Thank you for the kind comments everyone!
Cheers Kriss and Lawrence! The red used is a bit tricky to photo. It looks like in the pic when its in normal inside lights, perhaps slightly darker. When in sunlight it goes more vibrant. It makes the shadows more prominent and the paintjob alive.
Thanks Mark and Michael! I wish I could have gotten the rounded shape of the horizontal parts that follows the line from the wales, but I cant see how to do that without getting a mess when continuing the build, so I went with them starght. I also would have liked the vertical pieces between the vertical parts tilted correctly, but I had enough problems getting them straight like they are now. Overall Im still liking the result, and that it can be done with the original kit parts (except using the middle sized towers from the spare parts I have, instead of the big ones). I love wonky constructions, it gives life and personality.
Thank you Ferit, most apreciated!
Im worried about getting the lower rounded parts planked correctly, they are rounded with sharp edges like the towers, but its hard to shape the wood pieces without having them in place. Hopefully I can sand or file them in place if needed.
/Matti
Billing Boats Vasa
Hi
Great job with your ship, it looks realy good.
Question has anyoen downloaded the instruction manual for the wasa from billing-boats. The website is down, and in this instruction manual, are lot off extra pictures, who are not in the paper manual.
Regards Kor
Thanks!
Hmm, Ive read it and if I dont misstemember they are the same, at leat as mine. I have the latest release I think.
The us site is up, billingboatsusa.com
Heres a link to the instructions:
https://docs.google.com/folderview?id=0Bw40frlcNqbjOTNlYTE5Y2YtMGUyNC00NGE0LWE0ZTktNTRmZjFhNmM0MjM4&usp=drive_web&hl=en
The instructions are quite unstructured, but so far everything is there, but you have to jump around between the different parts of the instructions, and the big plan is often helpful. Just think the steps through and youll be fine.
/Matti
Edited by NAZGÛL
Billing Boats Vasa
thanks for sharing these perfect pictures from the original
I feel more and more that I should have bought the Billing kit instead of the Corel kit. the basic of the kit is better from Billing Boats as far as I could see now. during the time I was verifing both kits there were almost no buildlogs available from this BB kit. for all new builders this will be a good comparison with the other Corel kits on this forum.
I am curious how the figures are detailed even if these are from plastic (once painted you don't see the difference)
Jan V.
current build: Vasa-1628 Corel / Battle Station Mantua/Panart,
previous: Statenjacht / Cross section HMS Victory / diorama shipyard
No problem Jan, Im happy to share them.
Im happy with the BB. I think I read somewhere that Fred Hocker recomended the BB for wood models, and I started to look at pics and that helped me make up my mind. The gunports needs to be moded though, as the glue on plates are not up to the rest of the nice model. The shape is really good on it, and sculptures are not bad from what Ive seen so far. I couldnt get the small sculptures on the deck to fit perfectly, so I had to alter them a little. Akterspegeln is nice in my opinion. After reading the Landstöm book it seems to me that BB designed their sculptures and some details on his paintings. His work is pretty close to the real thing so its not bad.
(Landströms book is very inspirational and good for anyone interested in Vasa or how they built ships at that time. Any fan of blue and gold Vasas will like it also, because when he wrote the book in the eightes, it was a well known fact that she was blue!)
Like I mentioned earlier Im a bit worried about getting the sculptures to fit the towers as I did mine a bit different compaired to the pics in the instructions and box cover. Good thing is that you are supposed to bend and shape the sculptures at round shapes like the galleries and towers, so I can bend the to the shape I made. Im also considering to leave the top towers without sculptures like the real ship is today, like an homage. i havent decided yet.
/Matti
Edited by NAZGÛL
Billing Boats Vasa
/Matti,
    I am sure that no matter which way you do the sculptures they will look nice. Always remember you are the Master of the build and you should do it the way you think is best. Keep the pictures coming, I am enjoying this build very much.
Wacko
Joe :D
Go MSW :) :)
Excellent work Matti B) She looks fabulous.I don't envy you getting to the lower side of the upper gallery,or have you not glued everything in place?
Kind Regards Nigel
Currently working on Royal Caroline
Beautiful work, Matti.  Your color choices and workmanship are breathtaking!
Wayne
Neither should a ship rely on one small anchor, nor should life rest on a single hope.
Epictetus
Matti,
Looking super nice.  As for "bending" those carvings.... be real careful. It doesn't take a whole lot of heat to turn them into blobs of plastic.  Don't ask how I know...  :)   I did however, have two sets of fittings
Thanks for the nice comments! They mean a lot to me!
Joe thanks, and I hope I can get them good.
Nigel, cheers. Yes you are right, I will have some work to get the lower parts there. I wanted to get the towers and top sides in place first and work from there. If I need to "cheat" or adjust a little to get the galleries set up right, it will be least obvious on the lower parts. (Well thats what I hope anyway ;))
Thank you Wayne! Im glad you like it!
Mark, thanks! Yeah I hear you about the risks. Ive scratched styrene stuff before and heating it then, but it would be typical if thats the thing I messed up! I usually use a heating gun that can be adjusted to low heat and practice on parts like sticks from the sprue and first learn at what distance to hold the plastic at and how the plastic reacts. Boiling water can work aswell, but harder to get control over IMO and its easy to snap them. Actually its a stress not to have any spare parts. I messed up one or two of the towers, and could use spare ones. There were no extra plastic parts in my spare part kit though...
/Matti
Edited by NAZGÛL
Billing Boats Vasa
Looking great Matti! I'm certain your skills are up to the task.
She will be a beautiful ship when done.
Mark S.
                                           1st Build : John Alden Sloop / kit bashed
Matti,
I had two sets of spares due to a nasty accident while building the first one.  My lady pushed me to get a second one and "do better".... I did.  That plastic is bit strange.  Heating it and it doesn't give, a bit more and it bends and just a hair past that temperature, it turns into liquid.  Go slow and take your time.  You'll do fine.
On the topic of Fred, the Musuem, and BB... as I understood it, the BB kit is only one the Wasa Museum sells.  Seems BB is only company that updates their kit as new things are found through the research.  If you have questions, do email the museum staff.  You'll get an answer and it will be the right answer.
Thanks Mark, I hope so!
Ouch about that accident Mark T! Good that you made another. Thanks for the heads up on the tricky plastic.
I agree, the museum people are great and helpfull. I also met two of the guys that made and painted the 1/10 model, (they work at the maritme museum close to the Vasa museum) and they are also very nice and share how they do things.
/Matti
Billing Boats Vasa
Hey all!
Did the stern parts. As I wanted to have holes below the windows and think the original kit design seems really fragile, I made it in one piece that I will plank. I glued the lower one in place. I will shape the planks so there will be no gap at the top.
/Matti
Edited by NAZGÛL
Billing Boats Vasa
Nice move Matti,if you had just planked you may have had problems with the holes.This way should stop any splitting etc.Are the four holes gunports?
Kind Regards Nigel
Ferit, I want to try and see how it would look with the dark red against all figures. It will be pretty much covered with it could make a cool effect, but if not I will add a coat of the new nuance.
Nigel, thanks. I wanted to avoid drilling the holes after the planks was glued in place, as I have to be careful with the stuff I installed for lighting her. Gunports, yeah, from what Ive read she were supposed to have carried 4 swiwel guns there, but she didnt have them installed on her maden voyage. I know they had big problems getting all the canons finished for her, (it was a huge task) so maybe thats the reason.
Thanks Mark! I will soon join you in painting figures.
Cheers Lawrence, Its very strong. After bending it so much, I reinforced it with CA glue an baking soda on the inside and in small cracks, and it makes it strong. I do that with plastic models, and it works like a charm on wood
Did the top part last night, its the same but more shaping work to fit all lines but no holes. Ill update when Ive got both finished.
/Matti
Billing Boats Vasa
Thanks Brian!
Gettig the stern parts done. There are many lines and curves meating there, so it was some work to get them set up right. You can also see how the red behaves change in different lightning. Very dynamic and vibrant, and I think it will work well with painted sculptures on. I also could glue the Vasa sign and puttys between the windows. That felt rater good as it means Im getting closer to the stage I enjoy most: painting. I also lightly washed the yellow whales and parts to make it look uniform with the rest of the paintjob. That did a lot for realism and sense of scale.
Next step is the lower parts on the galleries.
/Matti
Billing Boats Vasa
That looks fantastic Matti B)  B) She is starting to look less like a model and more like the real thing every step you take.
Kind Regards Nigel
Matti,
Again !! love the look of your build. Such nice work--congrats.
PS: I'm working on fixing my weather deck gratings, took hints from yours (:-) Copying is the best form of flattery.
R/  Michael
Under the table:
Woody Joe Higakikaisen
Completed:
Santa Maria-Mantua --
Vasa-Corel -
