening that I feel okay with.
It will be interesting to see how bad it is after removing the tape.
Respectfully
Moment was to remove tape and reveal the damage.
There is more trimming to do, but so far so good.
Haha, looks like I caught myself a fish......
It's a blowfish
Respectfully
Long time ago my son was into Warhammer game, so we went to buy some characters for him.
A little project we did together, mostly him.
But in the box with brushes and dried paint I found this three piece set of files.
The grit is good enough for wood as well, which was really helpful to finalize the opening.
The files can be found in any hobby store selling Warhammer game characters.
files.JPG.15cc0c4f0300c2a7fdf71533256014fb.JPG From top to bottom; coarse, medium and fine grit.
A tool I like to recommend to all modelers.
Respectfully
Waist inside has gotten the second coating of white.
The waterways was painted with Valejo sky grey. It gave the deck and white a nice contrast.
First part of the mainrail was glued into place. Here it's important to make a solid contact all the way. I don't want to see any light showing through with the waist.20180204_210809.thumb.jpg.fac969e68850ee71b81e05c527c884ec.jpg
Respectfully
Additional three pieces for the rail was attached this evening. Using Titebond II and heat from my hand, the part set hard and fast. Even though I made scarf joint, they are now hidden under the new putty.4261.thumb.jpeg.b821d79b512b014444e672736e7a6aa4.jpeg
Respectfully
Trying out my new 9 dollar camera.
WIN_20180210_20_53_44_Pro.jpg.191ee0b9040bc38c3748691ea952ab5a.jpgWIN_20180210_20_47_18_Pro.jpg.917a47098c3ce801c457f592ea2c3434.jpgWIN_20180210_20_50_24_Pro.jpg.1a4f8c59e91b25b267c3de64334ba042.jpg
I can see a lot of potential use of this camera, which I can use both with my PC ( no issues at all with connection, Windows 10 recognized it directly) and my android.
None of the pictures are edited.
And here is the camera itself.
Edited by Nirvana
Respectfully
Per:
You are making good progress.  Nice work on the railing and the hawse holes. Your deck is looking good.
Russ
Had my Sunday all to myself, some fiddling and trimming and now the main rail is in place.
Really pleased with the result.
All the parts fit to a majority, some filling was necessary. This auto-putty is a pleasure to work with.
But takes some extra paint cover to the connection areas.
5a8a629fa39e2_mainrail6.JPG.cd5583dbd272607416cca05002099422.JPG5a8a62b8ebfeb_mainrail7.JPG.b1caa6c3105b1d4d1f3706401a326782.JPG
Respectfully
Nothing more nerve wracking than drilling a "simple hole" in the side of your boat B)
