Hello, just came across your build log. Very impressive, clean and crisp work, congratulations!
Also came upon your mystery photo regarding channels and it reminded me of a photo I had from the training ship "Mircea" of the Romanian Navy, built in 1881 by Thames Iron Works and Shipbuilding Company in London/Orchard Yard, Blackwall. The photo is from around 1940 with the ship already in conservation (it was set afire by Russian bombers in 1944) and you can surely see she had normal deadeyes with three holes, but the ropes were protected by wrapping a canvas around them. Also there seems to be an iron bar which keeps the upper deadeyes in line and the wrapping goes above this bar. To my eyes it looks like your photo shows the same arrangement, only in a tad bigger scale as Loreley was certainly bigger than Mircea! Hope this helps!
Edited by Doreltomin
wrong name of the ship Loreley edited
That's great. Thank you very much. A big relief for me. This ambiguous question was a bother for me.
Edited by Ilhan Gokcay
 Gorgeous, simply gorgeous, Ilhan.
Beautifully done.👏👏👏
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Welcome back "home", Ilhan.   Great to see you back in the shop.
I made the portholes of brass tubes which fits exactly to the tubes at the hull. I filled them with epoxy and glued with Revel Contacta Clear.Loreley-0515.thumb.jpg.dd10bb03ff548e076716dbe70a2197a1.jpg
  • 2 months later...
Very nice work        :cheers:
Bob M.
                   WASA
                   USRC Harriet Lane
Deckhouses made with acrylic sheets and pear strips.
Bridge deck is made of 1 mm plywood, 0,5 mm pear strips (top)  and 1 mm pear strips (underside).
Adjusted the bridge supports and installed brass tubes as bushings in the deck and in the handrail
Some part of the stanchions have 2 rails and some part of them have 3 rails.
I modified the stanchions because the 2 rails and 3 rails did not have the same height. 3 rail stanchions were higher. I sanded down the bulges at the bottom flash and made a new one.
I also sanded down the bulges for the rails as they are too bold.
