Add a chair for me too please!
Doug
Current BuildsBluenose II - AKrabbenkutter / Prince de Neufchatel / Essex Cross-section / Syren / Barque Stefano / Winchelsea / Half Hull / Maria HF31 - Dusek / Bandirma - Turkmodel
On the Shelf: Santisima Trinidad and Cross Section / HMS Cutter Alert / Tender AVOS / Confederacy
Suspended Build: Bluenose II - Billing Boats Nr 600
Erik - is your first name Svein or Erik? Its great to see another Syren. I am just a bit ahead of you. It will be great to compare notes.
Current Builds - 18th Century Longboat, MS Syren
Completed Builds - MS Bluenose, Panart BatteStation Cross section, Endevour J Boat Half Hull, Windego Half Hull, R/C T37 Breezing Along, R/C Victoria 32, SolCat 18
On the shelf - Panart San Felipe, Euromodel Ajax, C.Mamoli America,
Its a sailor's Life for me! :10_1_10:
 Floyd, you should add a build log too if it isn't "on the shelf" anymore!
Doug
Unlike brigs and frigates in other countries,  you would not likely find any lanterns on American vessels.  Not like you know from other English ships like Bounty or Victory.  For example,  If you were to look at any contemporary info.....paintings and models,  you wont see any that show a lantern on Constitution or similar vessels.   Its just not something you will see.
That you are right, I did not find anyting to comare with, but I think this wil be a nice tutsh on the model
I May have to take away the stern lanterns an maby I wil replase it, make a figure to hold a lanterns etc
I have order some 1.8 mm pico led for the Job.
befor I moving on I wil set up the lights on the model an try it out before I do the task permantly
I have know sendt a mail to M.E
they need know take some action on quality control On the plans and kit
if something is wrong here its going to be a problem truaout the hole build
if you use the plans as a refrance
as the plans is know, I can only use it to keep me warm in the winter😈
On 5/28/2017 at 3:46 PM, Chuck said:
How hard can it be for these guys to print those templates correctly for the kit......seems like the easy part.  Anyway.....hope these help.  Remember to set your page scaling to NONE when printing them.  And measure the scale bar for accuracy where each segment should be 3/16" wide.  If these dont match your plans then they probably printed your plans incorrectly as well.  Always measure the scale bar to find out.  That is why it is there.  These are the original files.
Chuck
colorcodedtemplate.pdf
framingplan1.pdf
framingplan2.pdf
framingplan3.pdf
framingplan4.pdf
framingplan5.pdf
framingplan6.pdf
framingtemplate7.pdf
sternframingsyren.pdf
Svein,
Read the above (Chuck's response to another member's identical issue).
Steve
 I got my pico lights for the lanterns, some of the cabels has to get on board Soon,
and it looking good,
am using a remote control and can tone down the braithness lights
the pico I using is Orange colour, Know I have to make some ships lanterns 😱
Svein-Erik, great to see another Syren.
I find it interesting and fascinating you're adding the led lights.
Good luck and be careful, the Syren has it's traps.
Respectfully
Am going to  install the gunport siles and lintels ang am using the templets yust as a gide,
I have to mesjure gunport to get it right later.
Battens are install for the siles.
I also made a copyof templates and ti Seems to me that its ok, butt the problem May bi inn the frame
I'd be the last one to take issue with Chuck but I have to think the early American Navy had to have some sort of
light in and on their ships during the night. :rolleyes:
I am considering some sort of illumination for my Confederacy.
Cheers, Harley
Edited by tigerdvr
Cheers, Harley<p
Under Construction:    USS Yorktown CV-5 1/200 by Trumpeter
Completed:              USS Curtis Wilbur DDG-54 1/200 by ILoveKit
                                USS Atlanta CL-51 1/350 by Very Fire
                                Liberty Ship John W. Brown 1/350 by Trumpeter
                                HMS Spiraea K-08 1/350
                                 USS Arizona BB-39 1/200 by Trumpeter/Mk1 Design
                                 HMS Sir Gareth 1/350 by Starling Models
                                 USS Missouri BB-63 1945 1/350 by Joy-Yard, 9/11/21
                                 USS Indianapolis CA-35 1945 1/350 by Trumpeter
                                 USS Kidd DD-661, 1945, 1/350, on The Sullivans kit by Trumpeter
                                 USS Alaska CB-1, 1/350, Hobby Boss, Circa 2/1945
                                 US Brig Syren 1/64 Model Shipways, Wood
Started, On Hold:  Frigate Confederacy 1/64 Model Shipways, Wood
Hi, thanks
I wil use small pico led for the lights whid remote control
Am making some oil lamps that the pico goes in to.
the cabels I wil putt inside the hull and will go true the keel.
Then it remain to get this dunn 😲
Hi Svien.
Nice build. Like the idea of the lights.
Did this on my victory cross section. Worked well.
Used very thin wire ( single strand) hidden in a knife cut. And flickered the led with a chip.
Rossi46 also did a excellent  tutorial.
https://modelshipworld.com/index.php?/topic/15018-hms-surprise-by-rossi46-artesania-latina-scale-148-first-wooden-ship-build/&tab=comments#comment-467056
All the best.
Antony.
Best advice ever given to me."If you don't know ..Just ask.
Completed Mayflower
Completed Fun build Tail boat Tailboat
Completed Build Chinese Junk Chinese Pirate Junk
Completed scratch built Korean Turtle ship 1/32 Turtle ship
Completed Santa Lucia Sicilian Cargo Boat 1/30 scale Santa Lucia
On hold. Bounty Occre 1/45
Completed HMS Victory by DeAgostini modelspace. DeAgostini Victory Cross Section
Completed H.M.S. Victory X section by Coral. HMS Victory cross section
Completed The Black Pearl fun build Black Queen
Completed A large scale Victory cross section 1/36 Victory Cross Section
  • 2 months later...
So, here are the lighting istallation
all the wire is on board and I have montet brass tube fore montig the model later on the board,
the wire goes true one of the tube and wil go under the finish board
this board will have a lager brass tube so the model will be sett down to.
the lights work well and next is to blokk up the hole frame, sett away the pico leds for future monting
Svein.erik
Re: ship's lights.  Below is a transcribed diary entry from a midshipman in SYREN during her expedition with INTREPID to burn the frigate PHILADELPHIA.  I did my best to interpret the 12-hour clock times given to 24-hour time.  Second para mentions lights, but doesn't indicate where they were displayed.  Taken from "Naval documents related to the United States Wars with the Barbary Powers" five volumes of which are available online.  Many interesting SYREN factoids within...grueling schedule for the small US force involved.
Midshipman F. Cornelius deKrafft
16 February 1804
Commences with fresh breezes, clear and pleasant weather.  The Intrepid in company.  At 0230, made the land on our lee bow.  Hauled up the mainsail, took 1 reef in the topsails, and bent the stream cable.  At 0330, backed the main topsail for the Intrepid to come up.  At 0400, lowered down the cutter and sent 9 men on board the Intrepid with cuttlasses, pistoles, musquets. etc.  At 0430, the boat returned, hoisted her up and made sail for the land.  At 0530, mountain Togura (6 or 8 miles to the E of Tripoli) bore SSW, town of Tripoli SW.   At 0600, tacked to the NW.  At 0730, boarded main tack.  At 0930, tacked to the SW, set staysails and jib.   At 1000, called all hands to quarters and run out the guns, hauled down staysails and jib, and hauled up square mainsail, brailed up after mainsail.  At 1030, spoke the Intrepid.  At 1100, backed the main topsail, sounded and got no bottom.
Midnight moderate and clear, lost sight of the Intrepid.  Hauled up the foresail, backed main topsail, sounded in 35 fathoms and filled away.  At 0100, sounded in 14, 12, and 9 fathoms (from 0100 to 0400 standing off and on the shore).  Showing lights for the Intrepid (which were answered).   At 0100, called all hands to quarters, run in the guns and secured them, shipped the ports, wore and stood off shore.  Made sail, the Intrepid on our lee bow.  At 0800, the high land near Tripoli bore SW by W, 7 leagues.  At 1100, the Intrepid tacked to the S and E.  Noon, wore to the S and W, handed square mainsail, reefed the foresail, and set after mainsail.  Moderate breezes and pleasant.  The Intrepid bearing S ½ E, 8 miles distance.
