Svein,
I would think twice about adding brass tree nails on the black wales. That contrast might be too much. Black treenails might be better, and I believe more authentic, even though they may not be seen very well.  Perhaps you should do a small section first, and if you don't like it, you could probably paint over them.
Just my amateur opinion.
Hei yes it was that I was thinking about doing
nails with heads painted black but it wil be so many nails about  450 yust on the wales
it wil look a bit strange
so I deside to skip it and leve it yust like it is
Svein.erik
It is hard to tell at long distance, but you are having some problems Erik. Before you go further, may I suggest you replace the black tape with thread? This minimizes the thickness issue. I'm attaching a version of your photo with red lines showing roughly how the lines should go. Note that the lowest planks at the bow, especially the garboard, end earlier to allow enough room for the rest of the planking. At the stern the lowest planks widen at the stern post. Try again and play with the thread positions until you get smooth curves from every angle of view.
Have you read A Primer for Planking, pinned on this site?
Thanks 😊there are 3 planks inkl the garboard planks (5/32 and 2 planks 1/8)
and you ar spott on , my baw looks something from hear to there😲
I have post some photo erlier of the hull before I plank the upper dekk (upgrade wood castello boxvood )
 but am not sure about planking the garboard  befor I line of the hull
I my have to take it off and line off the hull
make new garboard using the tic marks?
Svein.erik
Erik: there are so many things to consider when lining out. Please read the article (link below) to better understand what you need to do. Also, there are a lot of boat-builders in Scandinavia. Perhaps you could talk to one of them as well!
https://modelshipworld.com/index.php?/search/&q=a primer on planking&sortby=newest&search_in=titles
Hi Erik,
You probably already have, but study Chucks manual in depth. I read it 5 to 6 times and sometimes still picked up something I didn't see before. His photos show the order of placing the planks and where to end them to allow for the next one's. I wasn't very confident at this stage but got there in the end following the process outlines in the instructions.
Your model is looking great.
Cheers,
Current Build:     USF Confederacy 1778 - Model Shipways - 1:64
Completed:         US Brig Syren - Model Shipways - 1:64
                        San Francisco Cross Section - Artesania Latina - 1:50
Future build:        HM Granado - Caldercraft - 1:64
                        LeRenard - Artesania Latina - 1:50
Hi am back from my trip in Berlin an did some history movment,
thanks for the liks and kind works
am also back in the Shipyard and working on some more planks so in a day ore 2,3,4
The best from svein.erik
Hi  again and thanks for the liks
the summer is here So I have work to do outside the shipyard (yust to keep my wife happy😉)
But I did finish the 2 belts with boxvood and its time to get over to use basswood
am over the critical point at the stern,
The black paint wil have castello boxvood, I my have overdue this but Wats fun in that 😆
Svein.erik
Thanks for the liks
but Huston, I have a problem😲
I think I did some wrong with the planking, its Seems to me it going to get to narrow
there is 7 planks to fitt in there (about 2mm at the stem)
So do I take all the basswood strip off ore just leave it?
Svein.erik
Erik,
Shorten the garboard back a bit, and change the shape at the bow to better follow the current run of the planks. You should be able to fit all of the strakes in that way.
Good progress.
Joe Volz
Current build:
Model Shipways "Benjamin W. Latham"
Completed  builds on MSW:
Caldercraft HMS "Cruizer   Caldercraft HMBV "Granado"   Model Shipways "Prince De Neufchatel"
17 hours ago, jwvolz said:
Erik,
Good progress.
Thanks for the coment ,
as I did this hum#**/&%+...... 😲 am thinking of using a drop plank to do the task here
and take this with me on the nex build
as the syren get's the copper plates it vil not been seen
Svein.erik
Hi everyone,
I did resive corronades from shapeways to use on the syren,
but I did order the hole set with the sledge in 1:64 scale
but it Seems to me that the sledge is to big but the corronades is in scale
so I need to send a mail☺
price is 54 dollar vs 181 from cornwall
Svein.erik
I am pretty intrigued myself by this 3D printing approach. How is the quality of the carronade barrels? Once painted is a 3D printed barrel comparable to a brass barrel with respect to precision and details?
Btw, you do a really good job on your Syren model! I love to follow the progress.
Thomas
Current Built:   Model Shipways  Syren  (US Brig 1803)
Last Built:        Anfora (kit bashed)  Ictineo II  (1st steam powered submarine 1864)
Thanks Thomas
I do Not know how it wil look wen painted I yust resive it to day,
I also noted that the slegde is to wide back and a little to long (ref.plans)
I have mail them and sendt photo of the items and the plans,
they are already responding so I have to see wat the wil do with this problem☺
Svein.erik
The answer Thomas depends on the 3D printing process. The machines that Shapeways uses are the highest quality. I am very impressed.
Current Builds - 18th Century Longboat, MS Syren
Completed Builds - MS Bluenose, Panart BatteStation Cross section, Endevour J Boat Half Hull, Windego Half Hull, R/C T37 Breezing Along, R/C Victoria 32, SolCat 18
On the shelf - Panart San Felipe, Euromodel Ajax, C.Mamoli America,
Its a sailor's Life for me! :10_1_10:
