HMS King George V by RGL - FINISHED - Tamiya - 1/350 - PLASTIC
1 hour ago, RGL said:
So, my first attempt at camouflage, this is stressful
So you are human after all! Now you know what we mere mortals have to deal with on a daily basis ...
So the grubby light grey is your "default" colour, and now you are setting up the dark grey, since one usually works from light to dark. If you want to match the camouflage, you can scan and print the example and use that as a template ... makes life a lot easier ... maybe even less traumatic ...
Carl
Link to comment
Share on other sites
No mate, just the pain of “will the mask lift paint”, it has light grey, light blue, dark blue and black, so it’s a bit of a layer cake that requires preshading on each level or at least highlighting. I used a pencil to draw up the lines and some Tamiya flexible masking tape.
i got the set of Lifecolour RN paints, add thinner and they become putty. Don’t add thinner! Use water.
Light blue added, I’ll do black and dark blue tomorrow
Greg
Link to comment
if you saw how I did the camo on the Vendetta.........   the method your using though is producing some really good results ;)    airbrush is by far,  the best way to do camo......no tell tale paint lines.   blending is a lot easier too.   she's look'in awesome :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
5 hours ago, Koppalakki said:
You need lifecolors own thinner for the paints!
I tried to airbrush them a couple of times but they weren't up to my standards on how they behave. They are absolute marvelous brushing though!
GL with the camo, a lot of split hairs while I did mine on the Tirpitz!
My paint on my warspite is hand painted with lifecolor,  I love them.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Loving the camo mate.
OC.
Current builds
Completed works.
Link to comment
Thanks, I’ve just added the boot strap. Next will be the depth markers, then the deck will be laid down. I can then drill the stanchion holes as the deck will give me the boundary.
Then weather the hull, place stanchions and rig it with ezyline. Every other time I’ve rigged the stanchions the superstructure has been on and it’s that little bit more fiddly.
Greg
Link to comment
Some pics from 1941 (I think)   hope they are useful to you.
(All photos courtesy of  IWM retrieved via a generic internet picture search)
OC.
Edited by Old Collingwood
Current builds
Completed works.
Link to comment
And these two in drydock.
OC.
Current builds
Completed works.
Link to comment
Thanks, I have scoured the net for every photo I can, and only found 3 or 4 from 1943. So much rubbish with people just labeling photos of the wrong ship as KVG (or any other ship for that matter). Most research is open source these days and once your head is around what was fitted when makes it a lot easier to build.
Greg
Link to comment
Its quite difficult finding pics from our exact build timeline,  I am still looking for close up shots inlcuding deck shots of Warspite in mid 1944, as thats the time I am building her from D Day offshore bombardement.
OC.
Current builds
Completed works.
Link to comment
OC.
Have you tried switching searchengine ... you might have a few different posts between the engines on the same search criteria
Carl
Link to comment
Dirk, I completely agree, I suppose the issue is with the Internet photos are copied everywhere without references and it becomes impossible to find their original source after a while. Russian sites are a wealth of information for photos but as I only speak one language I have no idea what their captions are.
The IWM site is not really user friendly for searching. The AWM is a little better, and since the death of photobucket a ginormous amount of reference material has died never to be replaced.
Greg
Link to comment
Hi Greg,
Quite often google translate is capable of transforming those Russion captions to something more or less understandable :)
By the way: I very much like the camo on the ships hull.
I was wondering whether you will be able to mask the camo on the upper structures, or that you have to spray/paint them just by hand.
Jan
Link to comment
9 hours ago, Dubz said:
Imperial War Museum ... I would like to suggest to mention the sources of pictures from the net (also it is always a bit "tricky" with copyrights ...;-))
Nice progress though :-)
cheers,
Dirk
I have made a reference to the source of the pictures as requested,   hope it helps.
OC.
Current builds
Completed works.
Link to comment
I’ve made a start on the upper hull. A little bit of a wash to bring out the highlights on the hull plates I scribed in and degaussing cables. I then gave it all a light dry brush of white to highlight everything. It actually looks a lot better in real life.
I have to do some streaks yet but im going to wait until I’ve done the Walrus Catapult as I have to scratch build the ends which were not included in the kit (or upgrade set) and a solid shields amidships.
Greg
Link to comment
I know the dry transfers are a bit iffy. The only problem I've had with them is when you need to place them on top PE plates. It always peel off down to the primer. To remedy this as possible as I can is to cut all excess material off the sheet.
On normal plastic I've not had any problems so far.
Link to comment
Same, the stuff for their DDG was just horrible, I’ve taken to using Tamiya rattle can Primer on big bits of PE after I wipe them down with acetone.
This is is an easy fix as I’ll just dab some little bits of black and red and overspray again with diluted grey.
Glad to see you on this forum as I believe youre from @cog ‘ s part of  the globe so you can instruct him as well, and you can join our next joint build later this year.
Edited by RGL
Greg
Link to comment
Greg,
Do you show how you affix the brass rod pedestals to your models in any of your logs?  I was going to go thru your logs again to see, but am lazy of course, and thought I'd just ask. :)
Alan
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
