Very very nice,        I could throw in some drawings I have done of ships if you want.
OC.
Edited by Old Collingwood
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Very impressive Piet. Not only a model builder but an artist in multiple mediums as well! B) I can't even make a good picture using a camera!
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
We all have special talents that make us special lou;);):cheers:
OC.
Current builds
Completed works.
Yeah OC that's what my wife keeps reminding me! The only problem is that it appears that my special talent is Bad Example. According to her that is about all that keeps me from being useless!
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
You should listen to the admiral,   she can see your skills and qualities,    " A helpfull man outways a man of  skill - skills need hoaning but help is un wieghed"
OC.
Current builds
Completed works.
A lazy man will always achieve more than an ambitious man. As he will find a more efficient way to do it.
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Masterful Piet. Now I understand your "membership". You always seem to sneek upon me with a new surprise ... very unnerving mate
Carl
Thank you again gentlemen for your kind words and banter, enjoy it a lot.
Go ahead OC, show us a ship picture. I have a pen end ink of a Dutch frigate and started a tempera painting of a VOC ship. All my oil paint paintings are sold.
Yeah Carl, that'll keep all youns off balance ;)  I have a few more to tickle your nerves with :o :rolleyes:
I did manage to make some time this morning and bought a 200 teeth 10 inch saw blade for my jobbers table saw.  Now I heave to find some time to cut the plexy glass.  To prevent it from cracking and chipping I'll install the blade backwards and let it protrude about 3/16th of an inch above the table deck.  That way I'll have a little wiggle room and feed it slowly.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Thank you piet,   I draw these when I was a teenager, when I was first starting to be hooked on ships  -
OC.
Current builds
Completed works.
Nice work OC. Do you have anything newer?
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
No mate,  you could say my teens was my inspirational period,   I drew lots of different subjects back then   (sorry for hijacking your thred piet)
Including castles  -
OC.
Current builds
Completed works.
it's good to have other hobbies...helps to foster creativity and boost skills {such as painting}.   I've done well in combining modeling and writing :)   very nice art work from you  and OC..........all I can accomplish is an abstract stick figure  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Nice work OC. Even my stick figures are not proportionally correct!
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Very well done OC and that as a teenager.
I think I have completed the jig for putting the plexy glass case together.
I have also mounted two shelf brackets to the wall next the O19 model and above my drawing table. I'll show some pics when I get to it.  Hope to start cutting the glass tomorrow, I already asked Gwen to help me holding the sheet for me and she graciously agreed :)
Cheers,
                       VOC Ship Surabaya
Hello every one,
Here's an update of work done in the last couple of days.  Cutting the plexy glass went without a hitch and managed to do it without Gwen's help.  I just made a support with a few boxed till the first two sides were cut and could remove them for the rest.
After all four sides were cut I smoothed the edges out with 180 grit sand paper backed by a 10 inch piece of food, like a sanding stick. Then I clamped three sides in the jig and carefully applied the cement to the edges.  This was kinda tricky because the cement is "thinner" then water and did spill over in a few cases causing some smudging, which I hope to remove with a polishing disc.
After these three sides were cured I rotated the assembly and clamped the last side in the jig and cemented that one in place.
Today I cut the top piece out and cemented that to the box.
When using two pieces of corner molding I liked the idea of going ahead and putting corner molding on all corners, it looks much "dressier" then without them.  It also hides a few of the cement smudges ;)
So, off to the home improvement store for some nice small corner molding.  I'll stain them with the same stain as the base and use a few dabs of epoxy cement to glue them in place but that'll be a job for Sunday or later.
The jig
Hr. Ms. Java next to Hr. Ms. O19 and Hr. Ms. O16
Hr. Ms. Java above my drawing table
Plexy glass sawing setup.
Display case jigged to check for fit.  I removed the protective paper only at the to be cemented sides.  I did not take pictures of that process, sorry :(
Display case partially finished. Corner molding to be added. The glare on the left side is from my book shelves. behind me.
Cheers,
                       VOC Ship Surabaya
That is a good looking case, Piet.  I can't wait to see it finished.
Thanks Mark. Yup, I'm also looking forward to having this project completed, then I can go back to those on the bench.
Cheers,
                       VOC Ship Surabaya
Hey Piet, what kind of food works best when sanding?:D^_^ Whatever it is the results are really nice.
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Your getting as quick as me mate,   we must share the same wip.:D
OC.
Current builds
Completed works.
You meant whip, of course, from a whipping with yer fathres belt ;):D
Strange but effective setup Piet. Look forward as  to how you will finish it ...
Carl
Piet,
All that can be said is a perfect finish for a perfect build.:cheers:
John Allen
Current builds HMS Victory-Mamoli
On deck
USS Tecumseh, CSS Hunley scratch build, Double hull Polynesian canoe (Holakea) scratch build
Finished
Waka Taua Maori War Canoe, Armed Launch-Panart, Diligence English Revenue Cutter-Marine  Model Co.
Glad you did it Carl, I couldn't force myself to do it twice!:D (Of course it should have been your Father?):D Sorry
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
No  - "wit"  mate instead of "wip".
OC.
Current builds
Completed works.
nice progress on the case :)   the changes you made on the smoke really look great!
Edited by popeye the sailor
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks gents for the nice comments and of course the banter, enjoyable.
You mean the wood for the sanding stick Lou?  It's a piece of multiplex 11 X 1.5 X 5/8 in this case. It's long enough not to make it wavy.
Today I had to remove about 1/8 inch from the sea bordering the side molding so the "glass" could sit on it nice and even.  I also put small wooden pegs in the corners to prevent the "glass" from sliding off.
Tomorrow I'll see what Lowes or Home Depot has for corner molding. It usually comes in 1/4 inch thickness, which is too heavy to my liking so I'll have cut it down some. We'll see what they have, I can always make it fit. I'm shooting for no more then 1/2 inch wide by 1/8 inch thick.
Cheers,
                       VOC Ship Surabaya
Hello Everyone, and my thanks to all who clicked the like button.
I was not successful finding smaller corner molding to I'll have to work with what I have in stock.
I proceeded to cut all the pieces to size and temporarily taped them to the "glass" case.  Next will be to remove about 1/8 inch from the sides and sand them smooth so I can apply the stain. Once the stain is dry enough to handle I'll cement them to the "glass."
I think that I should make 4 corner pieces from copper or brass sheet to kinda dress it op a bit. After everything is done and looking good it's time to put the name plates on and place the finished diorama of Hr. Ms. Java on the shelf.
I have also rearranged the gun smoke a little and thinned out the funnel smoke.
Here is the diorama as of this afternoon.
Cheers,
                       VOC Ship Surabaya
WOW  thats looking really really nice - what a superb job you have done.
OC.
Current builds
Completed works.
the case looks great :) .......very nice indeed!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
The thinning out of the smoke added something.  All I could think was "running fast and in harm's way", Piet.  That is a powerful work of art.
