HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 60 donations so far out of 49,000 members - C'mon guys!) ×
Looks great GL The diagram of the parts on the deck was very helpful.
Michael
On 3/3/2019 at 3:49 AM, BANYAN said:
You've made some significant progress G.L.; it is all looking very good.  You must be close to finishing now?
cheers
Pat
Thank you Pat.
There is still some work to do: This week I will start to make the mast. That mast must also be rigged. The hull must be colored. I would like to make a work boat to store on the boat slide and last but not least the steam capstan has to be made. So enough to keep me busy for some more months.
Michael
11 hours ago, Backer said:
As always.
Beautiful and detailed.
Great work GL
Thank you Michael and Patrick
19. The spars.
19.1 The spars. Making the mast
To make the mast, I start from a square pine stock.
I narrow it towards the ends with the sanding belt.
I then scrape the corners until I get an octagon.
Next step is sanding the octagon to a round shape. The mast will keep its octagon shape from the mast step until about 6 cm above the deck and a square shape at height of the hound pieces.
382.thumb.JPG.917a372b854f3999a2b9376873fa496d.JPG383.thumb.JPG.0d38a8d9074ca38f900a900007d44b85.JPG
The mast on the cross section. It is leaning slightly forward just like on the real smack. (The picture of the smack O122 below belongs to Georges Verleene, the author of the practicum that I use to build this cross section. The helmsman on the picture is George's grandfather and the woman amidships his grandmother. In that era women did not sail on fishing vessels, the sails were probably hoisted especially to pose for this picture.   You can clearly see that the vessel is moored. )
384.thumb.JPG.1597276a49b4f5938d3eb9d3e9d4eeb6.JPG385.thumb.JPG.040a56fabcd7c0fe9f99b00b83927cda.JPG385a.jpg.3f3410ea4d46f39df0e487324deb6645.jpg
Making the hound pieces.
386.thumb.JPG.dc33d3212bb1f180dd581c7822a1f1d1.JPG387.thumb.JPG.7ffaba4d673d72c16a0e1feee8a8e52d.JPG
Making the trestletrees and the crosstrees.
388.thumb.JPG.6c6623e83f250565d4fc9172f00e669e.JPG389.thumb.JPG.eaf137b1919e644f264b57438d56f34c.JPG390.thumb.JPG.40881c7cc76a88a9315f670a59b8c3d1.JPG
Laying a metal band around the trestletrees.
391.thumb.JPG.3a8333e41521eb4de67b5ff189f4d101.JPG392.thumb.JPG.c5b956abc59f4980c8bf62f334063efb.JPG
Gluing the trestletrees with the bolsters on the mast.
3 hours ago, Mark Pearse said:
Hi GL
interesting. A couple of sail questions for you:
- do you know why they raked the masts forwards?
- were the topsails used regularly, or were they a 'race day' sail?
Hello Mark,
I must owe you the answer on the first question. I passed your question to the author of the practicum, his grandfather skippered a smack.
For your question regarding the topsails. A lot of the smacks had two sets of top gallants, one for the winter and a longer one for during summer. So I guess that the topsails were used, weather permitting, to sail to and from the fishing grounds. I am not aware if 'race days' by fishermen were organized in our region. To be sure I check it also with Mr George Verleene.
22 hours ago, G.L. said:
Hello Mark,
Just received an answer of Mr. Verleene:
He does not know either why the masts rake forward. Maybe someone on the forum knows?
The top sails were regularly used.
Thanks for putting my question forwards.
My gut feeling is that it's to do with the way the boats handled when working, & possibly to do with the topsails as the rake forwards affects the topsails balance the most. It could also be to do with the shrouds angle to the mast, as they don't seem to have running backstays.
Mark,
I think you are right about the absence of a backstay. With the trawlgate at portside just aft of the mast, there is no space for a backstay. That might be the reason why the mast is inclining forward to be better supported by the shrouds.
20.1. Finishing the hull. Dead eyes and chain plates.
Making hardwood disks to make the dead eyes.
Foto394.thumb.JPG.01182bdb3bc21f3ec7713f4cce8fb3f2.JPG395.thumb.JPG.be2b1c5da3d2901a19e722468081869e.JPG396.thumb.JPG.3891428614b4631610288f96e9121a8d.JPG
And at the other side I drill three holes in the position where they have to be in the dead eye.
Now I just have to place the dead eye in the hinge, close it and drill out the holes in the jig .
399.thumb.JPG.61d5206ac56309d0294d88fa3aecaaa4.JPG400.thumb.JPG.6a2cd00d6c52bc7cb4e4e25a34fa972b.JPG
I use the mill on the Dremel to make slits above the dead eye holes.
401.thumb.JPG.a9f71a1c227ddc625ef63375c03033ac.JPG402.thumb.JPG.4dbc634dfc3f65972165b94672cd8a65.JPG
I make rings from copper wire. The large rings will become the iron bounds and the small rings the iron bound rings.
403.thumb.JPG.6fb366cc297d9dceeb6f7e42c9cc8aee.JPG404.thumb.JPG.3518ac4acb647f79457ff9da2d2d6853.JPG
Soldering the iron bounds.
405.thumb.JPG.a615f2f8775383a7a043cf32ce9875ef.JPG406.thumb.JPG.a6830677a72102eaa269711edd60f4f2.JPG407.thumb.JPG.c67006a3242ac5d60f422a7e8d322bd5.JPG408.thumb.JPG.a7380cfdc7de75fa5ff9195a2a0512d7.JPG
The making of the chain plates is very similar to the making of the hinge of the trawl gate. First bending a strip of brass around a 1.5 mm drill to make a loop at the end.
409.thumb.JPG.d6a34aa52de555a372ae616957c5ed94.JPG410.thumb.JPG.21f06fa897e50013d85680d5227a3852.JPG
Closing the seam of the loop with solder and sawing the outer ends of it.
411.thumb.JPG.61b094e1b641cf994f9dc8af82fe3918.JPG412.thumb.JPG.930673127976bc7dc46072a62b1d64d7.JPG
The assembled dead eye and chain plate.
I determine the angle in which the chain plate has to be placed with a string around the trestletrees.
To have the dead eyes at the correct height, I lay a wooden lath as height indicator on the rail cap...
... and mark the middle of each wale plank on the chain plate to drill the bolt holes.
Once the holes are drilled, I mark the holes to be drilled in the wale and drill them.
417.thumb.JPG.b407e05a5aaef477f4c6b4f82f5e909f.JPG418.thumb.JPG.9a2b766b118820dcb86814b771e24163.JPG
Now The recesses can be sawn in the rail cap and the chain plates can be nailed into place.
419.thumb.JPG.71541258dbfbc10c57120dd8dbf0b073.JPG420.gif.b3cb16585697e12a18e9cd6b60ebf34e.gif421.thumb.JPG.918b8fcca25a1a5a360daec52d41c708.JPG
Just below the cap rail the chain plates are supported by a wooden 'guard'.
Guard, ready to be placed.
Port guard into position. Kept in place with two glue clamps until the glue is dry.
Below the railing and on top of the wale a rub rail is glued and kept in place with tape.
Starboard side.
Loved the hinge jig. One to remember.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
On 3/17/2019 at 7:28 AM, Backer said:
Nicely made and very well explained.
Always a pleasure to follow.
Thanks  for your comments and interest Patrick and Keith.
And also thanks for all the likes.
This week I finished the bulwark:
I make some rings of copper wire...
...and three large oak cleats.
426.thumb.JPG.c3473b7decde85b79dc75bcc6778bd9c.JPG427.thumb.JPG.4b77706ae5c71ef838d6a33ae8b0c927.JPG
Rings and cleats attached on the port railing ...
...and starboard railing.
Edited by G.L.
20.2. Finishing the hull. Protection planks.
The hull area behind and below the trawl gate was protected against the rubbing of the trawl and the trawl rope by a local doubling of the hull planks
Gluing the planks.
Doubling finished.
Well done!
John Allen
Current builds HMS Victory-Mamoli
On deck
USS Tecumseh, CSS Hunley scratch build, Double hull Polynesian canoe (Holakea) scratch build
Finished
Waka Taua Maori War Canoe, Armed Launch-Panart, Diligence English Revenue Cutter-Marine  Model Co.
20.3. Finishing the hull. Painting the hull.
I tried to postpone this part as long as possible. I decide to go for a tarred look above the waterline like I did for my Ostend shrimper. Below the waterline I want to go a kind of anti fouling or copper paint.
My instruments to draw the waterline are very basic: a spirit level from railing to railing and a pencil attached to an L square do it perfectly.
Mask taping ...
... and painting the tarred part with oil paint. I put thick layer oil paint.
After some hours when the paint had some time to dry a bit , I rub it up with a  cotton cloth.
When the paint is dry enough to apply mask tape on it, I paint the rub rail in white.
Below the waterline I want to paint in a copper paint color. I made several color samples. I mix of medium cadmium red and burnt sienna acryl paint seemed the best to me.
I want to highlight where the hull is cut to obtain the cross section. Therefore I make the edge of the gash red with oil paint.
477.thumb.JPG.9abb1c4378530c3a9eaa4077dcbff749.JPG478.thumb.JPG.f02c877ad7c4fa5bbc1a65322511df33.JPG
The last step in coloring the model is varnishing it with matt varnish.
479.thumb.JPG.4ee9520c09db88d72f45256a4abf2033.JPG479b.thumb.JPG.3a67b3c78b2bdf65035ae1bbff86b9ac.JPG
Nicely done -  very pleasing result.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Thank you, Keith
On 3/31/2019 at 3:47 AM, BANYAN said:
Looks great GL!
cheers
Pat
Thanks, Pat
On 3/31/2019 at 5:20 PM, cog said:
turned out pritty spiffy!
Carl,
I have no idea what 'pritty spiffy' means but I assume that it is a positive comment, so thank you also very much.
19.2 The spars. The mast fittings.
19.2.1 The Mast hoops
I make mast hoops of pit cane. It can be bought in hobby shops and is used for basket braids and flower arranging.
The outside surface of the mast hoops is flat, the inside round. To make the flat surface I cut a slice of one side of the pit cane.
The I make the pit cane wet, wind it around a round pipe with a slight bigger diameter than the mast and let it dry.
Next day the pit cane can be removed from the pipe like a spiral to be cut in separate rings.
436.thumb.JPG.4478973e7b280a648dbe3513473f567d.JPG437.thumb.JPG.09f96a3bc42249f38f94d0e6744787c0.JPG
I make a jig to glue the mast hoops. A wooden plank in which I drill holes of the same diameter as the mast hoops. With the help of that jig I determine the exact size of the pit cane rings and the overlaps that I need to glue them.
I file the overlaps. Put some wood glue on them and press the hoops in the jig.
439.thumb.JPG.5fe7936b765e5ed2d4990afa3f235f7a.JPG440.thumb.JPG.2db7c83685563995efd0178da51d715d.JPG441.thumb.JPG.b709f2850c0e20e3bca9f716f9e0374b.JPG
The mast hoops, stained and varnished around the mast.
On 4/6/2019 at 8:47 AM, G.L. said:
Thank you Patrick, trying to keep up the standard of the Belgian ship modelers.
And you do that very well !
