HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 66 donations so far out of 49,000 members - Can we at least get100? C'mon guys!) ×
3 minutes ago, mtaylor said:
Have you tried a Ouija board?  Sounds like that might work as well the manufacturers instructions/list.   I'll keep my fingers crossed it's just the filament but considering all the problems you had early, I'm beginning to wonder.....
Thanks Mark
I have been reading that there are a batch of bad motherboards out there that cause extrusion issues, binitial layer instability - makes me wonder. 😄
I hope the digressions into the 3D printing problems are acceptable in a build log rather than just a focus on teh model itself. I wanted to try to capture what I am learning with the process of making the 3D prints and maybe showing the lessons and results as well as the creation of a model
This morning I found that the controls on the printer allow a set length of filament to be extruded through the nozzle. So if you set 100 mm and you only get 95 mm its under extruding. That was the sort of information I was looking for so I marked 100 mm on the filament and set it running. It only extruded 50mm! A repeat attempt gave the same result. That is much too far in error to be a factory calibration problem so I wondered if it was the filament possibly being too hard and slipping in the extruder so I got out another reel and this time I got 60 mm instead of a 100 mm. Out of curiosity I tried a brand new reel and got 70mm. The value for each reel seemed repeatable, I can't see anything wrong with the extruder but something is not right. I increased the e-steps (the ratio of stepper motor steps per mm extruded) and a print came out much better. I don't think this is a dependable fix so I have ordered an aluminium extruder upgrade set to replace the factory plastic one. I can only think the extruder gears are slipping and the relative hardness of the filament results in the different extrusion rates. With luck I can get the upgrade installed in the next few days and see how it works out. I might install a new nozzle at the same time. Hopefully the voodoo will return
Alan
It's appropriate do post those issues I feel.   They'll help others who follow your log.
Try a new nozzle first if you have one.  It's possible yours is clogged or something else happened to it.  The new extruder can be installed after the nozzle.  The old rule of thumb I was taught was "change only one thing at a time otherwise you'll never know what the problem was.".
I just gave a thumb to Mark's statement!
Respectfully
Thanks Mark. I like to make one change at a time too and looking at the parts to change it doesn't impact teh nozzle so it will be left alone for the while
Alan
A day for learning. The replacement aluminium extruder upgrade kit arrived. In typical Creality fashion the instructions were an illustration with no text but there is a good Creality video and it is not very difficult.
When I removed the original gear from the exruder I found the cause of many of my recent woes. The PLA filament is obviously quite tough stuff and it had chewed a groove in teh brass wheel removing the majority of the teeth and allowing teh filament to slip.
This explains the poor detail and poor structural integrity of some of the prints - especially the more delicate ones. Also when I checked the calibration of the stepper motor I found that for a 100 mm commanded extrusion I only got 90 mm. So the printer has been under extruding the whole time I have had it and I think that is why I have had so much trouble with the alignment to the print bed. With the nozzle under extruding the line of filament being put out is thinner and cooling faster so getting good adhesion to the bed is more difficult. I am amazed now watching the printer putting down solid lines which are well fused to their neighbours and not skipping lines as it fills in sections.
Its very encouraging to have found a solid reason for the problem and be able to effect a cure. The upgrade kit provides a brass replacement gear and I haven't seen a further upgrade to a harder material so I suspect this problem will come round again but at least i know the symptoms and the cause. I have invested in a pack of ten gears from Creality for $10.
The first prints are very promising so here are a few before and after photos.
The four inch gun shield (half)
And the piece that brought this all into focus - the life raft racks
Now I have to decide how far back to go with repeating prints to clean up their appearance. I had only started printing the detail parts so hopefully not too far.
Thanks for looking in. Hopefully the next entry will be a bit more boat like
Alan
Wow... what a difference.  Who would have thought it was the brass feed gear?  I hope you'll pop them a message about the brass gear wearing like that and that fast.
Mark, unfortunately it's a know issue. The brass gear in Creality printers (Chinese) are much softer than American/European made (gear I mean).
Respectfully
Glad to hear you have found the source of your problems Alan, but not so glad to hear of the poor QC with material choice by the manufacturer. If the filament is that hard, maybe you should 3D print some replacements for the brass part!
Hi Mark
I was surprised that it has already worn smooth in about four months. It has done some pretty heavy printing though. With all the initial problems i probably printed  the equivalent of two hulls to get good prints. The disappointment is that in the extruder upgrade you just get the same brass gear instead of a hardened one> creality seems to prefer selling you bags of ten replacement gears instead.
Alan
I did find a third party selling stainless gears but they got horrible reviews for poor teeth profiles and off centre bores that I didn't give them a try. One reviewer stated that out of ten two were useable.
Alan
I did find out that brass can be tempered which is probably what this needs.  However, finding an oven to get that hot is a problem.
https://sciencing.com/determine-copper-real-10511.html  Scroll down and you'll instructions.
Thanks Grant
The Ender is a great machine for the price. It seems to be Crealitys business plan to ship an "entry level" machine and then have a huge range of upgrades to support it. Being originally supplied as a kit it is amenable to being pulled apart and rebuilt which is nice. The upgrades are generally not expensive .  The lack of an upgraded gear is a bit annoying though. They do sell a complete new extruder but I'll see how the new gear holds up now that I'm not banging out 30 hour hull part prints back to back.
Alan
Thanks Mark
I think my oven is more suited to the turkey on Thursday
Alan
The printer has been on duty through the day reliably turning out replacement parts. A last "before and after" shows the aft bandstand showing the poor quality of the earlier attempt that I was resigning myself to using. A set of bollards and cleats has now printed successfully 1468090835_xRIMG0081(1280x720).jpg.c576d5dd444c269f5afa84bc8385f2aa.jpg
I hope to continue printing out parts in between holiday activity for the next few days.
Thanks for looking and for the encouragement
Alan
Much higher resolution parts Alan.:D The better reliability and quality of parts should make this a much more rewarding build for you.  For what it is worth I don't think the brass feed wheel was your fault. You have been having problems getting quality prints right from the start.
Edited by lmagna
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Wow... that is an improvement.  Getting the upgrade bits probably helped a lot also.  Congrats.   I hope things keep going well.
Looking really good now  - what a difference  - so pleased for you mate.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Hard to believe those parts were created by the same machine! Well done Alan - your perseverance has certainly paid off.
Thanks Lou
Its great to see decent quality parts building up on teh print bed now
Alan
Thank You Mark
As an engineer I do much better with a tangible problem that I can find a solution to. It was frustrating flailing around not knowing what direction to go
Have a great day tomorrow
Alan
11 hours ago, yvesvidal said:
Alan,
You have been officially promoted to Creality Ender V2 Field Support Manager !!!!!
WOW, what a difference in printing.
Yves
Thank you very much Yves. I'll wear the badge with pride but I'm hoping I don't have to do too much more to keep it. I'm looking forward to knocking out good prints for a while.
Alan
Just to be clear, tempering is reducing hardness, generally in favour of toughness.  And reducing hardness of the brass drive roller is probably not what is required here.
The process described in the link is indeed softening the brass (or copper) to its softest state, even if I would describe that as annealing.
Rolling the drive teeth into the drive roller after machining will have work hardened the brass considerably and I would expect that to be the condition that gives the longest life propelling the PLA.
Andrew
"Pas d’elle yeux Rhone que nous”
Kits under the bench: Le Hussard (Started in the 1980s)
Scratch builds:               Volante, Brig (R/C): Footy Drakkar "Rodolm" (R/C).  Longship Osberg (R/C)
Alan
Many thanks for your blog;  I am learning a lot of the things that (I think) I need to know about 3D printing.
Your "catch" of the filament roller is an example of getting to the root of a problem, after fire-fighting all the effects seperately
Very instructive blog, very impressive model
thanks,
andrew
Andrew
12 hours ago, liteflight said:
Alan
thanks,
andrew
Thank you, Andrew, I'm glad you have found it useful. My intention was to try to share lessons as I learnt from my mistakes.
Out of the chaos I have developed a bed levelling routine that works for me and which I check regularly. As a result of the extruder gear issue, I will be checking the filament extrusion rate if prints start to lose quality. I'm trying to knock down the unknowns in printing.
Alan
