CSS Virginia by MrBlueJacket - FINISHED - BlueJacket Shipcrafters - scale 1:192 (1/16" = 1')
TIme to start gluing. Stem, keel, sternpost, propeller cage, fantail. Here's photos of the top and bottom. Also the rudder, carved out of sheet stock. Some striping tape will simulate the gudgeons and pintles.
V2.thumb.jpg.277d2489622ee1ea2cf5a84d2ad65e49.jpgV1.thumb.jpg.28a84bba49ba531c554e707f116727f8.jpg
Edited by MrBlueJacket
Link to comment
Share on other sites
Haven't done much work in the last two weeks, but made a little progress this past weekend. The instructions show adding strips of heavy paper to various parts.
For the armour belting I used 1/32 x 3/16 basswood. Then I shot a quick coat of primer on the model to see how much more sanding I need to do. The even color makes it easier to see irregularities than the bare wood does. Time for a little auto body filler, I'm afraid......
Link to comment
After several weeks of other things, I am back to the Virginia again. I decided to laser-cut the gunport lids, and a Google search showed them to be split vertically, with the hinges on the upper outer corner. Note they are only on the ends, not on the broadside.
5ab5044bea726_Screenshot2018-03-23at9_41_37AM.png.8023a9f02dc860bc3649060b9d57ccb0.png
These laser cut lids, and the top gratings, will be added to the kit.
Link to comment
So after a month of not working on the VIrginia, I am back at it. Drilled the holes for all the top fittings and stanchions, masked the grates, installed some parts and the boat mounts, guns are in, and also the eyebolts for the stack supports. Starting to look like something!
You can see that all the primer/prep work yeilded a nice smooth finish that will take the finish coat of paint nicely.
Link to comment
So now to install all 61 of the pins that make the rail stanchions. To get them at an even height, I made a jig by reversing a clothespin and cutting the tip down to the length I wanted the stanchions to be. Then it was a simple job to hammer the pins down to that depth. I'm happy with the outcome!
Link to comment
16 hours ago, jhearl said:
This is off-topic, but I'm curious - whatever happened to your build of Wyoming?
Cheers -
John
We never started to build the Wyoming, but it is in our kit development schedule. I expect it to come out in about 1 1/2 to 2 years. It wioll be 1/8" = 1' scale, and be 55 inches long.
Nic
Link to comment
17 hours ago, GrantGoodale said:
I really would love it if other kit manufacturers would try to build the model from the kit. Every so often, I come across something that makes me wonder -  did they actually try to do this?
I was hesitant to start a build thread, since we are a manufacturer. I asked Chuck (admin for MSW) and he said to go ahead, just don't make it a sales pitch. When the Virginia is done, I will be working on the Mary Taylor pilot boat.
Link to comment
Nic
My bad - I mis-remembered a newsletter last year where you were working on Notman and then there was a picture of Al holding plans for Wyoming. That's going to make one helluva model!
Thanks -
John
Link to comment
So I am on again with this "on again - off again" project. This past w/e I masked off the upper hull to paint the underside. The Virginia's waterline extends above the flat portion of the deck by 1/8" or so. The masking was a challenge. I used Tamiya 6mm masking tape for the first time, it is really great stuff. Very thin, clings around raised lips, and easy to pull off cleanly.V1.thumb.jpg.553cfe5314d52423b80a6d438dc5e505.jpg
Next comes the blue painters tape to protect the black upperworks of the model.
And after spraying and pulling off the tape (deep suck in of air) a perfect paint line!
Link to comment
Those laser cut grates of basswood looked too clean and white, so I painted a coat of brown on them. I think they look much better now. The last one still needs to be done, but I thought a photo comparing them would be good.
spelling
Link to comment
Challenge?
John
Member: Hampton Roads Ship Model Society
Current Builds: Tugboat Dorothy  Newport News Shipbuilding Hull #1 (complete)
                            Iron Clad Monitor (complete)
                            Sardine Carrier which I will Name Mary Ann (complete)
                            Pilot Boat John H. Estill Newport News Shipbuilding Hull #12 (my avatar)
                    Harbor tug Susan Moran
                    Coast Guard 100' patrol boat
Link to comment
Nice,
Member:
Connecticut Marine Model Society
Model Ship World
"So we beat on, boats against the current, bourne back ceaselessly into the past" F. Scott Fitzgerald - The Great Gatsby
"If at first you don’t succeed.......skydiving is probably not for you”
Link to comment
Found out something my last visit to the Mariners Museum in Hampton, VA. They are restoring the turret and guns, along with other salvaged parts of the USS Monitor. Excellent location for these transition era ships. And an outstanding museum with many ship models.  Anyway, the Monitor could only fire one gun at a time from the turret. And they were afraid to put a full powder charge in each gun for fear of bursting the barrels, so they fired at the Virginia with partial loads.
Ken
Started: MS Bounty Longboat,
Link to comment
So this build has been occasionally sidelined by other projects, but progress is made. Here's a shot of the railing and awning rigging completed:
ANd a better view of the stack guywires and steam vent:
I've also done some work on the lifeboats as you can see:
And finally, it's close enough to done that I feel OK with raising the flag:
Link to comment
Well done!
Building: 1:64 HMS Revenge (Victory Models plans)
On the building slip: 1:72 French Ironclad Magenta (original shipyard plans)
On hold: 1:98 Mantua HMS Victory (kit bash), 1:96 Shipyard HMS Mercury
Favorite finished builds:  1:60 Sampang Good Fortune (Amati plans), 1:200 Orel Ironclad Solferino, 1:72 Schooner Hannah (Hahn plans), 1:72 Privateer Prince de Neufchatel (Chapelle plans), Model Shipways Sultana, Heller La Reale, Encore USS Olympia
Goal: Become better than I was yesterday
"The hardest part is deciding to try." - me
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
