The sails look fantastic! I need to read up on this subject.
     Current:         Emma C. Berry Lobster Smack-Model Shipways-1:32-1866
        Back on the shelf:    USS Essex- MS- "Old Yellow Box" Solid Hull  Wall Hanger (Half Hull)
   Completed:    18th Century Armed Longboat-MS 1/24
                          USN Picket Boat-MS 1864 1/24
                          US Brig Syren by Sea Hoss- Model Shipways-1803
                          18th Century Carronade/Ship Section
                          Mayflower-Pilgrims Pride by Sea Hoss-Model Shipways-1620
                          18th Century Long Boat by Sea Hoss-Model Shipways
                          USS Constitution by Sea Hoss-Revel-Plastic
Thank you all very much for the comments and the likes!
 The fore top gallant sail is on and rigged.
 I did much better on the bowlines and the bunt line.
That leaves two royals, the main sail and the top main staysail plus the stun sails.
 The stun sails will be the last sails to be installed due to the necessity of being able to belay lines around them.
Building:
Stunsails... not often seen here.  Obviously you're looking at sailing in light airs?  ;)   She should look great with them.
I learned a lot this build.
I learned to watch scale.  That was my single biggest problem.  I used multiple sources, all at different scales.  I also learned that both pages on a plate in a book may not be at exactly the same scale.
I learned how to interpret line drawings better and make bulkheads from them.
I learned how to make my own blocks, eyebolts, deadeyes, gratings and other fittings.
I learned more about carving.
I learned more about the operation of sailing ships, which was crucial during the rigging stage for visualizing where lines ran to.
I learned to think on the fly when trying to make parts.
This is the most fun that I ever had making a model.
I made many mistakes, but I learned from every single one, and I will pass that experience on to my next project, which will be finishing the Victory.
Thank you all for the likes and the comments along the way.  They were very motivating.
Thank you everyone that took the time to teach me more.
Thank you everyone for sharing your knowledge.
I appreciated all of the support and assistance.
Building:
Very well done, Phil.   One would never know that is the first of hopefully many to come.
  • 1 year later...
On 8/9/2019 at 11:33 PM, GrandpaPhil said:
The Prince de Neufchatel is done.
It’s my first ever scratch build.
I learned a lot from this build.
I thoroughly enjoyed it.
It’s not perfect, but it’s not bad for a first try.
Beutiful GrandpaPhil. i can imgine her fly under such enormous sails. thak youvlad
The thing is, that the Prince was captured after days of chase by several frigates (including HMS Endymion, which was the fastest frigate of the Royal Navy by that time), because one of her masts cracked a tiny bit under the pressure of all her sails.
