Hi Bob, looking good! As to your copper plating, its very nice! The spring 2018 issue of the NRJ (Page 73) had a letter in it detailing how the nails that fasten the copper plating to the hull would hardly be visible anyway, as they would not be proud of the surface.
-Elijah
Current build(s):
Completed build(s):
Model Shipways Phantom
Member of:
The Nautical Research Guild
Thanks so much Rich, Elijah and the "likes".
Rich,get out your anti-boredom pills. The repetition of doing the guns, particularly the rigging, is almost mind numbing.
Elijah, were it not for physical issues that I was going through at the time that I did the coppering, I would probably have done the nailing in some fashion. I'm now just as happy that I didn't.
Bob
All of the guns are now installed and rigged. A  big "thank you" to RustyJ for graciously providing me with the 1/8" Syren blocks that I needed to complete the gun rigging (they were out of stock). This is a perfect example of the generosity and friendship that make this site the great place that it is.
Bob
She is looking superb bob.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
look'in good Bob.......very nice work with the cannon rigging...neatly done.   kudos to Rusty for help'in ya out!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Beautiful gun rigging! As usual I am amazed how fast you went through the rigging of the carronades! It took me forever to get them finished.
Thomas
Current Built:   Model Shipways  Syren  (US Brig 1803)
Last Built:        Anfora (kit bashed)  Ictineo II  (1st steam powered submarine 1864)
While rigging the guns, I was also making up the gunport lids. I decided to finish and mount them at this point. The lids were made in two layers: laser cut pieces from the kit that were painted red and boxwood strip planking, cut to fit. The hinges are black paper. Blackened eyebolts were bent over and inserted into drilled holes. The lids at the aft end, where there are no guns, were mounted in the closed position.
The next work will be on the head.
Bob
gun port lids look super..........look like you plotted them well to miss the chains ;)   I was daunted when I did the Thermopylae......I waited till I had them in place.   then I could add the lids {closed,  of course} ;)
very nice!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Well, I've been up north for the past couple of weeks having a medical procedure, but now it's back to work on PdN. I've done the head work , which is somewhat simpler than on others that I've done. That's not to say that it is ever easy to fit the cheeks and rails, but at least there was no middle rail or eking rail to fit. Once again, the plans and instructions are very vague on details, so I just fumbled along. All of the parts were made from boxwood sheet and strip.
Bob
Beautiful work Bob, hope you are feeling better
Looking really nice bob,   all the best to you after your op.
OC.
Current builds
Completed works.
