Hi all, this is the start of my latest Card model- a Yamaha MT-01, which was built between 2005 and 2012. As I did with the other Yamaha (YA-01) I built this will be a very truncated Build Log, consisting of pics of the major stages. Here's a pic of how it will look (hopefully ;) :D) :
I started this one by building the wheels to see if I would carry on with the build. If you saw my YA-01 the wheels were the hardest parts to build, and didn't turn out 100% on that one. This time they turned out a LOT better, not perfect due to the tags, but still good enough to keep going :). The design, being mag wheels, was different to the spoked wheels of the YA-01. Here are some pics of the wheels :
My method of fitting the last part - a band in the middle of the tyre. I glued extra card between the tags to get them the correct distance apart and stabilise the whole unit, which had significant distortion and stress before I added them :
Punching out the cooling holes in the twin disc rotors :
The completed front wheel :
And the HUGE rear wheel. I'm fairly happy with the way they turned out, so the build will continue :) :
The two wheels for comparison :
Danny
Cheers, Danny
nice, Dan. brings back the memories. now I'll see what else I did wrong...😄
cheers!
Denis
In Progress:             HMS Pandora 3D modeling
Finished Builds:       Swan Class HMS Pegasus for Admiralty Models 3D Build
                                German Type VIIC U-Boat 3D model
My other 3D work:  Artstation
yup...that would have sent me scream'in out of the room  ;)     they look awesome!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks guys. Denis, I doubt you did much wrong on yours, it looks great in the pic :).
I've made the tail-light/rear mudguard assembly :
Now to start the motor. This has 13 pages of parts, so it may take a while.
Danny
Cheers, Danny
There are three sections in each of the two barrels, and 17 rows of fins in each barrel. Cutting,folding and gluing the fins took the best part of two days :
Danny
Cheers, Danny
just two days?! 😯 take it easy with the coffee, will you? 😂 took me best part of three weeks...
cheers!
Denis
nice pair of 'jugs' Dan!   :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Here are most of the pieces of the crankcase. All of them have been folded and glued ready to assemble :
The crankcase assembled :
The barrels and other accessories fitted to the crankcase. That concludes the engine, I'll put it aside for now :
Danny
Cheers, Danny
Thanks Richmond :).
I've made up all the side covers. The louvred one (top left) was particularly tricky to make :
Danny
Cheers, Danny
Lots more done. Here is the partially completed frame :
And more frame pieces :
The start of the rear suspension :
Danny
Cheers, Danny
Thank you David and Richmond.
The completed rear suspension, chain and it's guard and the lower mudguard :
The front mudguard. LOTS of tabs :) :
The front forks. There is a paper tube running the full length, they're quite strong :
The front disc brake calipers :
The brake and clutch levers. These were a bit difficult to make, but they turned out very nicely :
Danny
Cheers, Danny
Wow, I missed this one so far.
You tab-gluing-speed is unbelievable :)
Before long you will need more tabs and parts to fulfill your needs.
There are some very, very demanding models around (not ships, but cars) These models for instance would keep you at least two weeks from the street:
http://e63papermodel.altervista.org/download.html
(only edge gluing, no tabs at all. They have some unbelievable detail)
Jan
Wow !!
super stuff Danny...
Nils
Current builds
-Lightship Elbe 1
Completed
Thanks David, Jan and Nils :). Jan, I've seen the Ferraris before but I can't remember the site they can be bought from. Do you know what it is?
This is the front suspension, steering and handlebars. The top bracket has not yet been glued in, as it needs to go through a tube at the front of the frame to enable the steering to turn. I actually made a mistake with the previous bike, gluing it in this stage, and had to cut it apart again. Lesson learned ;) :
Danny
Cheers, Danny
The Headlight :
The exhaust system. Some sections are glued together after fitting the first ones :
Finally, the seat :
Danny
Cheers, Danny
superb progress since I last looked in Danny :)    really looks great!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks Popeye.
The two crankcase side covers, footpegs and levers :
That's all the parts finished and glued into modules. All that's left now is to glue all the modules together :).
Danny
Cheers, Danny
Fitting the motor to the frame :
The airbox took a bit of tricky fitting, aligning the two pipes :
The exhaust system fitted rather well, although I had to cut one piece off and re-align it slightly. I started by gluing the two short pipes into the barrels :
The tank and seat had to be modified quite a bit before they'd fit properly. They both turned out OK :
Danny
Cheers, Danny
The model is now finished. I made a simple stand from cedar and gave everything a couple of coats of clear gloss :
My next "real" model will be a WW2 tank made again from Card. While waiting for it I downloaded a fairly simple ship - a German Monitor named Mosel. A link to it can be found in my Signature.
Danny
Cheers, Danny
lovely work Dan, do you feel like getting back to another wooden build ?
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Thanks Kevin. I'm going to stick with Card for a while yet as I don't have a workshop suitable for wood models at the moment. That may change in the future.
BTW - I edited your Signature to make it a bit smaller. The links now work by clicking on the model's name instead of using a separate one.
20 minutes ago, druxey said:
Impressive, Dan! Well done. Aren't you going to build the rest of the Yamaha models as well? ;)
Thanks David. I'm a bit "over" these particular kits - they aren't particularly well designed. My next kit of a WW2 German Tank looks like it will be quite challenging :).
Danny
Cheers, Danny
Danny
Thank you for sorting that out for me, looks much tidier
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
