Looks Fantastic , Nils
Best Regards,
Pete
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Herreshoff Buzzards Bay 14
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
thank you Pete,
the Progress is not going on so fast in the Moment, because many details are not taken directly from the Amati plan
Nils
Current builds
-Lightship Elbe 1
Completed
hee......hee...........I can visualize you balling up the plans and tossing them behind you   :D   plans are useless when scratch takes over!
looking  great Nils!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
very well spoken, and thanks Popeye,
Nils
Current builds
-Lightship Elbe 1
Completed
I think this Version for the swivelgun handles will do...
I am using the 15 mm Long gunbarrels from RB Models web-shop with a little updating. The Pivot boring is predrilled by RB already, with 0,5mm boring in about 1 mm depth only (not through), and the Little hole at the barrel-end is made with aid of a small gig, the handle is soldered in 0,8mm brass wire and a small metal bead is slipped onto the wire and AC glued at the end
Nils
Current builds
-Lightship Elbe 1
Completed
Richard,
thanks very much for your appreciation
Nils
Current builds
-Lightship Elbe 1
Completed
Very nice work Nils , I think The swivelguns look great . I like how you have put this build together
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Hello Nils, very nice progress but I think the eyelets slightly too large for this scale aren't they????
Hi Tom,
Thanks for your comment,
I know eyelets could be much smaller, I`m taking that in account, regardless to the scale in this case, probably it is from the experience with the rigging of the recent built tallships where there was quite some tension on all eyelets for steelwire shrouds, stays, backstays, yardlifts, etc, and what I would`nt want at all is a self opening eyelet from tension in a Position I have no more access to afterwards. Of course with this ship there are no steel wires to strumm, it`s just to be on the safe side for forestanding reasons. Once the eyelets are tackled permanently they will be closed by bending the Loop as Close as possible.
Would gladly hear of experience made by others regarding safe anchoring points
Nils
Current builds
-Lightship Elbe 1
Completed
thanks Tom,
Nils
Current builds
-Lightship Elbe 1
Completed
today doing the roughtree rails
the ends made in metal
hight check is OK
Nils
Current builds
-Lightship Elbe 1
Completed
Beautiful workmanship Nils!
Michael
Thank you Michael,
those gunposts were always Standing around the Quarterdeck, and I was anxoius I would knock against something by mistake and break them off, now that seems under control
Nils
Current builds
-Lightship Elbe 1
Completed
Looking good Nils, I love all the detail work that you have done
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Apologies for not being around much of late Nils and having to play catch up.I love your 'model engineering' approach to creating the details,great work!
Kind Regards
Nigel
Currently working on Royal Caroline
Thank you Pete,
As you have seen I do`nt necessarily Need to stick 100% to the plan with this scratch build..
Cheers
Nils
Hi Nigel,
yes, you`re right some of the ideas come like a Flash and may even be changed whilst doing in order to suit better. For example I did`nt like those belaying Pins on the lower quarter rail cut out of plank, now they are made from round, it gave me a little bit the Impression of a jawbone of a potwhale, with the ivory teeth. The use of unpainted brass along with the Wood tones is obligatory for my optical appeal system
Nils
Current builds
-Lightship Elbe 1
Completed
Aft supports for the roughtree rail and belaying pin racks
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Nils -- At long last I've come across your log, and have to say that you're building a beautiful ship.  The detail is lovely.
Martin
Current Build:  HMS FLY 1776
Previous Builds:  Rattlesnake 1781
                        Prince de Neufchatel
looking pretty sweet Nils!  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Martin
Hello Martin,
thank you for visiting my log.
At the beginning of my own decision for a "Swan Class vessel making" (Fly or Pegasus)I was also a bit irritated by the Amati kit contents such as castings for quarterbadge and sternplate. After asking the Amati dealer, I was told that the Pegusus had no metal castings but layer photo-etched brass sheets that would give a halfway 3D effect. I found this very interesting, because never seen before, and the result from MSW fellow builders Pictures encouraged me then to purchase the Pegasus plan together with these etched parts and to do a scratch-build Version. What I like with some of the HMS Fly Models displayed, is the creme-White Sub waterline paint finish. Maybe yours shall show this as well.
Wish you ongoing good success with yours and much fun as I am having in setting her together, also getting all this inspitation that MSW comunity provides...
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you Popeye,
I hope that I can get the forecastle deckrails (without a roughtree rail) done in the same way, but would have to Change some of the already neat Fitting glued on parts (hopefully without destroying anything else in doing so)
I`m glad I did`nt fit the catbeams and the upper bow rails yet
Nils
Current builds
-Lightship Elbe 1
Completed
Hallo Nils
Once again I just had an (imaginary) stroll through your amazing Pegasus. Wonderful!
By the way – what are your plans for the rigging? None, plain or with sails?
Keep up the good work.
Cheers
Peter
Hello Peter,
nice to hear from you again, and thanks for your words...
I had really planed to do full rigged sails, always hoping that the one or other of the fellow builder would set sails to a good breeze well ahead of me, so I can see what it Looks like. In my mind I see a White swan blustering its feathers a bit, drifting over the lake in a gentle wind. I also remember That Danny (his wonderfull Vulture 1:48) once mentioned that too many sails would hinder the sight into the outcut hull and -decks and I share his opinion there.
For the standing and possibly the running rigging I trust and hope there shall be some very well done presentations on the Swan Classes rigging on MSW in due time, and last not least with aid of the Amati plan. When the time for rigging is reached, I will have to groove myself in first anyhow. I think Glen Barlow once mentioned that he spent so much accureness and functioning ropes into the running rigging Detail, that the ship could be sailed if magnified to actual size.
Cheers
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you very much for your words Geoff,
Nils
Current builds
-Lightship Elbe 1
Completed
Hallo Nils
Yes, I think we all like those … swans. A noble cloud of sails sure must be a glorious sight, but Danny certainly is right as well.
A possible solution could be to set not all of the sails, the swan not blustering all of its feathers, so to speak. Depending on the situation you decide to show your Pegasus in, there are almost unlimited combinations of sails set, hauled up or furled possible. You just have to choose one, where you have a good view of the decks and still a pleasantly balanced arrangement of sails. An example could be that picture (from Peeter Goodwins The Ships of Trafalgar) showing Thunderer hove to.
I’m looking forward to your solution of that tricky problem. ;)
Cheers
Peter
Thank you very much Peter,
you are reflecting exactly my thoughts I have in mind....., thats a nice Picture resembling a great Inspiration for sail Setting on a model, probably I´ll go for a good compromize solution like that. Your own rigging with partial furled and hauled up sails is also a good Version for orientation...
Nils
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
Today the Access ladder to the forecastle deck is fitted for Position check
I know this may not be historicly wise correct, but I just could`nt mount those Little "pigeon-ladders" the way the plan shows. Leaving awy the forecastle bulkhead anyhow, the underneath area would be open, and the captain claimed a propper stair there after slipping off the foreseen ladder of the plan several times
The ladder now neatly fits in between the first and the second starboard gun, without hindering the tackles there
Nils
Current builds
-Lightship Elbe 1
Completed
The ladder looks great , Good job Nils
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
