9 hours ago, NovaStorm said:
Those look totally rad man. Good job!
Thanks Robin!!! 😃
Current:
USF Confederacy - Model Shipways (Build Log)
HMS Pickle - Caldercraft (Build Log)
Complete:
Virgina 1819 - Artesania Latina (Gallery)
U.S. Brig Syren - Model Shipways (Build Log, Gallery)
On the shelf:
Armed Virginia Sloop - Model Shipways
After finishing a couple more carronades, I think I got the process down for the tackles. Since I did not explain before, here it is:
First, a simple overhand knot secures the line on the first block, then the thread is inserted into the other block using a needle threader, and back to the first block. I did some experimenting to find the right length of the tackle + coil. I found that having a coil of around 80mm was a good size, and needed a bit of extra thread for the rigging part. The extra thread length was longer for the tackle pair used to swivel the gun (30mm) than the pair to adjust the distance from bulwarks (15mm). For the coil I briefly soaked the 80mm end in some diluted white glue and twirled it around a pin sandwiched between two hard clear plastic sheets (which I got from a spinach container 😁). Here is an image that probably explains the lengths better:
Here are some progress photos of where I have reached (25% done)
Current:
Complete:
On the shelf:
Nice job on the coils. I've done that  by coiling the line onto a piece of double-sided tape but your methods looks faster and the results are nice.
3 hours ago, Matt D said:
Those coils look really good.  Thank you for showing your method, too!
Many thanks for the comments Eric and Matt!! The only issue I am having with the coils is that there is a bit of a shine from the dried glue from certain angles.... Seeing the shine is driving me crazy!!! I think lightly scrubbing it with a toothpick might solve this issue. Anyhow, I have finished all the carronades, will post some pics later in the day!
Current:
Complete:
On the shelf:
That is some great work Walrus.  We got back from seeing our new grandson, and I finally got started on mine.  Your build log will be my go to for help, and pictures as it is a terrific resource. I started a build log from the view of a newbie.  It will be more photos with some written content when required.  After all, it is just my first.  Keep up the great work.
I often use pastels to dull model surfaces by dry-rubbing them in with either a fingertip or brush. They can add a nice complex texture to a surface. A cheap box of pastels can last a lifetime of light weathering and could help dull the rope coils. Not sure how it would work in your specific situation but you could test it on an off-model coil to find out. Just a thought.
4 hours ago, Overworked724 said:
You could try to dilute the glue a bit more. That may help.
Thanks for the suggestions!
I should have diluted the glue more, but I guess it's too late since all the coils are done 😅, I'll try if the pastel method works, otherwise I'll just try scraping off the shiny bits lightly with a wet toothpick.
Current:
Complete:
On the shelf:
As promised, here are the pics!! I consider it to be a another milestone of the build since this section took a while haha.
Here is the Syren with my first build, the Virginia.
Before I proceed with deck fittings, I want to seize the line attaching to the bridle, rear, and stern gun port lids onto the cleats. Does anyone know how to do this? I guess it is seized in a 8-like pattern, but would like to see how it is done exactly. Any suggestions are much appreciated!
Current:
Complete:
On the shelf:
Thank you for the comment! Congrats again on your grandson!! 😊
I'll follow your log with interest and I'll try to help where I can. Good luck on your build!
Current:
Complete:
On the shelf:
7 minutes ago, el cid said:
Cleat belay video...
Thanks so much!! The video explained it very clearly.
Also, I didn't know it was called belaying 😅
Current:
Complete:
On the shelf:
4 hours ago, Chuck said:
Nicely done!!  Its looking great.
3 hours ago, BobG said:
Beautiful work!
Thank you Chuck and Bob! :)
Current:
Complete:
On the shelf:
Superb work and a very great result !
Jean-Paul
'You are not carving a bear with a chain saw here folks',
Chuck Passaro, ´Queen Anne Style Barge´ manual of instructions
Current builds :
Finished build :
Next on list :
  • HMS Winchelsea 1764 - Syren Ship Model - 1:48
One word.....Fantastic!
John
Member: Hampton Roads Ship Model Society
Current Builds: Tugboat Dorothy  Newport News Shipbuilding Hull #1 (complete)
                           Iron Clad Monitor (complete)
                           Sardine Carrier which I will Name Mary Ann (complete)
                           Pilot Boat John H. Estill Newport News Shipbuilding Hull #12 (my avatar)
                    Harbor tug Susan Moran
                    Coast Guard 100' patrol boat
                           Light House Tende Beech (complete)
Many thanks for the compliments Jean-Paul and John!!
I have belayed the lines attaching to the port lids. I have just tied them without glue (except for the portside bridle port since it was the only one giving me a tough time 😅). For that one I used a very miniscule amount of superglue to help secure the thread so I can loop correctly.
Wanted some opinions and thoughts on how they look. Anything I should change? And are rope coils supposed to be added to them later?
20201005_091042a.thumb.jpg.6afe6ce5395a71d9458be22b1f6da97e.jpg20201005_090824a.thumb.jpg.5f4d1d52ba8e251f965e710fb7228d4e.jpg
20201005_090945.thumb.jpg.83c5673bfb373754b2b3110d10a4d7b3.jpg20201005_091049.thumb.jpg.ae63ded9dcf4099efe301b96f18f0861.jpg20201005_090922.thumb.jpg.1c083a65183dfcde0904d1ba91ebaa06.jpg
P.S. drilling the holes in the bulwarks was very scary!!!
Current:
Complete:
On the shelf:
Yep...those drilling events always make me nervous too. I’m putting in the trunnels holes in the side of my Syren now and that’s nerve wracking enough. Drilling the holes on the interior is cringeworthy...I’m afraid I’ll puncture the wall.
How are you drilling your holes?  Pin vise?
“Here.  Hold my beer..." --- Common phrase uttered by Lord Admiral Nelson at any pub. 🍺
Oh yea the treenails were also nerve-wracking for me. I misplaced one trunnel on the bullwark and I can easily locate it (might be almost impossible for someone else to see it though). At the time I was cringing at my mistake, but now I consider it as my signature 😁
Yeaup! All holes drilled manually with a pin vise. I don't think I have used my electric hand drill for this build (except for making pilot holes bigger in some cases eg. rudder hole).
Current:
Complete:
On the shelf:
3 hours ago, Gahm said:
I just caught up with your amazing progress. Your battery with the finished rigging looks great!!
Thomas
Thank you Thomas for the encouraging words!! I have been using your log as a reference and it helped a lot for the rigging 😃
Current:
Complete:
On the shelf:
On 10/8/2020 at 9:54 PM, Retired guy said:
Just catching up as well Wally your details and gun rigging is brilliant well done 👍
Regards
Richard
Thanks Richard!!! 😁
Current:
Complete:
On the shelf:
Making very slow progress with the deck details.
Finished making all the coamings and gratings. The gratings were very fun to put together. Reminded me of lego 😁
Here are some pics:
Here they are dry fitted on the deck:
Next step is to put in the treenails on the deck section and on each corner, curve the coamings and gratings to fit on the deck, and lastly apply tung oil.
Current:
Complete:
On the shelf:
Finished curving and detailing the coamings and gratings. For simulating the treenails, I used the same method I used before for the decking using sharpened toothpicks with 0.5mm holes drilled. Some pics:
Glued to the deck:
Current:
Complete:
On the shelf:
1 hour ago, NovaStorm said:
That is looking great, nice switch after all the work that went into the carronades.
Thanks Robin, working on the deck details is a nice change of pace!
Current:
Complete:
On the shelf:
