You're welcome Ulises
I'm confident you'll do it right. The styrene strips offer one advantage : as long as you are not happy with the result : wrip it off. I can assure I did
Well here it is : oars and other stuff coming from the mini kits were added.
However, the barrels were bought in a shop in Antwerp
Also my latest acquisition : a Proxxon lathe.
Kind regards
Christian
"The original always beats the copy"
(supportive statement)
Thank you Christian. One more question if I may: What paints did you use?
Can't wait for your review of that lathe.  ^_^  ;)
Edited by Ulises Victoria
There aren't but two options: do it FAST, or do it RIGHT.
Current Project Build Log: Soleil Royal in 1/72. Kit by Artesania Latina.
Last finished projectsRoyal Ship Vasa 1628; French Vessel Royal Louis 1780. 1/90 Scale by Mamoli. 120 Cannons
Future projects already in my stash: Panart: San Felipe 1/75; OcCre: Santísima Trinidad 1/90;
Wish List: 1/64 Amati Victory, HMS Enterprise in 1/48 by CAF models.
So much to build, so little time!
Hi Ulises,
Thanks for showing interest
Humbrol paints were OK but I made the decision to move over to Acrylic paints and the A.V. (Acrilicos Valejo) brand deliver quality.
Here's an overview
Regarding to the lifeboats : I can recommend the paint with ref n° 311 New Wood : it's -in my opinion- pretty close to the "wooden" look I was aiming for
Kind regards
Christian
Hello Again,
Especially related to the lifeboats , here's my proposal : this evening I'll post an overview that depicts what kind of paint I used for a specific part of the lifeboats .
Feel free to ask questions or make comments/sent feedback.
Kind regards
Christian
Hello Again,
Awesome! Thank you very much! Will follow with interest!
Hi Ulises,
Here's the painting scheme
One drawing for the 3 different lifeboats, having the :
- 32 ft the largest (red colour )
- 22 ft the "in between" ( green )
- 18 ft the smallest ( blue )
according to each ship I mentionned the colour code
All three received the same small styrene strip painted in Tamiya XF10 Flat Brown.
Two details :
1) go for quality brushes : it's money well spent
2) also on the main ship : whenever possible I try to paint different parts before  fixing them
Kind regards
Christian
  • 2 months later...
Hi,
Update : lower parts of the masts (more or less) completed.
As B.E. suggested I used Ramin (or something lookalike) for I was not keen painting them. Furthermore, I omitted the black paint between the cheecks for aesthecal reason. By chance I had some spare dowels at my disposal coming from previous builds, although some fiiting to correct diameters according to building instructions were required.
A word of caution related to the bowsprit. ( see pics in attachment ) Part n° 48 .
Unless I overlooked something, one and the same part can hardly being used to 2 different purposes. Meaning the same mastlock for bowsprit as well as mizzen-mast.
But there was another snake in the grass : the bowsprit makes an angle towards the horizontal line of the ship. If the two holes in part n° 48 are plain vertical and the same part fitted on the bowsprit is supposed to stand vertical : there's a problem. The holes should be fored under the same angle to compensate, I guess.
I wonder if other Diana-builders had this same experience ?
So I made the lower bowsprit lock from scratch using the original frame, so I had already the correct thickness.
Among many kit builders I also share the dream building a ship from (semi) scratch - plans only. So if I can't manage a mastlock, that would be shameful, n'est-ce pas ? ;)
Next step : why not the shrouds ?
Kind regards
Christian
Christian - I think its an error on the plans.  Part 107 is the mizzen cap (not part 48 as indicated), part 48 the bowsprit cap.  I don't like the way that that bowsprit cap is predrilled because as you say, it needs to be corrected to the angle of the bowsprit and its harder to do that properly as supplied - just my opinion.
Everything is looking great by the way.  In Mount Everest terminology, you're up at Camp 3, I'm still making breakfast at basecamp :D  Where did you get the ramin wood, is it straighter than the dowel provided? - mine is quite bent.
Cheers,
Jason
In the shipyard:
Wow Christian......
I've bin not looking for a while and I don't know why but Man, do I missed a lot !!!!!!!
Your little ones are just what I was looking for ....so I'll be coming visiting you for a cup of coffee and when I'm leaving you need to make other little ones  :D  :D  :D  :D
Nice Lathe also !
I have the same one and see if you can found an extension bed for the lathe !
I have one and I have all the benefit of it !
Sjors
Hi Christian,
I don't know how the hell I missed your build until now, I'd like to pull up a bench and follow along if you don't mind, ( better late than never ).
Your whole build is looking fantastic mate and those ships boats are great.
I generally use Admiralty paints, they give me the pigment I'm looking for without having to go over the object again, but each to their own and as long as were happy with our choices what does it matter.
Be Good
mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
Hi Jason, Sjors & Mobbsie : you're all more than welcome
Jason, referring to the dowels : tough question
- Here's a pic of my already limited supply, and sources are different. A part are leftovers from previous kits but all coming from old continental brands such as Mamoli, Mantua and Corel.
- Besides, those kits were completed long ago and before the internet-era. There were more retail shops related to modelling in business and they had an important supply : dowels, ornaments, all kind of fittings. But that's the past and those days are not coming back for sure, I'm afraid.
Nonetheless , if I were in your place : why not contact a retailer such as Cornwall Model Boats ?.( there's no personal interest involved)  I believe brands such as Mamoli, Mantua and Corel are incorporated in their stocklist.
Moreover : I'm ginving it some thought to make the same move : I like the contrast between the yellow looking wood ( without paint ) and the black parts, as the walnut dowels do not seem very appealing to me.
While making shrouds : there's plenty of time.
But first , I'll complete the cross- and trestle trees.
Kind regards
Christian
Hi Jason,
In addition to previous post(s) : I had plenty of 12 mm dowel in stock , by consequence for main, foremast and bowsprit I had to reduce the diameters by 2 mm .
As my lathe didn't allow dowels longer than 250 mm, I needed other options for main and foremast.
So back to "old school methods"
I sanded and used this level tool until diameters fitted. The slots in the outside garden table come out to be very convenient for this job.
Far from being a specialist nor engineer my guess is that it's perhaps better to compensate a curve or a bent piece in "stand still" position  rather while rotating ( in a lathe ).
I hope this helps.
Kind regards
Christian
A very clever solution, Christian.   I never thought of that with regards to a dowel even though I've done similar to large planks.
Thanks Mark & Jason and all the likes.
Combined with a caliper, the level tool was quite inhandy for the job.
By holding the dowel close to the leveltool against the light, the exeeding areas came out nicely.
Given that the diameter of the "curved " dowel allows this and the curve is not that big, this might help
Kind regards
Christian
She's looking wonderful Christian, what a fine model you are creating.
I had similar issues with the Bowsprit cap on my Pegasus and ended up scratch building it from  boxwood. The main issue was that the cap should be wider and the hole off centre to allow for the Jack staff to be accommodated on the Starboard side. Apart from this the kit provided part was of poor stuff and could not survive the rigours of shaping the hole to allow for a vertical fit of the piece.
Cheers,
B.E.
Thanks for the praise, BE and all the likes for showing interest.
While we're at it , meaning the Bowsprit cap : before fixing, if my interpretation of the AoTS (regarding HMS Diana) drawings is correct, it appears that the same bowsprit cap also makes an angle in front view. In other words : bowsprit and jibboom are not 100% "vertical-perpendicular" in front view.
All input regarding this specific matter is welcome.
Kind regards
Christian
Hi Christian, sorry to appear obtuse but I'm not entirely sure I understand what you mean by "not 100% vertical-perpendicular in front view".
From the side view the cap is vertical to the waterline. The top and bottom chamfers are angled to the stive of Bowsprit and Jibboom, and so are horizontal to the line of those spars. There will be  slight variance in the gap between jibboom and bowsprit as it passes thro' the cap due the bowsprit taper which gives the impression that the jibboom stive is at slight variance with that of the Bowsprit, but from head on the cap looks vertical to me. (well it does on my Pegasus)
I see the arrangement for Diana is the same as for Pegasus with the cap being slightly wider to starboard of the jibboom hole to allow for the jack staff.
B.E.
Hello
Thanks to BE the problem related to the bowsprit cap is resolved
Rigging and mast part started with the shrouds :
I secured the shrouds near the mast top with Guterman thread col n° 36 (dark grey), as I wanted a little contrast with the black shrouds. Besides, the thread is rather thin which suites me fine as I wanted to avoid "sausages"
Same remark about the lanyards : they're supposed to be black but I went for something more pale. The only problem I encountered was the necessary small drop of glue : it affected the pale color, so I carefully overpainted with diluted light grey. I'll see about some extra trimming : I'd like to remove the protruding parts of thread as much as possible without damaging the knots
The thread I used for the shrouds is - regarding the thickness- a compromise. I did not use the one supplied in the box
Almost there  :rolleyes:
Kind regards
Christian
Hi Christian,
Looking really good mate. Glad you were able to get your cap sorted.
For getting really close to trim a knot try using nail clippers, the ones with the sprung lever, they work for me and you can get really close to the knot, a word of caution though, you can get too close and then it's that time when every woman learns to cover their ears.
Hope that helps mate.
Be Good
mobbsie
mobbsie
Next Build :-
Hi Mobbsie : thanks for the tip ( nail clipper)
No need to worry about Mrs. Barbossa covering her ears :
1) I'm working in the attic
2) Any music will do to reduce some awkward words or expressions
Also thanks for the likes : much appreciated
Kind regards
Christian
Nicely done Christian...
Almost ready for the ratlines ?
I'm doing that at the moment and every time when I finished one ratline I will put some glue on the knot so they stay where they have to stay.
Sjors
"Almost" indeed Sjors. Thanks for showing interest.
Diana is far from completed : so I 'll alter ratlines with other fittings/stuff.
Although....there's little shipbuilding scheduled this WE.
The reason is simple : after a long period of almost ghastly weather ( rain, cold, grey,  wind..you name it) we're enjoying-finally-some sunny weather.
In that respect, I presume little difference between Bleiswijk and Zottegem ?
Kind regards
Christian
No difference Christian.....
Sunny and beautiful weather in Bleiswijk   :D  :D  :D
Only working in that weather and not going to the beach  :(
Aggy is also long from complete.
Take a look at the log and you will see what I mean.....
Sjors
Ratlines & Shrouds : intermediate update
Hi people : here's the actual status, almost halfway.
For the ratlines I used Gütermann thread color code 701.
The dark grey gives just that little contrast I was looking for.
Although it's (always) recommendable to follow the instructions, here I'd like to quote the Caldercraft's  "Ratlines chapter"  :
" When all the ratlines are finally tied, stain them by carefully brushing on Indian ink"
Has anyone ever tried this ?
Even with the necessary precautions, only the thought of spilling a drop of ink on the hull/decks makes me feel a bit incomfortable.
Kind regards
Christian
Hi Christian, neat work on those ratlines, did you use clove hitches or a simpler overhand knot to secure to the shrouds? I can't quite see from the photo's.
I'm not quite sure that it's (always) recommendable to follow the instructions, Caldercraft are pretty good as kit suppliers go but there are usually errors and simplifications in kit rigging instructions.
The idea of staining ratlines post fitting with Indian ink fills me with horror and is fraught with risk. Where required I will always stain my line prior to use.
Regards,
B.E.
great rigging Christian.
When I secure a knot I\m using Pattex glue for plastic builds.
They are in that red bottle.
Works perfect because there is an iron tube on it .
You can glue secure.
Picture below.
Sjors
Hi,
Thanks B.E. and Sjors : I appreciate input your input and sound advice.
Moreover : whenever I visit your buildlogs : it's obviuos that I'm not the only one who's showing interest
Also thanks for the likes : I'm also a "like button"-addict in many buildlogs
Now back to topic :
The knots : I believe I made standard knots or in other words the overhand knot.
I guess photo's tell more than words in this matter.
- Both extreme shoruds were secured with superglue
- The inner shrouds with "Contacta liquid" from Revell  ( a little brush is attached to the cover )
- last to pics are related to the building instructions related to different knots.
O, before I forget ( as a reply to B.E. ) should we consider building instructions rather as "guidelines" ? ( cfr. "Pirates of the Caribbean )
Kind regards
Christian
Thanks Christian, I've used overhand knots hitherto on my builds, mainly because given the scale I considered the clove hitch although the authentic method, to perhaps look too bulky.
The jury is still out on my current build, I will have a look when I get around to the ratlin' down stage.
These days I tend to consider most things as 'guidelines' but for rigging I tend to go directly to Steel, cross referred to a few choice reference books, kit instructions particularly in relation to rigging I mostly ignore.
Cheers,
B.E.
Hi,
The advantage of the clove hitch knot is that the ratline leaves the shroud at the same angle on both sides. With the standard knot it tends to go downwards on one side and upwards on the other creating a wave pattern across the shrouds rather than a natural hanging shape. However, saying that, it is hardly noticeable on this build!
Thunder.
Current Build(s):
Completed Builds:
