De Havilland DHC-6 Twin Otter by Jack12477 - FINISHED - Revell - 1:72 - PLASTIC
Now for build number 2 in the anti-boredom project, the DHC -6 Twin Otter done in the colors of the Canadian Rescue service.
First the box art and sprue contents, sorry I started building before I dragged out the camera, EG. 😉
20201229_132452.thumb.jpg.e3559f24c78515ebe0892b71f8147beb.jpg20201230_100231.thumb.jpg.b32bf468c35a1f51e46c263b8b8c1bcf.jpg20201230_100155.thumb.jpg.0dab1588eb2fa3960eb0ae6410a611ba.jpg20201230_100216.thumb.jpg.5449dabdc35616c9bd26fc7bab28edfe.jpg
The model can be built in one of 4 variants, including a float and ski plane. I prefer the ski plane variant and will build it as such
20201230_100447.thumb.jpg.ceda1b906e11ab76ee08aae7c283e398.jpg20201230_100350.thumb.jpg.12e1604bbae33143f5dc2e45fb882be8.jpg20201230_100402.thumb.jpg.4257e3b120c161cab77b66f329277193.jpg20201230_100327.thumb.jpg.823d138d54f476137e3030659b03c532.jpg
Decals provided
So I started assembling the model. Only 4 sprue!  Not a lot of parts per sprue.  Assembled the cockpit interior which cannot be seen once the 2 halves are glued together, installed all the tiny glass windows, glued the hull halves together. Simple ! Added the engine nacelles to the wings, selected the nose cone for the variant.  Nose needs 20 g of weight to keep the nose wheel on ground (tail sitter), so I added a bunch of copper clad steel BBs.  And now senility sets in, to keep the BBs in place I squeezed some Testors plastic cement over the BBs and attached the nose cone to the hull.
(You all know where this is going! Right ! ?) 🤔☹  Yep a few hours later I notice that the port side of the nose is slowly melting.......  😒  Left it overnight to see what would happen after the glue had fully cured.  Photos below show the disaster.
20201230_095751.thumb.jpg.ac2c16123dabaa3e7cc9ebe9e67d07e6.jpg20201230_100006.thumb.jpg.b2b8e8d079f9abf1e2bc45a3217ca962.jpg20201230_095820.thumb.jpg.05b47bdd8ecf0e3cb97a46d79ebed18d.jpg
Guess this is what happens to "ole coots" when they spend too much time underground.. 😷 The ole grey matter turns to mush.
So today I took out the Tamiya White Putty and a small spatula and started filling in and reshaping the nose cone.   Stay tuned !
Edited by Jack12477
I used to see Twin Otters quite regulary  flying over me.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Just seen the above  -  sorry to see that.
OC.
Current builds
Completed works.
Good choice. One could also use Bondo Spot Putty (the red stuff that sticks to plastic).
There's them that has and then there's them that will.  Case of TMB, Jack.
Too Many Birthdays.
I'll get my coat and hat. ;)
Ken
Started: MS Bounty Longboat,
Sad to see you off to this kind of start Jack. I like the looks and lines of this aircraft. Hopefully you can recover and salvage the build.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
No need to be, it's your choice as always.....
Now I'm off to the peanut gallery... (hmmmnn, I wonder if I can hoist a comfy chair up there?)
Quote:
read my mind Mark............can you say 'bird strike'....holy cow!   yea.....nasty :(    glad your gonna try to save it......next time,  white glue ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
We'll rig the block 'n' tackle up EG and get it up here.
Bad luck on the nose cone Jack, I  have full confidence that you'll get it sorted though 😏
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
Looks good Jack. Back in the 70s, our intel shop had a number of models of Soviet jets that were in similar appearance. No mistaking what that represents. Smooth finish will blend it all in.
Ken
That should smooth out beautifully Jack....
Excellent recovery.....
Quote:
Same as EG says  - great recovery.
OC.
Current builds
Completed works.
That's some great "cosmetic surgery" there - good job sticking with it and not giving up!
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    Hs129B-2 1/48  SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32   IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48  Eduard Sikorsky JRS-1 1/72
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
A little more smoothing and it's on to bigger and better things. Congratulations Jack. Are you going to make her float, ski, or wheeled?
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Good rescue with the nose cone ! Jack😉
Current builds;
Completed:
Thumbs up, Jack and you're good to go with the repair.
looks great!.....knew you could pull it off!  fine sandpaper and you'll have the shin back to normal ;)   are you going to replace the glass......some clear cello should do it.  get some Testor's window maker to cement the cello in place .   good save!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
replacing the windscreen would be near disastrous.  Already had to use G-S Hypo Cement to replace side window that went bling into never-ending land of missing parts. Actually it was the GS glue that messed up the windscreen in the first place.
Edited by Jack12477
Well, this isn't coming out the way I first envisioned but moving on.  Trying to fix/hide the botched panel lines, getting the paint to cover etc.
20210104_214013.thumb.jpg.96354cfeac5ccaf24f30699fa14d97f3.jpg20210107_154013.thumb.jpg.5f1267f148ba495f58dd76bdcb590aff.jpg20210107_154034.thumb.jpg.740c9910c8e848300fca33244ccc1e51.jpg20210107_154048.thumb.jpg.b2190a6509f8e6dc2583b4f36a9bde65.jpg
The paint I am using is Liquitex Cadmium Yellow acrylic
Just a suggestion Jack, when I used to do yellow on my grey plastic miniatures I primed them first with an off white/cream,  made for a better cover without brightening the yellow too much. As I say just a thought.
Current builds;
Completed:
Yes, yellows are translucent, like the tube label says (as are reds) and the primer is critical. Add another coat of yellow, taking some of the sheen off to get the next coat to stick.
Ken
That's a good primer and light gray should work. It's the translucent yellow. Strip and redo or try a second coat? I'd try a second coat. If its still like that, do-over time.
Ken
Yes I would have thought it should be ok with two coats over that primer.
Current builds;
Completed:
51 minutes ago, Jack12477 said:
This is the Tamiya primer I use, light gray.  Guess maybe I should try their white primer instead.
IMG_8738.JPG.fa16b498c9c24c837167439505ab5a7e.JPGIMG_8739.JPG.e9c209d2478579e3942d1508adb55f5a.JPG
Thats what I use  on my aircraft models.
OC.
Current builds
Completed works.
