I am planning to try my 1st scratch model with the HMS Winchelsea.
I have a little work to finish on my New Bedford Whaleboat before I start.
I will most likely be purchasing some of the laser cut items.
Looking forward to this as a fun project and a great learning activity.
CURRENT BUILD:
HMS Winchelsea, 1764 ~ 1:48 scale
COMPLETED BUILDS:
New Bedford Whaleboat ~ 1:16 scale
Ships in Bottles Models
Card Stock Nautical Models
~Donor & Member of Nautical Research Guild~
Getting very, very close to finishing my New Bedford Whaleboat, so I ordered the laser cut parts
for chapter one of the HMS Winchelsea this morning from Syren Ship Model Company.
Looking forward to the fun of building her and learning about non-kit building!
CURRENT BUILD:
COMPLETED BUILDS:
Received my order yesterday from Syren for the laser cut parts for Chapter One of the Winchelsea 1764 project.
I ordered the parts for Chapter Two and the Brackets for the false keel last night.
Ordered a Wren scroll saw and extra blades from Amazon this morning, I have also been watching YouTube videos on using a scroll saw.
Edited by RBohlman
update
CURRENT BUILD:
COMPLETED BUILDS:
Printed and cut out pattern for False Keel yesterday.
Made a trip to my local Home Depot for some 1/4" plywood and sandpaper.
My Wen Scroll Saw should arrive from Amazon this afternoon and going to practice with it awhile before
starting the cutting of any Winnie parts.  Heading out the Walmart early this morning for a can of Krylon spray temporary glue.  :)
Edited by RBohlman
update
CURRENT BUILD:
COMPLETED BUILDS:
Spent the morning getting my new scroll saw set up for Winnie.
It gets hot here in Mississippi, so planning to do some practice work tomorrow and then
start my False Keel and Bulkhead work.
CURRENT BUILD:
COMPLETED BUILDS:
I got to work a little on the printing and plywood cutouts for my Winnie.
I had to stop before noon as the garage gets very hot here in central Mississippi.
I plan to do some scroll saw work tomorrow morning early while it is still some what cool.
CURRENT BUILD:
COMPLETED BUILDS:
Received my Syren order yesterday, Chapter Two & Bracket laser wooden parts.  I have started cutting out the bulkheads on my new Wen scroll saw, l am using an Olson PGT No. 7RG blade.
The No. 7RG seems to work well, but being a newbie to scroll saw work, is this the best blade for cutting out the 1/4" plywood bulkheads?
As always, Thanks for the help!
Edited by RBohlman
Typo
CURRENT BUILD:
COMPLETED BUILDS:
Watched your New Bedford Whale Boat build, I'm sure you'll do a great job here too!, I'll be watching with interest.
     Current:         Emma C. Berry Lobster Smack-Model Shipways-1:32-1866
        Back on the shelf:    USS Essex- MS- "Old Yellow Box" Solid Hull  Wall Hanger (Half Hull)
   Completed:    18th Century Armed Longboat-MS 1/24
                          USN Picket Boat-MS 1864 1/24
                          US Brig Syren by Sea Hoss- Model Shipways-1803
                          18th Century Carronade/Ship Section
                          Mayflower-Pilgrims Pride by Sea Hoss-Model Shipways-1620
                          18th Century Long Boat by Sea Hoss-Model Shipways
                          USS Constitution by Sea Hoss-Revel-Plastic
Getting ready to build my brackets and stand to support my Winnie as a construct her and have a few questions.
What size is the wood base the model is build on in this early stage?
What is the size of the wooden strips used between each bracket?
Are the wood strips glued or screwed in place?
What size screws are needed for the six (6) brackets?
Thanks as always for the help!
CURRENT BUILD:
COMPLETED BUILDS:
It’s not really important.  Just use any scrap you have laying around.  Make sure the base is larger than the model is long and wider as well.  That’s about it.  The strips can’t be wider or taller than the keel but anything will work.
I got to work some more on my Winnie this morning.
I have been dry fitting my bulkheads to the false keels as I cut them out.
I have not glued anything at this point just checked the fit of the sections as I cut them out.   :)
Edited by RBohlman
Typo
CURRENT BUILD:
COMPLETED BUILDS:
She’s looking great!  What variety of Home Depot plywood are you using?  I was thinking about starting this project and doing the same thing, but I am not sure which 1/4 inch plywood would work well versus the more expensive Baltic birch 5-ply stuff that I’ve seen at the craft stores.  I don’t mind spending $70 on plywood, unless I can get away with spending $30.
HMS Winchelsea 1:48 (Group Project)
Completed Builds:
Virginia 1819 Artesania Latina - 1:41
Guess I'm just cheep at heart ~ The $5.00+ per each 1/4" 2'x2' Home Depot plywood.
Since it will be planked over anyway,  I just went cheep for the False Keel & Bulkheads.
I did go through the bin and picked out the best looking plywood pieces.
Edited by RBohlman
CURRENT BUILD:
COMPLETED BUILDS:
The last 2 pages in the Chapter One notes from Chuck show his board and supports - you can estimate sizes from that.
Doug
Current BuildsBluenose II - AKrabbenkutter / Prince de Neufchatel / Essex Cross-section / Syren / Barque Stefano / Winchelsea / Half Hull / Maria HF31 - Dusek / Bandirma - Turkmodel
On the Shelf: Santisima Trinidad and Cross Section / HMS Cutter Alert / Tender AVOS / Confederacy
Suspended Build: Bluenose II - Billing Boats Nr 600
36" long and about 12" wide will do the trick.  Make sure its at least 1/2" thick and not warped.  MDF is perfect for this.
THANKS ~ Just the info that I needed!
CURRENT BUILD:
COMPLETED BUILDS:
I finished my Bulkhead Form and my next step is to construct the Build Board.
I have all the wood and parts needed but it is so very hot in the garage this afternoon , 102 degrees, here in Mississippi.
I hope to do some table saw work in the morning!
CURRENT BUILD:
COMPLETED BUILDS:
Completed the construction of my Build Board for my Winnie.
Now, on to cutting out and fitting the remainder of my bulkheads on my WEN scroll saw.
Edited by RBohlman
Typos
CURRENT BUILD:
COMPLETED BUILDS:
