1 minute ago, mtaylor said:
As some former military might say...  "Stack 'em. Pack 'em. And rack 'em."  Looks great, OC.
Thank you kindly Mark,   quite intricate work to do  - just a case of  uisng my fine brushes  and going carefully  between them.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
6 hours ago, AJohnson said:
Nice detailing. 👍
Thank you  kindly.
OC.
Current builds
Completed works.
Evening all,   my little pile up is finished  apart from an airbrush flat coat to protect it.
OC.
Current builds
Completed works.
1 minute ago, king derelict said:
Looks very good OC. The pile will look very convincing when it's in place. It's going to be a cracking diorama
Thank you kindly mate.
OC.
Current builds
Completed works.
2 minutes ago, king derelict said:
I think it's a very tough trick to pull off. I've seen a lot of dioramas where casualties are essentially standing figures cut off their bases and placed lying down. They don't have the slumped look you see in paintings and photos and rather spoil the appearance. I think you have it sorted out.
Alan
That was  my initial thoughts  -  how to get a natural  look  - so I bent some of the legs  using the hair dryer  and brute  force, and messed around with their arms  etc.
OC.
Current builds
Completed works.
6 minutes ago, Canute said:
Very effective, OC. Not an easy thing to pull off. Can't wait to see this in the dio.
Thank you kindly Ken.
OC.
Current builds
Completed works.
10 minutes ago, mtaylor said:
Thanks Mark,  take you approve then🙂
OC.
Current builds
Completed works.
It's gotta be good, even the Kitty Kibbutz approves....
Quote:
OC.
Yes sir.  Very much so.
Thank you kindly Mark.
OC.
Current builds
Completed works.
5 hours ago, GrandpaPhil said:
Nicely done!
Thanks Phil.
OC.
Current builds
Completed works.
very nice indeed my friend, its going to look great when in place
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Thank you   so much Kevin.
OC.
Current builds
Completed works.
Evening all,  a we bit more progress  today,   I  cut the bases  from the 2nd  KGL  that I had made earlier,  these will be glued inplace  tomorrow,   I also  took another pic of the resin 5th KGL  wounded,  they are slightly  larger scale than my plastic  ones  not massivley  so but  you can see  the difference, so what I think I will do  is  to display them on another  section of the farm  (like the kitchen garden)  and  keep them  slightly  distanced  from the ohers  so the scale wont be that noticable.
OC.
Current builds
Completed works.
Evening all,   I was able to get the dio on my table  - then  glued down the 2nd KGL  attacking from the front entrance,   I also  de-based  some of my French  and placed them attacking  from the roadside  and also in the  Orchard  - still plenty more to come yet.
OC.
Current builds
Completed works.
It's coming to life!
Looking excellent so far OC.
Your pile of casualties is great, some very intricate brushwork.
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
Thank you kindly Edward,   I think my restraints now are governed  by how much physical space I have.
OC.
Current builds
Completed works.
All I can muster is "wow!", OC.  Looking fantastic.
9 minutes ago, king derelict said:
Wow. suddenly the scene is full of action and it looks terrific. Its only going to get better as more figures get added.
Careful handling from here on out !
Alan
Thank you kindly Alan,   indeed  my heart is in my mouth  every time I move it on to the table.
OC.
Current builds
Completed works.
Thank you kindly Mark   for  saying that,  I am sure as more and more is added  it will  reveal itself  to tell a story.
OC.
Current builds
Completed works.
OC.
Depends on the definition of "more".  I think you'll know when it's done.
"When I run our of space"  lol.☺️
OC.
Current builds
Completed works.
This is what I  call a  dio .............😲
OC.
http://bennosfiguresforum.com/viewtopic.php?f=78&t=23430
Current builds
Completed works.
