22 minutes ago, VTHokiEE said:
Thanks Lyle!
I finished up another belt before I had to store her away for a move. I'll be looking forward to finishing her up once we get settled - each belt seems to look a lot better than the last so I definitely feel like I'm making progress in my efforts. I left some extra length of the planks over the counter and chiseled a (somewhat) straight and even line with the wale once they were all installed.
My camera gear is all packed away, but here is a parting shot.
Hope your move goes well mate  - never an easy thing  - Will be great to see you building again mate.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
The planking is looking excellent...Moab
Completed Builds:
Virginia Armed Sloop...Model Shipways
Ranger...Corel
Louise Steam Launch...Constructo
Hansa Kogge...Dusek
Yankee Hero...BlueJacket
Spray...BlueJacket
26’ Long Boat...Model Shipways
Under Construction:
Emma C. Berry...Model Shipways
  • 2 months later...
I've been neglecting this log for a little while mainly because I've had a lack of motivation (which is mainly my fault) and I'm hoping this bump of a post will help encourage me to get on with the show. I'll confess that as my planking progressed it became obvious (to me at least) that I didn't fair the frame well in spots. The real solution would be to tear down and start again, but this is a learning experience for me and I don't see myself finishing the build going down that path with this tutorial. However you better believe that I'll be doing a lot of checking to make certain I'm confident in my fairing next time I start to plank a hull - there is no covering it up with a single planked model. With that said - onward to the current state of the build.
She really doesn't look too shabby from this angle.
DSC_0007.jpg.0d8c56677df18a90db5142540227db0b.jpgDSC_0008.jpg.364e307a62a39128e3861e4be6e38b7c.jpg
Not quite as smooth as it could be from here however.
I also don't feel like I did a great job with how the wale and the counter met, but I'm not really certain what I did wrong (or if anyone can tell from the picture). Any insight there to take forward with me would be much appreciated.
Edited by VTHokiEE
Very happy to see you back. I am still working on my other projects but I am definitely going to build this half hull and certainly appreciate your doing it ahead of me. Sorry I cannot help you with your counter but I am not very knowledgable in the 18th century modeling.
Welcome back
Ras
Current builds:
USS SAN PABLO-1920-1/64 scale-River Gunboat
Previous builds:
Stern Paddle Wheeler ZULU-1916-1/48 scale
Freccia Celeste-1927 350cc racing motorcycle-1:9 scale- Protar kit
Boeing B17F- 1/72 scale- Hasegawa kit
HMS Mimi-scale 1/24-Fast Motor Launch
Amapá 1907-1/64 scale-Brazilian Customs Cruiser
Scottish Motor Fifie. 1/32 scale. Amati kit
Patricia. Steam powered R/C launch. 1/12 scale. Krick Kit
African Queen. Steam powered  R/C launch. 1/24 scale. Billings kit
Emma C. Berry. Sailing fishing smack. 1/32 scale. Model Shipways kit.
Thanks for checking in and I look forward to seeing how yours comes together when you get there. I keep looking at the exemplar build and I’m starting to think I initially placed the counter slightly off and then didn’t fair it quite as well as I should have. The directions seemed vague to me at the time for how exactly to place that part.
1 hour ago, Cathead said:
Looks better than mine!
Oh you’re too modest, but thank you!
I agree that the directions are pretty difficult to follow regarding how to handle the complex planking around the counter, and none of the photos really capture it in progress. I had to study a lot of different images to even get as far as I have.
Great seeing you back my friend  - fairing the hull was a real pain for me  with my wood build  - so hard to get a perfect smooth  run of planks,  its down to ourselves also  how perfect we want to make it.   Is that the first or second planking?  reason I ask is,  the First gives  you more wriggle room if you wanted to try to sand down the high spots, also  with the  wale  could you not just meet the counter the same way  you have it but with more planks on the counter to match the extra wale planks (I assue you are adding)
Not sure if that was of help Tim?  its hard to come up  with ideas some times  unless one is building the  ship  your self.
OC.
Current builds
Completed works.
There is a lot of truth to that! This is a single planked Hull reducing the wiggle room some. I do have to add another layer to the wale; I’ll have to see if fiddling with that layer improves things. If not c’est la vie.
Fairing can be difficult to get right... I struggle with it from time to time!
I used mine as a learning experience too... made mistakes, learned from them and moved on!
Here is picture of my wales to counter seam... not much difference.
Check my build log if you want to see more.
I think you're doing great!
Lyle
"The only thing that stays the same is the constant state of change"
Completed Builds:
Occre HMS Terror - https://modelshipworld.com/gallery/album/2065-hms-terror-occre/
NRG Half Hull Project - https://modelshipworld.com/topic/23546-half-hull-project-by-lylek1-nrg/
1:130 1847 Harvey - https://modelshipworld.com/gallery/album/2125-1847-baltimore-clipper-harvey-1130-scale/
Scott Miller's Sea of Galilee Boat https://modelshipworld.com/topic/29007-sea-of-galilee-boat-by-se-miller-120-scale-lylek1/
In progress:
Artesania Latina HMS Bounty - https://modelshipworld.com/topic/26817-hms-bounty-by-lylek1-artesania-latina-148-scale/
Waiting for dry-dock space:
Model Shipways - USS Constitution
Master Korbel - Cannon Jolle 1801
A Scratch build -TBD
Thanks! I recall enjoying your build. I rechecked your log and I think my counter issue stems from the initial placement which fairing added more of a curve to that desired (I think). I think it’s probably good enough for this, but I prefer how yours came out and I’ll have to keep an eye of that in the future.
I'm a little surprised to find myself "finished" with the half hull (I still have to take it off the building board). I did notice one final "error" that I made in my build to watch out for. If you notice in the following picture I planked the transom short of the planks on the hull. I went back and forth and tried to look at every picture I could find to determine which was the right way and of course I missed a great picture further along in the instructions that showed I did it wrong. Not a big deal, but boy did I make my life a little harder placing the "decorative" pieces later.
Please ignore any waves that you see - fairing is the such a critical step in a single planked hull and I'm glad that I saw the consequences here instead of a future build.
I did paint the wales before gluing them on, but after fitting them
(What paint job doesn't need a little touch up?)
Due to the fact that I planked my transom "differently" I had to cover the ends of the planks differently and this gave me fits. The directions details one piece that is bent, I needed a lateral bend and it simply wasn't working so I split the piece in two.
I think I made the following piece 3 or 4 times after trying to bend a single piece 5/6 times 😁. In the end I got there though.
Here is the final reveal:
Big thanks to @tlevine and the NRG for putting this kit together (and thank everyone who followed along!). I found it highly instructional and I'm very glad to have worked through it. There are a few areas in the instructions that I wish had a little more detail (placing the counter, planking the transom) but it was a learning experience and I learned a lot. Be very careful about wet basswood and clamps though (oh the dents! - thankfully most came out after applying some water but I typically places some scrap basswood in between the clamps and the wet basswood).
Nice job!
What did you finish it with?
Lyle
Completed Builds:
In progress:
1 hour ago, Gregory said:
The basswood looks incredible..  I wonder why it gets such a bad rap sometimes..
Thank you! I think the end result came out very nicely but I have to admit that I wasn’t thrilled with the basswood at time. It can fuzz with sanding and dents but it was also easy to cut.
Superb work my friend  and a really enjoyable read, you finished her off lovely with tha contrasting Black and  wood.
Whats your next project?
OC.
Current builds
Completed works.
very nice
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
OC.
Thanks OC; I’m currently mulling over what to do next. @ccoyle has really been tempting me with his card models so I may try my hand at one of those before kicking off a longer term project again.
Edited by VTHokiEE
It looks great, despite the transom problem.  You used this project for what it was designed to be: a teaching aid on how to correctly plank a hull.  All that's left it to mount it and be proud of what you made.
Toni
Member IPMS
                           Utrecht-1742
Thank you, it really was a nice kit and eventually I’ll be giving the Capstan a go. In your log you mention covering the exposed areas of the Hull before mounting. Is that mainly for reducing dust? And did you mean a sheet cut to fit at the top?
Congratulation VTHokiEE. Good job. Hope mine comes out as good. Thanks for the sharing your experience with us
Ras
Current builds:
Previous builds:
The reason to cover the top of the hull is to keep people from looking in and seeing the bulkheads and any other messiness.
Toni
Member IPMS
                           Utrecht-1742
