8 hours ago, Paul_S said:
How do i go about this in future?
What VTHokiEE is saying, is what I mentioned up thread.
The chisel may not work so well with MDF, but sand paper and files should do it.  If you have a rotary tool, a little drum sander would help if used carefully.
― Jimmy Buffett
On Hold:    Rattlesnake
I sanded a bearding line in but with 1mm of first plank and 0.5 mm of second plank x 2 meant i needed to sand it down by 3mm total which is the thickness of the false keel so that didnt seem possible, i got it down pretty thin already and it still stood proud
My experience starts to fall off here very quickly but I think you want to sand down to account for that first layer of planking (1mm on both sides). Then the second layer can be fitted or sanded to make a nice edge if desired. someone with more experience will have to jump in here though to correct me if needed.
I looked at the back of my build and I decided that I didn’t mind how it looked with the second layer a little proud towards the top. I noticed it in other builds with two layers of planking as well. I could only offer possibilities though since I don’t really know the answer.
Paul,
First of all a warm welcome to our corner of the model ship world.
Choosing a Victory model as a second, I like it!
I didn't know that the false keel was made out of mdf board.
You have done a fantastic job so far. I will follow along this build.
Respectfully
Paul,
you may leave the keel and sternpost-parts until the first planking is done and add them after that. The planks at the stern will almost lay flat on the false keel and you will be able to sand the first planking as much down as needed so the second planking will be in line with the keel and the stern post.
Best regards,
Andreas
Completed Build:
Armed Virginia Sloop 1/48 by Model Shipways / Gallery
HM Cutter Sherbourne 1/64 by Caldercraft / Gallery
Good information.  With all said and done, I have that kit in my stash, and will have to think about making that work when I get around to building it.
― Jimmy Buffett
So I planked the inside of the bulkheads which was pretty easy and have also planked the deck.  I randomly chose a planking pattern and decided i was goign to try 'joggling' ( i think thats the name).   I think its turned out pretty well
I caulked each plank with a pencil to get some lines in between
image0.jpg?width=1051&height=788
Halfway point  Not too happy about how the ends of boards lined up at the top left leaving me with the small pieces, but not sure how to avoid that.
Finished, can you spot the 2 deliberate errors?
and post sanding
image0.jpg?width=591&height=788
You're the judge. If you do put treenails in the deck, they should be barely visible. At 1:64 they have to be 0.4mm diameter, then covered by a stopper of the same colour as the deck with the faintest of margins on the rim of the plug visible. Then imagine yourself looking at a real ship from the deck, where you can barely make them out when your eyes are 5 feet or so away, and then put yourself in the position of looking at the deck from from 64 times that distance. That would be 320 feet or 97 metres. Do you want to be realistic, or draw attention to your skill or do you want to replicate models? It's an old conundrum.
Tony
Edited by tkay11
added 'or'
I think Tony is spot on for accuracy... but I think they look neat. Judging by the fact that you’re asking I’m going to throw my vote behind - Sure, why not? It’s awesome to have a finished model but the journey, that is really the fun. If it adds significant time but you think it’d be a nice addition then I say go for it.
Spent a few days messing around with treenails and couildn't come up with a method i was happy with so decided to forego them for now.  Maybe next model..
Got a few other parts done now
Wales are done although the measurements on my model didnt quite match up to the plans I think they are ok.
Capping rails ar e on but were too short, definetly messed up the back end somehow can see where it looks a little uneven but i think i've managed to hide it. Seems to be a consistent theme for me, hiding where I ballsed it up.
Red bits are painted as well as the wales.  I think im going to leave the rest natural wood rather than paint it white, bit scared the paint will show up errors a bit too much, and i think the wood looks nicer.
Started working on the deck furniture now with the hatches
Quite pleased with this!
  • 3 months later...
No other pics atm but will try get some, that ones a bit blurry.
My nephew has been fascinated by me building it and has asked me to make one for him.  Hes pretty lively so i think HMS Terror will fit him perfectly so will be making that for him.  If he can stay patient long enough for me to finish it
The Terror is a magnificent ship, I will follow that build along as well.
Nice finish of Lady Nelson.
Respectfully
Congratulations on finishing your Lady Nelson.  You did an excellent job on building this model.
Ryland
               - Nautical Research Guild
  • 10 months later...
  • 2 months later...
Very Nice!
Just ordered my Lady this morning. What colors and brand of paints did you use?
Dave
Dave
Current builds: Rattlesnake, Curtis P-40 Warhawk - 1/33 Card
Completed builds: Lady Nelson
On the shelf: NRG Half Hull Project, Various metal, plastic and paper models
