On 12/9/2022 at 7:30 PM, scrubbyj427 said:
Beautiful work Ondras!
Thank you so much Scrubbyj. Thanks for the like:D
Finally, clamping deadeyes called "chains deadeyes" on the main mast..:Whew:
General view..
Now I have small deadeyes waiting for me on the mizzen mast..:default_wallbash:
Ondras.
Done : President - https://www.modelforum.cz/viewtopic.php?f=177&t=90230
Under construction : Roter Lowe - https://www.modelforum.cz/viewtopic.php?f=177&t=114576
Member of the organizing clubhttps://wchs-c-2023.klom-admiral.cz/en
I made the last two sizes of small 4mm wide deadeyes. Again, a system of glued plates and machining at once..
Created a tool for a milling cutter for the production of a 0.4 mm side groove..:default_wallbash:
All deadeyes after waxing..:Whew:
I wish everyone a lot of success in the new year 2023, a lot of peace in modeling and, above all, health!
Ondras.
1 hour ago, Alvb said:
hallo.
how did you glued the plates for the deadeyes for machining at once.
Alvb
White glue Pattex D2, hardening time 4 min. Dissolves with heat and water..👌
Ondras.
Thank you very much everyone!:imNotWorthy:
Deadeyes fittings for besan made of wire 0.4 mm..
I ran into another stupidity in the plan. From a layman's point of view, deadeyes cannot be placed directly on wales. The ropes would break against the broad stern..:default_wallbash:
I measured the width of the channels..
Channels again secured with steel pins..
Deadeyes attached to the hull..
Ondras.
Frühe Galeonen, deren Seitenwände mehr zum Heck hin eingezogen waren, konnten die Deadeyes der Besanwanten an den Walen fixieren, ohne die Seitenwand zu berühren.
noch etwas verwundert mich.
Die Deadeyirons am Haupt- und Vormast enden nicht in Wales.
Das weiß ich bis jetzt nicht.
Gruß
Albb
Edited by Alvb
6 hours ago, Alvb said:
Why is the text so big
On a computer you can set the size of the letters.
On a smartphone I don't know how to do this
Gruß
Albb
Hello, Alvb. I had this opinion too, but I found out that the "chains deadeyes" fitting was also above the wales. On a competition model, I try to change only complete nonsense, I leave what could have been. I found boats with chains deadeyes outside Wales.
For the rigging I use the Zeehaen ship plan, here the clamping is also over Wales, there only the reinforcement continues..
On the Dutch ship replicas this clamp is also over Wales and looks good..
Edited by Ondras71
Ondras.
Gruß
Albb
Alvb,
This is an English language forum so please post in English.  If needed, Google Translate works very well.
Thanks,
19 hours ago, Alvb said:
Sorry I replied in English.
The fact that this text appeared in German must have been caused by an unintentional operating error.
Alvb
No worries.  Seems to happen a lot so you are not the only one.
I started making poop deck railings..:Whew:
348818898_zbradlzadnpalubky(6).JPG.350b2488b87a98d1fbfc816ec31a2b96.JPG817056879_zbradlzadnpalubky(5).JPG.45feca1c143f1e9140a64d9fdd42312d.JPG
Railing decoration. The carvings will be too small, I wouldn't make them out of wood. Production of modurit firing compound. I opened the mod from the previous President build. It is still usable after 8 years..👌
I again studied the instructions of the Czech modeler Doris Obručová for working with modurit and tried the first option..:default_wallbash:
Rollers approx. 0.6 mm... Temperature 130 degrees Celsius..
Preview, the result will be red..
Ondras.
Good day,
Dear Ondras,
Such clean and beautiful work! Watching your build with great pleasure!
All the Best!
Kirill
On 2/4/2023 at 7:50 PM, kirill4 said:
Good day,
Dear Ondras,
All the Best!
Kirill
Thank you very much Kirill, thank you for the like..:imNotWorthy:
I have repeatedly studied Doris' threads on working with modurite matter. Yes, it's alchemy, it either flows or it breaks..:default_wallbash:
I was looking for the perfect shape in a book..
According to Doris, he only fired the basic shape..😴
Then he added the little things that always damaged the foundation. Much better after repeated firing and spraying..:Whew:
During the fight with modurite, I started making the emblem for the rearview mirror..🤨
Ondras.
  In nearby Wilmington Delaware, there is a full sized reconstruction of the Kalmar Nyckel (trans: Key to Kalmar).  I was present for the cermonial laying of the keel, re-enacting the role of a soldier with a matchlock musket (there's a picture of me in that garb somewhere).  Below are pictures of her stern decoration, under sail and at dock.  At dock, I note that the topsails are furled in period manner with the central part of the sail 'bunched' around the mast.
Thank you Johnny. I prefer to use a replica of an older Duyfken ship as a model.:rolleyes::imNotWorthy: I really envy your participation in the construction of Kalmar Nyckel🔥💥
Edited by Ondras71
repair
Ondras.
I patinated and glued the ornament, the back rail glued..👌
Another fight with the modurit and completing the emblem on the mirror..:default_wallbash:
I've been studying the Doris threads to work with modurite. It's hard to find, so I'll put a link here for a better search.. https://www.modelforum.cz/viewtopic.php?f=177&t=110763&p=2259964&hilit=modelování+výzdoby+se+věnuji+již#p2259964
I will allow myself a short message that I contacted Doris, she is fine, but she has put the models away for now.. :Whew::imNotWorthy:
Edited by Ondras71
Ondras.
Thanks for the like..:imNotWorthy:
Thus, the parts of the emblem are hardened by heat. Just the color..🔥
Completely finished poop deck railing..💥
Ondras.
The emblem is ready..
..and placed on the mirror..
Next job - a big flag on the stern
Ondras.
Thank you for the like..:imNotWorthy:
"Mast rails" are created on the stumps of the masts..👌
All attachment points including Pins done..🔥💥
Ondras.
