Hi ZyXuz
Thank you for that valuable hint.
 In fact I tried something similar during the first repair. But because I left all the shrouds and the stays in place I was only able to insert a perhaps 1cm long piece of wire into the mast. I gave not enough strength and broke again. Hence the replacement with an all new topmast.
Otherwise I’m sure that your method could save many a broken spar.
Cheers
Peter
The broken topmast and its cap were dismantled. I left the Shrouds etc. fixed to their dead eyes but I will have to set them up again with new lanyards. At least it shall be possible to keep the ratlines and the deadeyes.
The new mizzen topmast and a new cap are ready to replace the broken parts.
I decided against making an all new mizzen top from scratch – I’ve got a lot of extra work already and am too lazy to double or triple it
The captain musters the new topmast and cap
The mizzen top ready for a new topmast
The new parts provisionally in place
It didn't take you too long to get back on the go after your mishap.
Looks good, hopefully nothing more will go amiss.
Andy
Quando Omni Flunkus, Moritati
USF Confederacy
Next in line was the fore topgallant yard. Here the dimensions in the plan are in agreement with what I found in James Lees’. It was a straightforward job.
New pillar in place
I’ll have to scratch away the superfluous CA glue
Those nasty pillars still haunt me. So much so that if I don't have the exact height and diameter, I not have them laser cut for the profile and the modeller then just has to file/sand the corners smooth - they then look much better.
Nice job, by the way, I enjoyed looking through your build :)
Vanguard Models on Facebook
Hi Andy
Yes, if the beast throws you off, you have to go back into the saddle again as fast as possible. I guess that’s also true for flying horses.
Cheers
Peter
Hi Chris
Thanks for the compliments.
Haunted by those pillars…what a blood-curdling thought… ;)
No, seriously, it’s much easier than I thought to make a replacement yourself and to patch up that little mistake.
Of course there are some small possibilities for improvement in that kit, such as providing square strips (of sufficient size) for upper masts and yards or the question of the size of the mizzen top investigated by Blue Ensign, but…
This is still the most wonderful kit I have been building , classes better than those from Corel or Mamoli (they are quite good) and  rivaled only by Caldercrafts  Granado (perhaps you happen to know the designer of that kit??!).
Perfection is unaffordable – I really appreciate that you continue striving for it.
Thank you
Peter
Hi Peter,
Great fix my friend, back on track again, well done. :dancetl6:
Murphy was from the Republic of Ireland I believe but the fact he was Irish is sometimes enough. :D  :D
mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
It's looking good.  Chances are that when it's all done, you'll completely forget about having to do a repair -- you'll just remember that you enjoyed the build.
Cheers,\
Martin
Current Build:  HMS FLY 1776
Previous Builds:  Rattlesnake 1781
                        Prince de Neufchatel
Hi Mobbsie
According to the web he was probably an American aerospace engineer, Major Edward A. Murphy Jr.
But whatever he was, I’m really glad it seems he was not associated with the development of the Swiss army knife. A point for us Swiss.
Hi Martin
Yes, it’s finished now and it really was an interesting little project. Fortunately only one ratline had to be retied.
Cheers
Peter
The New topmast could be set up using the existing rope work. Initially the top cap was left off so the shrouds and stays could slip over the new mast. Then they were set up with the old deadeyes and new lanyards. Only one ratline broke and had to be retied. Now it’s better than new and it was an interesting piece of work.
The captain checks the new topmast from the main top
Backstays are in place again
A last critical gaze from the captain – all is well
Thank you, B.E.
By hindsight it actually was fun.   ;)
Peter
Very nice fix on the mast, Peter, it looks great :)
I think it was sort of a blessing in disguise that it happened this early, imagine how it would have been if it snapped when all the running rigging is already in place :o
Best regards,
Aldo
Currently Building:
HMS Pegasus (Victory Models)-Mothballed to give priority to Triton
HMS Triton (first attempt at scratchbuilding)
Past build:
HM Brig Badger (Caldercraft), HM Brig Cruizer, HM Schooner Ballahoo
Hi Timmo
Thank you, but isn’t brilliant a bit shiny?
Hi Aldo
Thanks, but no, I’d rather not.
Hi Frank
Thanks mate, but I’m a bit unsure – considering the way you make your ship appear - if ‘looks like new’, coming from you, really is a compliment. ;)
Take care
Peter
That's an impressive fix Peter, very well done.
You have some lovely rigging there as well, no wonder the Captain is looking happy. :dancetl6:
Keep up the great work.
mobbsie
mobbsie
Next Build :-
Now the work on the main topgallant mast could continue.
The shrouds were a straightforward job (no ratlines!!!!!).
The size of the backstays had to be corrected. Again they should be made of the same rope as the stay. The lower ends however presented a problem.
According to the plan and James Lees a thimble should be used. As such parts are not provided with the kit I used a small dead eye on the backstay of the mizzen topmast but this looks somewhat oversized. Now I tried to simulate it with just an eye split. But this looks wrong as well. Therefore I ordered the smallest thimbles available from cornwallmodellboats and will have a try.
While waiting for them I started fixing the spare spars with some hidden nails in preparation for placing the ships boats. Those will be Caldercrafts 24’ cutter and 19’ launch.
Work on main topgallant mast has been stopped after the first backstay
Unsatisfactory lower backstay end with spliced eye
Mizzen topmast backstay with rather large deadeye
Spare spars in place and shells of boats placed provisionally
Edited by flyer
Peter,
Hi. I discovered your Pegasus when you were kind enough to visit my build just as I was leaving for a few weeks.
I'm back and I went through your log from page 1. You are such an artist. I would not know where to begin with the accolades.Your attention to details, that you replicate so well are a joy to look at. Wao!! Super nice. I'm happy that I found your ship. I will certainly copy some of your details especially when I start the masts and rigging. Beautiful project. I look forward to your updates.
Regards,
Michael
Michael
Current buildSovereign of the Seas 1/78 Sergal
Under the table:
Golden Hind - C Mamoli    Oseberg - Billings 720 - Drakkar - Amati
Completed:
Santa Maria-Mantua --
Vasa-Corel -
Peter,
OH I just thought of something....have you been to this AMAZING place??
Watch it in 1080 and full screen (:-)
Michael  (It's on my list)
Edited by md1400cs
Michael
Under the table:
Completed:
Vasa-Corel -
Hi Michael
You are overdoing the compliments a bit (but I like it). :blush: :blush:  :blush::D:blush: :blush: :blush:
I’ve heard of that other place in Hamburg from a friend, but only about the model railroad, not that airport. Amazing is the word!
Cheers
Peter
The standing rigging on the main mast was now finished.
Amati’s 2,5 mm deadeye with a single hole seemed worth a try as wooden thimbles. They look ok.
The bosun is happy about the new thimbles.
Installing the crowfoot on the main top I saw that I had made 2 mistakes on the mizzen: First I took the wrong (0,2) thread and for the euphroe block I only took one photo etched part while you better use the two identical parts together, glued back on back. I will have to rig the mizzen crowfoot again.
Main top with finished standing rigging
Ascending to the main top
Main topmast trestletrees
Foot of the foremast with topmast stay and preventer stay
Hi Peter nice work on the rigging one tip leave as much space in the middle as possible, do not fix the spare spars and boats till as late as you can, it gets very crowded, as there is so much rigging to tie off in small spaces.
Ray
 Current build A set of HMS Diana`s boats @ 1/48
 HMS Royal Marine a Military class Trawler
 Completed  HMS Diana
Completed build The Lady Nelson
Completed Build HMS Pegasus
Hi Aldo
Thanks for looking in.
I got the impression that you are taking a break in the work on your Pegasus, concentrating on your wonderful Triton. Another one lost to the dark art of scratch building…?
Hi Ray
Thank you for the sound advice. Of course it’s a bit of a dilemma – after finishing the rigging there will not be enough space to fix the spars and boats. I guess those ‘ships-in-a-bottle-problems’ are part of our hobby and you probably would meet them even if building in original size. We know it from other work areas, e.g. trying to bring the furniture into the new house and realizing you should have done it before fixing the roof…
The spars are still provisionally mounted and I delay the definite fix as much as possible until I will have missed the optimal point…
Take care
Peter
In between the work on the masts I started on the first boat, Caldercrafts 24’ cutter.
The rips were made according CC’s instructions. Contrary to them the floorboards were not mounted on the prepared piece of plywood but directly on the floor. A cockpit floor and a small ’deck’ up front (I wonder what’s that actually called?) were added.
For those 2 details and a lot more information I used Chuck’s beautiful longboat as source – thank you, Chuck. The rowlocks were filed into the side as per CC’s instruction.
Further detailing of the boats interior will not be made as the smaller cutter will be stowed inside this one. For the coloring I followed mostly the instructions and just added some blue to make it ‘the blue cutter’.
The rips are made from cartridge paper
Floorboards are added and the risers are being glued in place
Cockpit floor added (the boat sits on a copy of Chuck’s longboat- that’s a perhaps a bit impertinent)
It’s now the ‘blue’ cutter
Front platform added
Cockpit seats added – the captain inspects the new boat
Provisionally stowed – looking at those pictures I think I will have to make a kind of support to keep the boat stable on the spars
Edited by flyer
Lovely work on the cutter Peter, and yes you are right mate, you will have to build a support for it and lashing points.
Will you be fitting it out with oars, anchor, rope ect, it all helps to bring it alive.
Good work my friend.
mobbsie
mobbsie
Next Build :-
Nice details on the Blue cutter.  I especially like the flooring.
As for the oars, I believe Chuck had a thread -- it might have been back in the antediluvian MSW.1 -- on making oars.  I followed it and got nice results, and I'm only a beginner.
Cheers,
Martin
