HMS Pegasus 1776 by Mirabell61 - FINISHED - scale 1:64 - 16-gun sloop
I always knew you were a good foreman.
Bob
Current build:  SS_ Mariefred
Link to comment
Share on other sites
your rigging is fantastic Nils....WOW!  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Thak you very much for your word Popeye,
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Nils. I am continually amazed at how much fine detail and work you accomplish.
Michael
Link to comment
Michael,
thank you so much, your Kind comment is gladly appreciated..
The rigging is the first thing to attract ones eye later on, so I`d better put some concentration on it. Also it takes longer than I thought. Trust I would`nt have the Patience to do a rigging for a heavy frigate like "Agamemnon" or "Victory". When all is complete at least I can say that I`ve once tried an 18th century rigging.
I admire all those members, for example with their 1:48 scale square riggers where even most the Standing rigging ropes are precisely served......
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Simply Amazing Nils, just incredibly beautiful work
Best Regards,
Pete
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
Link to comment
Pete,
Thank you very much for your Kind comment, I`m glad you like my work...
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
This is specialy to thank all fellow builders
that expressed their "likes" without comments recently by activating the appropriate button
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Update
here a little update on the foremast topsail and the lower squaresail.
My technique for rigging is to pre-rigg the two yards, hang the yards with the attached sail into the slings and then sort out the lines, rigg and belay them to the appropriate terminals. Buntlines, reef lines, leech lines come on a bit later. all the bow lines will go on last, when the braces are set
Nils
I use mini rollers (diam. 2,5 mm) from RB Models webshop as thimles
here thimbles attached for the truss tackles
foresail attached to lower yard
self explaining.....
the scetches for the mainmast yard rigging come very handy again here
these two pre-rigged foremast sails are ready for hanging into the slings
Current builds
-Lightship Elbe 1
Completed
Link to comment
I think the roller-thimble idea works brilliantly :)
HMAV Bounty 'Billings' completed
HMS Cheerful - Syren-Chuck' completed :)
Steam Pinnace 199 'Billings bashed' - completed
HMS Ledbury F30 --White Ensign -completed 😎
HMS Vanguard 'Victory models'-- completed :)
Bismarck Amati 1/200 --underway  👍
Link to comment
Lawrence, Patrick,Bob, David and Ian and all the "likes"
Thank you so much for your Kind comments and appreciations......
Lawrence,
I`m quite pleased so far theat the planed and intended Details worked out alright
Patrick,
your encouraging comments are much appreciated, thanks so much
Bob,
a masterbuilders appreciation......, thanks so much Bob
David,
Thank you David, I`m glad that you like it
Ian,
yes I was looking for a suitable Little Fitting with a circumferential groove to pick up the appropriate pendant line. I find These rollers look just right
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
beautifully done Nils........some really nice work there  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Appreciate your comment Popeye,
Thank you very much
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Thank you very much Hartmut,
I`ll be happy if it is of helps to you with your next rigging project, especially if ist going to be a squarerigger
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Little update...
Build log part 80
some impressions on rigging my Swan Class
Nils
again a hand scetch for  belaying of the fore bits (On forecastle deck), slight changes to needs pending
one of the yards....., with stirrups, footropes and Flemish horses
the prerigged foresail together with its yard has been moved into place
the tacks of the main topsail stay-sail will be lead over thimbles to the aftmost shroud and lower attached shroudcleats
the truss tackles go down to the eyelets next to the foremast and leaves the lowest block for the sidewise attached cleat on the foremast
for access to the lead blocks under the foremast platform the upmost futtock ratline has been left out until later, have to still fiddle in buntlines and leechlines there
slowly the "sail picture" is rounding up...
14 of the 18 sails are on now....
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
Link to comment
Hi Nils.
I seriously don't know how you do it so well. I've read and re-read and re-read again, one rigging book after another. I've studied diagrams. I've copied other people's models. I've studied photos. I've freeze framed images of full rigged sailing ships on TV...but, I still don't understand how things work, or what line is what and where it belays to.
Yet, I see what you're doing and how well you're doing it. I envy how you make it look so deceptively easy.
Without a doubt, I just wish I had your brains and talents. If so, I'd go back and properly re-rig all my boats!!!
Of course, that ain't ever going to happen, so, I'll just have to be content with admiring your work!
Cheers
Patrick
Link to comment
Nils -- Those photos of the full build are stunning, where the full sails really make their impression.  This is going to make for a captivating display piece.
Cheers,
Martin
Current Build:  HMS FLY 1776
Previous Builds:  Rattlesnake 1781
                        Prince de Neufchatel
Link to comment
Thank you very much Patrick, Crackers, Martin, and all the "likes"
I highly appreciate those fine comments, it makes me happy and self satified that my work is liked.....
Patrick,
The full understanding of lines and their function I studied from Lennarth Peterson`s book (only super self explaining drawings, no text). For written explaination and also drawings of the complete rigging I have James Lees book. The remaining information is from the very nice Amati set of plans.
What makes my rigging here a little challenging are the functional braced yards with their sails, (max. 45° before jamming the shrouds), but this is one of the obligations I set to myself for the rigging. This means to watchout that sail operating lines do`nt foul the braced sailcloth bows neighther on weather- nor on leeward side
Crackers,
thanks so much for your nice words, hope you may enjoy further on, I am having much fun with the rigging....
Martin,
thank you very much for your kind words,
before I started with the sails (staysails first) perhaps you remember, I was unsure of the number of sails, because I did`nt find a Swan Class rigged under full sails let alone a scale 1:64 version, on the web or on MSW. Your answer at that time gave me confedence that there were 3 triangle sails only (and no extra  flying jib). So it was actualy a small frigate with slightly reduced sail area. (no royals on the large masts and  only a topsail on the mizzen as the only squaresail there.
As I could`nt afford Antscherl`s Volume IV for crosschecking I had to take a certain risk........
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
I’m with Patrick.  I pat myself on the back for figuring out how to rig a schooner and then I see what you are doing.  I can only sit in amazement.
Bob
Link to comment
Thank you for your words Bob,
like I answered to Patrick its not confusing any more if you have a chance (plan , book, etc.) to study and understand the functions, and then go step by step
Meantime I think, I`m familiar with every line type and their function for standing and running rigging on a rather small squarerigger lke this
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Little update....
I`m at the foremast upper shrouds now and stropping all the blocks for the fore-topsail, which will come next
Nils
I`m rigging (Bracing) the yards at 45° angle
looking a bit more dynamic with braced sails
tack, sheet and brace lines not attached to the lower squaresails yet
one hand for your life the other for the ship......
the third swivel (from bow) points through the lower shrouds, directly obove the swivel elevation the shroud cleats will be attached as well as an additional ratline that also fixes the cleat fastening
Current builds
-Lightship Elbe 1
Completed
Link to comment
absolutely beautiful Nils!  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Thank you very much Popeye
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Lawrence,
thanks very much for your Kind appreciation, there are so many belayed lines in the moment, and I still have to do all the coils at the ends......, wanted to do that when all the sails are on...
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Hi David,
although I have sometimes the very distant puff of Emotion that I`ve been in places, or seen things somewhere before, but a weaver........ no...
Thanks for dropping in to my build again youre always wellcome
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
