The first option went to the trash can. The form seems to be sheathed well, but it’s impossible to remove the shell. Something hasn’t been done fully probably. Apparently I will have to remake the form, and make it from three parts that can be disassembled.
I made a technological mistake and here is the result. I will have to try again.🙂
 Meanwhile I am tuning the Proxxon circular saw, a gift for the New Year. Some components are very crude and require some changes. My best regards
Sad to see your first effort go to the trash bin, especially as you planked it so beautifully.  But your old method produced a very fine boat.  Very nice work, Alexander.
Gary
Completed Scratch Builds
Basically, I have finished the longboat. I don’t see the point in further detalisation. There will anyway be a boat on top. I didn’t do the the rudder as well, because I don’t have to install it anyway. All that’s left is to cover it with oil.
On 2/25/2023 at 2:52 AM, KORTES said:
I decided to change the covers of the ports .
That's a very remarkable improvement on such a small detail!
Dave
“You’ve just got to know your limitations”  Dirty Harry
Current Builds:  Modified MS 1/8” scale Phantom, and modified plastic/wood hybrid of Aurora 1:87 scale whaling bark Wanderer.
Past Builds: (Done & sold) 1/8” scale A.J. Fisher 2 mast schooner Challenge, 1/6” scale scratch built whaler Wanderer w/ plans & fittings from A.J. Fisher, and numerous plastic kits including 1/8” scale Revell U.S.S. Constitution (twice), Cutty Sark, and Mayflower.
                  (Done & in dry dock) Modified 1/8” scale Revell U.S.S. Constitution w/ wooden deck and masting [too close encounter w/conc. floor in move]
Hope to get to builds: MS 3/16” scale Pride of Baltimore II,  MS 1/2” scale pinky schooner Glad Tidings,  a scratch build 3/16” scale  Phantom, and a scratch build 3/16" scale Denis Sullivan.
On 7/10/2023 at 1:25 PM, KORTES said:
I also have great respect for hand crafts, but when you need to cut several identical elements by hand, it's quite stressful.
    That is probably true, but it just makes your results just that much more remarkable! :imNotWorthy:
    My paternal grandfather was also very good at carving by hand back in the depression with his own handmade tools.  I was always impressed by how he could create such beautiful sculptures and furniture from the most basic tools and scraps of lumber that he could get a hold of.
    I think that's who I inherited my urge to recycle rather than replace from.
Dave
 Beautiful ship's boats, Alexander.
Unfortunately, I got the artillery with a shortage, there were no trunnions for the carronades. I had to make it myself. The main difficulty was producing a large number of identical parts. Since I don’t have enough metalworking equipment, I had to use wood.I made it from black hornbeam which took me some attemps. I deliberately made it  simplified, on my scale and with my “machinery park” - I think this is acceptable.
  • 6 months later...
That is some meticulous work there, very well done. I think I might just pull up a barrel and follow along here :)
Hello Kortes,
I am an admirer of your model-making skills.
You have made these carronades with great finesse and precision, like all of your wonderful models.
As I have now seen, the upper parts of your carriages are equally strong at the front and rear.
As you also value historical accuracy, I did not want to withhold the following information from you.
I studied the carronades for the La Créole intensively during construction.
Accordingly, I noticed that the upper part of the carriage tapers slightly towards the rear.
I have marked this with red lines on the drawing section of the monograph.
This taper is also clearly visible on the historical black and white photo of a French carronade.
This is why I enjoy the discussions and interactions of this forum so very much, the friendly exchange of valuable pieces of information like this.
8 hours ago, archjofo said:
Hello Kortes,
My greetings,  dear Johann. My work on the corronades  was based mainly on Your Masterclass on the carronades creation. I have never seen a more detailed and informative report. Concerning the constructio n I ve payed attention that the upper, movable part of the gun carriage is thinner than the lower part, so i made it like this ,but i did not know that it has trapezoidal shape. Im very grateful to You for such a valuable information ! I will definitely know that for the future. But these gun  carriages will be left as they are, moreover that in my case the inclination will  be of the size of a fraction of mm. Please, allow mw to express my gratitude to You for the information,  its an honor for me that You as a Maître of such a level  paid attention to my work. My very best regards
