  • 11 months later...
49 minutes ago, Matt D said:
Are those spiders any good at planking?  I might need to borrow them.
I did hope so..... but  notthing is happening😄 maby these just rund around and doing some pinning😂
Nice job on this planking. The first belt on the starboard seems really very beautiful.
Jean-Paul
'You are not carving a bear with a chain saw here folks',
Chuck Passaro, ´Queen Anne Style Barge´ manual of instructions
Current builds :
Finished build :
Next on list :
  • HMS Winchelsea 1764 - Syren Ship Model - 1:48
Nice to see another Cheerful underway. I can see you're in great shape for the square tuck
Edited by glbarlow
Regards,
Glenn
Current Build: HM Flirt
Very nice job on the planking!!!
MAury
thanks for all the coments and likes... 😊
am getting ready to plank the 2 plank belt , all the tick marks are in place and i also took a control of the run,
wat i can se at the bow is the plank seems to go more upwards then the first belt .
in my 2 belt there is totel of 10 planks if i go dow to 9 i may have to use a drop plank aft,
i think is going to be to wide ....
The curve is too severe on those planks already on the hull.   They should be straighter at the bow....it should follow your lining off if that was correct.
Chuck
Chuck
thats wat i was afraid of.... lol  i need to ripp of te 2 plank and re do it so it flows strait and follows the marking i made..
It does get a bit tricky at this point, your eyes seem to tell you one thing but that doesn't correspond to the tick marks.  You really have to trust the marks, I found trimming based on the second bulkhead vs. at the bow worked better, plus constantly rechecking the remaining distance.
Your planking is looking great, nice and tight.
Regards,
Glenn
thanks for the advice and warning......  and yes my eyes are playing with my head😨,
i think i need to ripp of the garboard plank also and make a new one and place it more fare back then i did
so it wil flow more strait into the bow 😊
svein erik
20 hours ago, svein erik said:
the garboard plank
I played around a lot with that plank. It’s a challenge to get it right for sure.
Regards,
Glenn
some new photo , my eyes diddent want to see wats going on ..... so i have to lay out some tape strips to see the run for the plank
at the bow , i do have tick marks but it seem wrong , the tape helps me on that.
the are 10 planks to the keel inkl. the garboard plank, i can know see were it goes , and it seems i have to place it up wards in the bow to get it
right for my planks , i may have dunn something wrong with my other planks so i have this problem know...
in chucks photo the garboard plank sitts more aft then mine, maby it dosent matter at this point.....
in one of the photo i mark the garboad plank in red so you can see were it goes.
svein erik
Hi again, and tanks for the likes ...
i have just discover something on my plank sheet spreder,
the provided marker for 5/32 plank does not match the 5/32 sheet (ca 4mm wide) is more betwin 3/16 to 7/32 (5mm)
i think also this my had some impact om my planking since i have used this marker in the prosess ,
se the photo.
Aren't you using 3/16th for hull planking?  My planking fan downloaded as part of the monograph only has a pre-defined line for 3/16th.
Regards,
Glenn
yes a do use 3/16 .... i yust some time ago take some messurment from this why.. i do not know..LOL,
in the future i need to check wat i have is correct.... but its to late now so i just has to go with wat i have.😊
