USS Kearsarge by CPS_skybolt - FINISHED - BlueJacket Shipcrafters - Scale 1/96
Thanks s4usea. I have tried contact cement before. For the bent pieces I use CA medium glue for the quick hold. I prefer not to use CA because of the fumes. When I get to the straight I'll try rubber and silicone glue.
Bob
Edited by CPS_skybolt
Link to comment
Share on other sites
Day three of copper sheathing. Slow going but I enjoy it. I am using CA medium glue.  I make a small puddle of glue ( a drop or two ) and touch the copper plate to the puddle I can get three or four plates glued to the hull before needing to add another drop or two to the puddle. The time before this when I was copper sheathing the Constitution I  placed a drop of glue to each plate. To much glue.  I was getting glue on top of some of the plates. Also I was using kicker ( to accelerate the drying time of the glue ) which put a haze on top of the plates. I had to spray the finished bottom with copper paint. I want a shiny bottom on this ship. I used dividers to find the number of plate vertically for each section of the bottom. Then I made a curved pattern on the hull to allow me to have the last four rows straight. See the photo.
Bob
Link to comment
I have used  900 copper plates left over from building the BlueJacket USS Constitution to cover one side and the rudder of the Kearsarge. I have ordered 900 more plates from BlueJacket to finish the other side.
Link to comment
This really looks good! I love copper plating . . . it always gives a model a lot of detail and character. What kind of nail pattern do the Bluejacket copper plates have? As far as I know they are not embossed but photo-etched. Are they specifically designed for a 1:8 scale?
Thomas
Current Built:   Model Shipways  Syren  (US Brig 1803)
Last Built:        Anfora (kit bashed)  Ictineo II  (1st steam powered submarine 1864)
Link to comment
Thanks for your encouragement all. I am not very good at sheathing. I am now about 75% finished sheathing.
Thomas, I do not know the scale of the plates. Original plates was 14" x 48" on the real USS Constitution. The BlueJacket USS Constitution model is also a 1/96 scale model as is thier Kearsarge model. BlueJacket only offers one size copper plate. The  photo is of one of the plates offered.
The bottom photo shows the USS Constitution being sheathed. I thought it was interesting.
Bob
change picture and words
Link to comment
Thank you Thomas. I could not paint good lines just above the sheathing so I resorted to an old favorite of mine, decals. I painted a sheet of decal paper and cut strips for the waterline white stripe and the trail boards. The I used SOLVASET decal setting solution to secure the decals to the ship.
Bob
Link to comment
Bob
Beautiful matt paint
Link to comment
lovely work, the copper work sets the hull off very well, well done
Link to comment
Finished the two 11 inch guns. I fumble fingered my way through them. I have not glued them down yet. I used 28 AWG guage wire for most block pigtails. I used the kit wire for the larger blocks but that wire was to thick for the smaller blocks. I had bought the 28 guage wire at a bead shop when I was building the 1/96 scale USS Constitution. I had some super small bolts from model airplane builds that I used for gun elevation screws. I used scrap brass for the rails. I do not have a given work area for my model ship building so I use space in our large dining room. I lay down a large matt on the carpet floor then I set up two adjustable carpenter horses and lay a house door I bought for model building on top. I have a piece of manufactured marble that I lay on the door for a perfect flat work bench.
Bob
add picture
Link to comment
I made the  main and fore masts. The top masts are made from brass tubes and rod. Instruction said to drill three .020 holes in the assembled tube and rod for the topsail halliard. My drill bit is not good enough to cut through this so I cut slots and then soldered the rod and tube together. I put extra solder on the joint then put masts in a drill, rotated them and used sandpaper to shape the solder to match the mast tube size. I tried to free hand the slot but it was not uniform. So I put the dremel tool with cutting wheel into its dremel drill press. For stability and proper spacing I put a block under the cutting wheel as seen in the photo. I joined the rod and tube and soldered. Final mast assembly comes later in the build.
A note here, to anyone building 1/96 scale ship. Use brass tube and rod for the top masts. When I made the Bluejacket 1/96 scale Connie I was forever breaking off the topmasts as they are tiny wood dowel. I broke them off several times until I put the model in its final protective case. If you look close at my USS Constitution you can see the scars.
Bob
Link to comment
I completed the fore, main and mizzen masts. I placed the dowel for the lower masts in my small lathe and used 80 grit , 220 grit and a wood file to shape the taper of the masts. Upper masts are brass tube and rod. I placed the dowel for the yards in my drill and used 220 grit sandpaper to form the taper of the yards. These were easy and enjoyable to make. I used 28  AWG gauge wire for the ropes as I thought the kit wire to thick. I will set the masts in at a 5 1/2 degree slant aft. I will install the blocks on all of these next and assemble the masts with the yards before I glue the masts in place.
A note here: I think both sides of the weather deck is scribed for the planks. I would not use the side with the etched marks for the components locations. Some of the items do not cover the location marks on the deck. It does not look good. You can see some of this in Report post #48. Also, I should have marked off the beginning and end of the planks. Now the planks are as long as the deck.
to add note and make text corrections.
Link to comment
I had an idea for making adjustable shroud lines so I can adjust the vertical and horizontal of the masts. BlueJacket instructions said not to glue the mast in place. So I thought why not make shroud line beads. Plus it saves my trying to wrap the small line around and around again. this has probably been done before ( nothing new under the sun ).
Link to comment
So, as I understand it, these beads are premade seizings (?).  Fascinating idea.  Thanks so much for the info and the pics!  I will definitely give it very serious thought.  I understand how adjustable shrouds can change the alignment of the masts, but I don't yet see how it solves a curving mast, or, in some cases, a double bend that makes the mast a lazy "S".  As far as mast alignment is concerned, I  worked on the places where I will step the masts until I had perfect alignment, as well as the exact angle when I inserted the dowels.  I have procured dowels for the lower masts that are straight, but if I blow it, I may not be able to find others.  Then I will make the masts from square stock like many other modelers on this site do.  That way, I can try again and again until I get it right.
Edited by KHauptfuehrer
Link to comment
Thank you all for your thumbs up and comments. I have aligned the foremast vertical with a laser. I aligned the main and mizzen masts with eyeball. Tightened all the shroud lines and glued the first thread bead on each line. I will wait to align the 2nd and 3rd beads on each line when I get to the rat lines. So far the beads have worked well. The masts are not glued in. The lines are all that hold them  in place. The stays will let me adjust the 5 1/2 degree angle of the masts.  I think I will have to buy special cutters to trim excess thread from the beads as I don't want those ends showing, may sand them off with my dremmel. Then again how steady am I, LOL. My first attempt making 1/96 scale rolled up hammocks. Not sure these will stay, think I can do better, much better.
Edit, added note and photos: I used my dremmel with a drum sander ( used fairly smooth sanding surface  ) to sand the rat line stubs and it worked, smooth. I only used it on one side. You can see the stubs on the other side in the photo.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
